Air Dryer
04-02-2007, 08:21
Air Dryer
Leroy- my coach has a delay in the hiss on the dryer, also. This may be an
indication that the dryer needs a rebuild?? Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-02-2007, 11:33
Air Dryer
It is time for me to do PM on my air dryer. While checking my bus
getting ready for Talladega and two trips thereafter I noticed a 10-15 second hiss after the spitter does its thing. I don't recall hearing it in the past. I have not seen any condensate when draining the tanks and I do not have air problems. And I do not want any. Has anyone retrofitted the air dryer with a newer tech spin on filter type dryer. Do the LXi models have the spin on filter dryer. I am considering this retrofit. It is not very expensive, considering long-term maintenance and where the dryer is located. Thanks, Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville,FL |
04-02-2007, 14:21
Air Dryer
I just updated my 84 with the AD-9 dryer.
Took it to the local Peterbuilt dealership and had them do it. The old dryer is taller and the new one is shorter. They had to modify the air lines (copper) to make it fit. Took about 4 plus hours. Had them replace a leaking left rear leveler also. Good work but expensive. Bob Lawrence 84 PT36 Tacoma, Wa. Has anyone retrofitted the air dryer with a newer tech spin on filter type dryer. > Do the LXi models have the spin on filter dryer. I am considering this > retrofit. It is not very expensive, considering long-term maintenance > and where the dryer is located. > > Thanks, > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville,FL > |
04-02-2007, 16:46
Air Dryer
Thanks Bob, I'll google around and check out that dryer.
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Bob Lawrence To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 02, 2007 9:21 PM Subject: [WanderlodgeForum] Re: Air Dryer I just updated my 84 with the AD-9 dryer. Took it to the local Peterbuilt dealership and had them do it. The old dryer is taller and the new one is shorter. They had to modify the air lines (copper) to make it fit. Took about 4 plus hours. Had them replace a leaking left rear leveler also. Good work but expensive. Bob Lawrence 84 PT36 Tacoma, Wa. Has anyone retrofitted the air dryer with a newer tech spin on filter type dryer. > Do the LXi models have the spin on filter dryer. I am considering this > retrofit. It is not very expensive, considering long-term maintenance > and where the dryer is located. > > Thanks, > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville,FL > [Non-text portions of this message have been removed] |
04-02-2007, 16:49
Air Dryer
It is time to change the filter and valve but I think I want to update to a spin
on filter unit. Thanks, Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 02, 2007 7:21 PM Subject: Re: [WanderlodgeForum] Air Dryer Leroy- my coach has a delay in the hiss on the dryer, also. This may be an indication that the dryer needs a rebuild?? Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
04-03-2007, 00:44
Air Dryer
My air dryer is located where the "spit" catches the wind and blows
back onto the front of my tow car. I rebuilt it about 5,000 miles ago, but would like something that runs cleaner on the purge. I would like to hear about your conversion to the spin on unit when you do it. Pricing, difficulty of the change, etc. Have you picked a brand or dryer yet? A quick search yielded this one: http://www.bendix.com/bendix/downloads/A...rDryer.pdf Dan 94 BB BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > It is time to change the filter and valve but I think I want to update to a spin on filter unit. Thanks, > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > ----- Original Message ----- > From: erniecarpet@... > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 02, 2007 7:21 PM > Subject: Re: [WanderlodgeForum] Air Dryer > > > Leroy- my coach has a delay in the hiss on the dryer, also. This may be an > indication that the dryer needs a rebuild?? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > ************************************** See what's free at http://www.aol.com. > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
04-03-2007, 01:44
Air Dryer
Dan before you decide to change out your air dryer because you are
getting contaminants spitting out of the purge valve, I would advise finding out where the contaminant is coming from by doing some tests on the air compressor. http://www.bendix.com/bendix/downloads/BW1971.pdf tom warner vernon center,ny 1985 PT 40 At 08:44 AM 4/3/2007, you wrote: >My air dryer is located where the "spit" catches the wind and blows >back onto the front of my tow car. I rebuilt it about 5,000 miles >ago, but would like something that runs cleaner on the purge. > >I would like to hear about your conversion to the spin on unit when >you do it. Pricing, difficulty of the change, etc. Have you picked >a brand or dryer yet? >A quick search yielded this one: >http://www.bendix.com/bendix/downloads/A...rDryer.pdf > >Dan >94 BB BMC 37' > >--- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > It is time to change the filter and valve but I think I want to >update to a spin on filter unit. Thanks, > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > > > > > ----- Original Message ----- > > From: erniecarpet@... > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, April 02, 2007 7:21 PM > > Subject: Re: [WanderlodgeForum] Air Dryer > > > > > > Leroy- my coach has a delay in the hiss on the dryer, also. This >may be an > > indication that the dryer needs a rebuild?? > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > > > ************************************** See what's free at >http://www.aol.com. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > >Yahoo! Groups Links > > > |
