Fan Blades
04-02-2007, 01:52
Fan Blades
I have a customer who has a 1996 PT40. He is looking for the fan blades
for the roof mounted AC unit. I work here at John Bleakley Motor Homes and neither Russell nor George (both from BB) have been able to help him. There is no model number on the AC unit. I told RC (my customer) I would give the forum a shout to see if they could help. Thank You! Ron Fauconniere JBMH for: RC Bryan 1996 PT 40 |
04-02-2007, 06:08
Fan Blades
The factory can not help them out even with the coach serial number?
I would think they could tell him what units where installed at the factory. I have a 1992 WB40 and believe they are 15,000 BTU Dometic Roof AC units if I recall correctly. I can look when I get home this eve, but someone else on the forum probably has that info directly available. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "rfauconn" wrote: > > I have a customer who has a 1996 PT40. He is looking for the fan blades > for the roof mounted AC unit. I work here at John Bleakley Motor Homes > and neither Russell nor George (both from BB) have been able to help > him. There is no model number on the AC unit. I told RC (my customer) > I would give the forum a shout to see if they could help. > > Thank You! > > Ron Fauconniere > JBMH > for: > RC Bryan > 1996 PT 40 > |
04-02-2007, 06:17
Fan Blades
Take the air distribution box down, the model and btu info will be on a tag
attached to the under side of the a/c pan near the electrical connection box. With that info you can go to camping world and they can order them through DTI for you unit. You have 2 fans one is a double squirrel cage and the other is a single. Both are held by set screws, to the shaft. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 06:08 PM 4/2/2007 +0000, you wrote: >The factory can not help them out even with the coach serial number? >I would think they could tell him what units where installed at the >factory. > >I have a 1992 WB40 and believe they are 15,000 BTU Dometic Roof AC >units if I recall correctly. I can look when I get home this eve, but >someone else on the forum probably has that info directly available. > >Michael Brundridge >1992 WB40 >Georgetown, TX > > >--- In WanderlodgeForum@yahoogroups.com, "rfauconn" >wrote: > > > > I have a customer who has a 1996 PT40. He is looking for the fan blades > > for the roof mounted AC unit. I work here at John Bleakley Motor Homes > > and neither Russell nor George (both from BB) have been able to help > > him. There is no model number on the AC unit. I told RC (my customer) > > I would give the forum a shout to see if they could help. > > > > Thank You! > > > > Ron Fauconniere > > JBMH > > for: > > RC Bryan > > 1996 PT 40 > > > > > > > >Yahoo! Groups Links > > > Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma |
