1992 WB40 Spare wire from front to back?
03-30-2007, 13:10
Is there a spare wire that runs from the front to the back of a 1992
WB40 that I can use for my brake controller?
I have a US Gear D-Celerator brake system that needs one wire to tell
the system in the toad to apply the brake, and another to keep the
battery charged. I am not worried about the one for charging as I can
grab that right off the back of the coach, but did not want to have to
run a wire all the way from the front to the back if a spare already
exists for that.
Michael Brundridge
1992 WB40 - newbie
Georgetown, TX
03-30-2007, 13:35
When I decided to pull a trailer with electric brakes, I noticed that
connections for that function were capped off at the connector. I contacted BB
and was told that an extra wire was not pulled for that purpose. They suggested
that I install a relay to apply the brakes. That did not make sense to me as
the controller relies on inertia to apply power to the trailer. The faster the
bus slows, the more power is applied to the trailer brake system. I ran a 10
guage multi strand wire from the front to the rear under the bus primarily
following existing tubing and wiring. A broken fishing rod makes quick work
through the tough spots. The controller power was obtained from the the lower
load center to be activated when the ignition is turned on. I used a blade fuse
for the system utilizing an open outlet factory installed for accessory
additions. I tied the ground to the primary ground in the lower load center. It
works fine. The job took about 3 hours.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Friday, March 30, 2007 7:10 PM
Subject: [WanderlodgeForum] 1992 WB40 Spare wire from front to back?
exists for that.
Michael Brundridge
1992 WB40 - newbie
Georgetown, TX
03-30-2007, 15:08
Michael, If you don't find a spare wire,
I would think you could run a Bosch type
relay across or in parallel with the brake
light. Then use the common/normaly open
contacts to deliver what ever signal you
wanted, ground or 12 volts. The relay would
isolate the systems.
bob janes, 87fc35, greenville, sc
can
to
> exists for that.
> Michael Brundridge
> 1992 WB40 - newbie
> Georgetown, TX
03-30-2007, 15:40
If it was just the coach brake signal that I needed that would
work. However, the US Gear Unified Tow Brake system has a
controller that sits on the dash of the coach and has a momentim
switch that detects the coach is decelarating. When it detects that
the coach is slowing and that the coach brake has been applied, it
starts to send a signal to the toad brake system to apply the brakes
at the same rate as the coach. So the US Gear is a progressive and
proportional system, so I can not just tie into the brake signal as
the signal from the controller increases in voltage as more brake is
needed to control the brakes in the toad.
I was hoping there was a spare wire or two like in my old coach that
I could use without having to run one. But it is not looking that
way. So guess I get to crawl under the coach this weekend and fix
the genset hoses, and while there run the wire Smile
Michael Brundridge
1992 WB40 - newbie
Georgetown, TX
--- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot"
1992
tell
I
> can
have
> to
already
> > exists for that.
> > Michael Brundridge
> > 1992 WB40 - newbie
> > Georgetown, TX
03-30-2007, 16:01
Leroy,
Thanks for that insight, the US Gear Unified Tow Brake is similar to
a electic brake controller in that the Unified Tow Brake is a
progressive and proportinal braking system with a controller that
sits on the coach dash, and a controller that is located in the toad
and tied to the relay that pulls down on the brake pedal and starts
the add-on vaccum pump for the vaccum assisted brakes. The more it
detects the coach is slowing from the inertia mech. in the
controller, the more signal it sends to the toad. So I will have to
do as you have and run another wire back there.
I have not checked the 7-pin plug at the back of the coach to see if
it supplies 12 volts (believe it is normally pin #4) to keep the
toad battery charged. If not, I will need to put a relay in that is
tied to the coach batteries and activated by a ignition switch
signal to keep from discharging the batteries when the coach is not
running.
Michael Brundridge
1992 WB40 - newbie
Georgetown, TX
that connections for that function were capped off at the
connector. I contacted BB and was told that an extra wire was not
pulled for that purpose. They suggested that I install a relay to
apply the brakes. That did not make sense to me as the controller
relies on inertia to apply power to the trailer. The faster the bus
a 10 guage multi strand wire from the front to the rear under the
bus primarily following existing tubing and wiring. A broken
fishing rod makes quick work through the tough spots. The controller
power was obtained from the the lower load center to be activated
when the ignition is turned on. I used a blade fuse for the system
utilizing an open outlet factory installed for accessory additions.
It works fine. The job took about 3 hours.
> Leroy Eckert
> Niceville, FL
> From: mbrund
back?
1992
tell
I can
have to
already
> exists for that.
> Michael Brundridge
> 1992 WB40 - newbie
> Georgetown, TX
03-30-2007, 16:36
I don't have a battery on the trailer so I don't know what pin number would be
for charging the battery in the toad. I am confidant that you will need to hook
that up also. I may have done an overkill with the 10 gauge wire but my
thinking was it is 40 ft and I only wanted to do it once. <<>>
I ran mine on the street side through the genset cooling compartment, used a few
clamps under the bus and followed the wiring in the rear wheel well to get to
the plug.
Leroy Eckert
Niceville, FL
Sent: Friday, March 30, 2007 10:01 PM
Subject: [WanderlodgeForum] Re: 1992 WB40 Spare wire from front to back?
Leroy,
running.
Michael Brundridge
1992 WB40 - newbie
Georgetown, TX
> Leroy Eckert
> Niceville, FL
> From: mbrund
back?
1992
tell
I can
have to
already
> exists for that.
> Michael Brundridge
> 1992 WB40 - newbie
> Georgetown, TX
04-01-2007, 13:05
Well as luck would have it, I took the front nose panel off where
all the relays and fuses are and I saw two wires that where in
convoluted tubing and has a hand written label that said 'run to
back' I jumped under the coach out back and sure enough there they
where. I ohmed them to verify and sure enough. So some kind sole
before me had already done the hard work Smile So I just need to hook
it to the controller in the coach now.
Also I needed to run 12 volt from the engine batteries to TOAD to
charge the battery. I was having a hard time finding a wire in the
engine bay that was only hot when the ignition was on so I could put
it to a relay so the wire to the toad battery is only hot when the
coach ignition was on. Then I looked up and remembered the rear
coach ignition box, so I removed the screws and determined that the
center post on one side of the front/off/rear switch is hot only
when the front or rear ignition switch is on. So I tapped into that
and ran it to the relay, so now I have a hot AUX going to the toad
only when the ignition is on.
1992
tell
can
have to
already
> exists for that.
> Michael Brundridge
> 1992 WB40 - newbie
> Georgetown, TX
04-01-2007, 13:11
Woops, got to get the hang os signing these post
Michael Brundridge
1992 WB40 - newbie
Georgetown, TX
they
hook
put
that
> 1992
> tell
I
> can
> have to
> already
> > exists for that.
> > Michael Brundridge
> > 1992 WB40 - newbie
> > Georgetown, TX
04-01-2007, 13:56
Michael, the toad needs a ground that is common
to the coach for the aux 12 volts, otherwise no
reference, no charging.
put
that
> 1992
> tell
I
> can
> have to
> already
> > exists for that.
> > Michael Brundridge
> > 1992 WB40 - newbie
> > Georgetown, TX
04-01-2007, 14:38
Bob,
Isn't that what pin one is for on the standard RV plug wiring? To
provide a common ground?
Michael, there are pictures in the "Files" under 'RV Plug Wiring' that
show all the connections if you are in need of such a diagram.
1991 WB40 "Texas Minivan"
> put
> that
> > 1992
> > tell
> the
> I
> > can
> > have to
> > already
> > > exists for that.
> > > Michael Brundridge
> > > 1992 WB40 - newbie
> > > Georgetown, TX
Loading...