04-03-2007, 01:58
Air Dryer
I'll let you know. I'm working with Fleet Maintenance in Fort Walton Beach, who
does my heavy maintenance. I have not selected the dryer yet and I may not until the old one is removed. I take it in on the 18th. Thanks for the link. Your dryer must be in the rear down low. With my big body, I cannot get to mine with any kind of ease. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: ac7880 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, April 03, 2007 7:44 AM Subject: [WanderlodgeForum] Re: Air Dryer My air dryer is located where the "spit" catches the wind and blows back onto the front of my tow car. I rebuilt it about 5,000 miles ago, but would like something that runs cleaner on the purge. I would like to hear about your conversion to the spin on unit when you do it. Pricing, difficulty of the change, etc. Have you picked a brand or dryer yet? A quick search yielded this one: http://www.bendix.com/bendix/downloads/A...rDryer.pdf Dan 94 BB BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > It is time to change the filter and valve but I think I want to update to a spin on filter unit. Thanks, > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > ----- Original Message ----- > From: erniecarpet@... > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 02, 2007 7:21 PM > Subject: Re: [WanderlodgeForum] Air Dryer > > > Leroy- my coach has a delay in the hiss on the dryer, also. This may be an > indication that the dryer needs a rebuild?? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > ************************************** See what's free at http://www.aol.com. > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
04-03-2007, 12:10
Air Dryer
Got mine off ebay for $190..good luck on getting one. Retail seems to
be around $270. Bob --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Thanks Bob, I'll google around and check out that dryer. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > ----- Original Message ----- > From: Bob Lawrence > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 02, 2007 9:21 PM > Subject: [WanderlodgeForum] Re: Air Dryer > > > I just updated my 84 with the AD-9 dryer. > Took it to the local Peterbuilt dealership and had them do it. > The old dryer is taller and the new one is shorter. They had to > modify the air lines (copper) to make it fit. Took about 4 plus hours. > Had them replace a leaking left rear leveler also. > Good work but expensive. > Bob Lawrence > 84 PT36 > Tacoma, Wa. > > Has anyone retrofitted the air dryer with a newer tech spin on filter > type dryer. > > Do the LXi models have the spin on filter dryer. I am considering > this > > retrofit. It is not very expensive, considering long-term > maintenance > > and where the dryer is located. > > > > Thanks, > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville,FL > > > > > > > > [Non-text portions of this message have been removed] > |
04-03-2007, 12:44
Air Dryer
Leroy and Tom.
The BMC uses a Haldex (Midland) Pur Air Plus air dryer. It is mounted on the passenger side low at the rear. Several BMC owners have had blowby spitting oil that hits the tow car after several hundred miles. One member has changed to a "Econ" version of the Haldex Midland (model DA33200) based on a Cummins engineers advice, and this has solved the problem. http://autos.groups.yahoo.com/group/Blue...files/Air% 20Dryers/ or http://tinyurl.com/3bb95d details the change etc. I'll read the pdf provided below, but since I rebuilt my Pur Air Plus air dryer recently with NAPA Part number DQ6026 ($123.99), consisting of the desiccant canister, coalescing filter, 175 PSI pressure relief valve, orings, purge valve shield, screws etc, I think the "spit" is just the nature of the beast. Dan 94 BB BMC 37' NM --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Dan before you decide to change out your air dryer because you are > getting contaminants spitting out of the purge valve, I would advise > finding out where the contaminant is coming from by doing some tests > on the air compressor. > http://www.bendix.com/bendix/downloads/BW1971.pdf > > tom warner > vernon center,ny > 1985 PT 40 > > > At 08:44 AM 4/3/2007, you wrote: > >My air dryer is located where the "spit" catches the wind and blows > >back onto the front of my tow car. I rebuilt it about 5,000 miles > >ago, but would like something that runs cleaner on the purge. > > > >I would like to hear about your conversion to the spin on unit when > >you do it. Pricing, difficulty of the change, etc. Have you picked > >a brand or dryer yet? > >A quick search yielded this one: > >http://www.bendix.com/bendix/downloads/A...rDryer.pdf > > > >Dan > >94 BB BMC 37' > > > >--- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > It is time to change the filter and valve but I think I want to > >update to a spin on filter unit. Thanks, > > > > > > Leroy Eckert > > > 1990 WB-40"Smoke N Mirrors" > > > Niceville, FL > > > > > > > > > ----- Original Message ----- > > > From: erniecarpet@ > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Monday, April 02, 2007 7:21 PM > > > Subject: Re: [WanderlodgeForum] Air Dryer > > > > > > > > > Leroy- my coach has a delay in the hiss on the dryer, also. This > >may be an > > > indication that the dryer needs a rebuild?? > > > > > > Ernie Ekberg > > > 83PT40 > > > Livingston, Mt > > > > > > ************************************** See what's free at > >http://www.aol.com. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > |
