Removing the doghouse 84FC35
03-29-2007, 05:36
Keith- on your front bumper, is there 2 small hinges under the bottom edge?
You still have 4 bolts on the bumper. Just curious.
83PT40
Livingston, Mt
03-29-2007, 06:06
I recently saw a post on removing the doghouse. I'm having some
maintenance done tomorrow by a mobile mechanic and thought it would be
a good idea to be familiar with doghouse removal. He says he will check
all the belts , hoses, and air filter, etc. I think it says "dynapak"
on the filter housing and I'm certain I'll need to remove the doghouse
to get at the belts, etc.
Your help is appreciated, Keith
84FC35
03-29-2007, 06:27
Keith,
You won't need to remove the doghouse to check the belts, hoses and air filter
but you
will need to open up the front of the coach which is much easier than removing
doghouse. If you have a swing radiator, it will be a pretty short job to get to
the front of
the engine. If you don't have a swing radiator (I don't) you will need to drain
the radiator
and remove it. Takes about an hour when you're used to doing it.
Removing the doghouse is required when you need to get into the top of the
engine to
adjust valves, replace injectors, etc. I posted a Wanderlodge procedure for
this in the Files
section of this forum. I just had an experienced BB mechanic pull the doghouse
to do
some engine work. Took him 2 hours to get it out and 2 hours to put it back in.
It's heavy
and cumbersome to work with in a fairly tight area. Avoid this unless it's time
to adjust
valves (every 40,000 miles per Caterpillar).
Regards, Eric in San Antonio
84FC35SBWL2
--- In WanderlodgeForum@yahoogroups.com, "Keith Strehle"
> 84FC35
03-29-2007, 06:30
Eric, did your mechanic take the top cover off the doghouse? Even then, it
takes 2 people to get the bottom section out of the coach- unless you are
really strong.
83PT40
Livingston, Mt
03-29-2007, 06:54
I just bought the Bird and I'm trying to catch up on some of the more
immediate maintenance issues. Oil/filter change, fuel filter, air
filter, check belts and hoses, lube the chasis, etc. The guy said he
can do most of this in three hours. However, as it turns out, this
Bird has 36,000 miles so it seems like a good time to adjust the
valves.
But one thing at a time... I don't have a swing radiator. I'm just
wondering if he can get at the air filter without removing the dog
house. And is there any access to check/adjust the belts from the
bottom?
Keith
84FC35
--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson"
> Keith,
air filter but you
than removing the
job to get to the front of
need to drain the radiator
of the engine to
procedure for this in the Files
the doghouse to do
put it back in. It's heavy
unless it's time to adjust
> 84FC35SBWL2
would be
check
says "dynapak"
doghouse
> > 84FC35
03-29-2007, 07:32
Keith,
If your air cleaner filter is mounted on the top of the engine like mine is,
there is
absolutely no reason to remove the doghouse to change it. It's a large, square,
metal box
that sits right on top of the turbo intake. I recently changed mine out in
20-30 minutes.
Bear in mind, there are various skill levels out there when it comes to
mechanical help.
This guy may be able to "check" belts and hoses but I wouldn't let him near the
3208
engine internals (I'm talking valve adjustments, etc) unless he is a trained,
experienced,
diesel mechanic. Many of the really qualified people don't like to mess with
motorhomes
and things like doghouse removal, so you will need to talk to other Bird owners
in your
area or conduct your own search to find someone that CAN do it and WANTS to do
it at
some reasonable cost. Hint...your local Caterpillar shop may do the job, on
their terms,
but you will pay very dearly. My first valve adjustment/injector change cost
$2,400 done
by Cat. This was after they estimated the cost at $800. They blamed it all on
the time it
took to remove and replace the doghouse.
There is no way to check condition, replace belts and retension your belts
without
removing the radiator. Same goes for hoses. There are quite a number of hoses
you can't
even really see from above or below the engine. I open up the front or our
coach at least
annually to look things over. Check the file I posted in the files section
under "3208 Belts
FC" if you want more data on belts and tensioning.
Changing oil/filters, air filter belts and hoses is a good place to start. Do
you know the
original owner so you can find out when and what maintenance items he has done
recently? There is a real laundry list of other items, as I'm sure you're
aware, of other
things to look at. I can send you a maintenance spreadsheet I use to keep track
of stuff on
our coach if you're interested.
Finding an 84FC with only 36,000 miles is quite a find. If it was stored and
maintained
well you are in luck. Low mileage is great from a cosmetic wear standpoint but
these units
do best from a mechanical standpoint when they are used regularly.
84FC35SBWL2
> valves.
> bottom?
> Keith
> 84FC35
> > Keith,
> air filter but you
> than removing the
> of the engine to
> the doghouse to do
> > 84FC35SBWL2
> would be
> check
> says "dynapak"
> doghouse
> > > 84FC35
03-29-2007, 08:05
Unfortunately the folks I bought the bird from were not very familiar
with the maintenance schedule. It appears the Bird was maintained on
a regular schedule but was stored outside. It has a very new
appearance on the inside but the outside has suffered a little. Not
much though. It was a "family" bus. Several brothers used the bus
from time to time and none of them were real clear on what had been
done. I had a friend and fellow bird owner, Robert Britton, check it
out for me. I drove it from San Jose to San diego 500+ miles with no
problems.
This mobile mechanic was recommended by a local and well respected RV
shop in Escondido. But I agree and don't plan on letting him do
anything except general maintenance. I like to do as much of the
work as I can. Doghouse removal is one of the things I'll do before
having the valve adjustment done. Same with the hoses and belts.
