How to test grounds
04-02-2007, 16:18
How to test grounds
a simple test to check for bad connections "Drop Test"
Take a voltmeter connect one end to each end of the cable If it's a
ground, connect one end to the ground post of the battery, and the
other end to a good engine ground, crank the engine and watch the
meter, Any voltage that can't go through the cable due to high
resistance (corroded cables, lose connections), will go through the
meter. If you have more than 1/2 of a volt showing on the
meter, you have a bad connection. Good Luck
by
Jimmy Harvie
Above is a cut and paste from a thread of a different name. Thanks
Jimmy
GregoryO'Connor
94ptRomolandCa