The air filter is just like yours and shouldn't be a problem.
I plan to turn it into a "proven" coach by putting some miles and
some usage on it.
So tomorrow I'm getting the front tires replaced and then the general
maintenance stuff. Just trying to get a little peace of mind before
driving to Arizona in April.
I guess I'll have to save the coolant change, belts and hoses for
another weekend. I'll get the mobile mechanic to help me out. I'll
do the grunt work.
Then I'll need to get the tranny serviced...
It never ends does it? But it's been a lot of fun so far!
Keith
84FC35
> Keith,
mine is, there is
large, square, metal box
mine out in 20-30 minutes.
comes to mechanical help.
him near the 3208
a trained, experienced,
mess with motorhomes
Bird owners in your
WANTS to do it at
the job, on their terms,
change cost $2,400 done
blamed it all on the time it
your belts without
number of hoses you can't
front or our coach at least
section under "3208 Belts
start. Do you know the
he has done
you're aware, of other
to keep track of stuff on
stored and maintained
standpoint but these units
> 84FC35SBWL2
more
air
said he
this
> > valves.
just
dog
> > bottom?
> > Keith
> > 84FC35
> > wrote:
> > > Keith,
> > air filter but you
easier
> > than removing the
short
will
it.
top
> > of the engine to
pull
> > the doghouse to do
to
> > > 84FC35SBWL2
some
> > would be
will
> > check
> > says "dynapak"
> > doghouse
> > > > 84FC35
03-29-2007, 08:56
Since you have an 84, I am guessing you do indeed have the swing
radiator. Are your sure it is not a swing radiator?
Dan prior 83 Fc35
NM
familiar
on
Not
it
no
> problems.
RV
before
> some usage on it.
general
before
I'll
> do the grunt work.
> Keith
> 84FC35
> > Keith,
like
> mine is, there is
let
> him near the 3208
is
to
other
> Bird owners in your
> WANTS to do it at
> your belts without
files
to
items
> he has done
sure
use
was
> > 84FC35SBWL2
> more
> air
> said he
> this
> > > valves.
> just
> dog
> the
> > > bottom?
> > > Keith
> > > 84FC35
> > > wrote:
> > > > Keith,
hoses
> and
> > > air filter but you
> easier
> > > than removing the
> short
> will
> it.
> top
> > > of the engine to
Wanderlodge
> pull
> > > the doghouse to do
> to
this
> > > > 84FC35SBWL2
> some
it
> > > would be
he
> will
> > > check
> > > says "dynapak"
> > > doghouse
> > > > > 84FC35
03-29-2007, 08:56
Dan prior 83 Fc35
NM
familiar
on
Not
it
no
> problems.
RV
before
> some usage on it.
general
before
I'll
> do the grunt work.
> Keith
> 84FC35
> > Keith,
like
> mine is, there is
let
> him near the 3208
is
to
other
> Bird owners in your
> WANTS to do it at
> your belts without
files
to
items
> he has done
sure
use
was
> > 84FC35SBWL2
> more
> air
> said he
> this
> > > valves.
> just
> dog
> the
> > > bottom?
> > > Keith
> > > 84FC35
> > > wrote:
> > > > Keith,
hoses
> and
> > > air filter but you
> easier
> > > than removing the
> short
> will
> it.
> top
> > > of the engine to
Wanderlodge
> pull
> > > the doghouse to do
> to
this
> > > > 84FC35SBWL2
> some
it
> > > would be
he
> will
> > > check
> > > says "dynapak"
> > > doghouse
> > > > > 84FC35
03-29-2007, 09:19
Yep, very sure. I may install one later but right now I just want to
attend to the immediate maintenance issues. Seems like pulling the
radiator is not too much trouble? I need to change the coolant
anyway.
Speaking of coolant --- I've heard mention of coolant conditioners
and checking the pH level? Do you know about that? Some have said
it may be in the form of a filter?
Thanks, Keith
84FC35
--- In WanderlodgeForum@yahoogroups.com, "ac7880"
> Dan prior 83 Fc35
> NM
> familiar
maintained
> on
> Not
bus
been
> it
> no
> > problems.
respected
> RV
> before
belts.
> > some usage on it.
> general
> before
> I'll
> > do the grunt work.
> > Keith
> > 84FC35
> > wrote:
> > > Keith,
> like
> > mine is, there is
a
> let
> > him near the 3208
> is
like
> to
> other
> > Bird owners in your
> and
> > WANTS to do it at
do
adjustment/injector
> > your belts without
> files
place
> to
> items
> > he has done
> sure
> use
> was
wear
regularly.
> > > 84FC35SBWL2
> the
> > more
filter,
> > air
> > said he
out,
> > this
> the
> > > > valves.
I'm
> > just
> > dog
from
> > the
> > > > bottom?
> > > > Keith
> > > > 84FC35
> > > > wrote:
> > > > > Keith,
> hoses
> > and
> > > > air filter but you
> > easier
> > > > than removing the
pretty
> > short
you
> > will
doing
> > it.
> the
> > top
> > > > of the engine to
> Wanderlodge
mechanic
> > pull
> > > > the doghouse to do
hours
> > to
> this
> > > > > 84FC35SBWL2
having
> > some
thought
> it
> > > > would be
> he
> > will
> > > > check
> > > > says "dynapak"
> the
> > > > doghouse
> > > > > > 84FC35
