Newbie with warning buzzer sounding
05-01-2005, 08:35
Well I am now officially a newbie since I took delivery on the bus I
bought back in January today (the person I bought the bus from stored
it for me until Spring). Everything seems fine except for a warning
buzzer that sounded for about 30-45 minutes in the dash area. The
previous owner said that the buzzer was sounding due to a discharged
genset battery. The genset worked fine with a jump but we did not run
it long enough for it to recharge. He said the buzzer would go off as
soon as the battery was fully discharged but in the meantime it would
sound the buzzer. All systems seemed fine so I drove it home with the
annoying buzzer buzzing. It finally went off except for a few
intermitant buzzes. Can anyone confirm the previous owner contention
regarding the genset battery? Oil temp and pressure were in the
normal range, engine temp was fine, the air pressure was about 125
PSI, the transmission temp was on the low side, just off the peg. I
hope I did not do the wrong thing by driving it.
Steve Meach
85 FC35
Paw Paw, MI
05-01-2005, 11:45
If you got a buzzer when hitting bumps, likely a leveling jack is
hanging and the jack warning buzzer will go off when it bounces.
There is also the headlamp warning buzzer, key-off/lights-on,
sometimes a low-voltage from the ignition switch will cause this
occasionally with the lights on.
Next would be the low-air-pressure buzzer which I think you
mentioned, and overhead the beepers for water-in-racor and shoreline.
I think this covers it?
- Jeff Miller
http://www.wanderlodge.net
http://www.millercoachworks.com
--- In WanderlodgeForum@yahoogroups.com, "SFMEACH" <sfmeach@y...>
I
stored
warning
discharged
run
as
would
contention
I
> Steve Meach
> 85 FC35
> Paw Paw, MI
05-01-2005, 12:01
Steve,
Congrats on your new coach.
There are a few reasons for the buzzer, I don't believe any are
related to the generator battery. With an old bird though, you never
know what's been changed around or added.
An engine alarm buzzer (and light NOT from the same signal wire)
A low air buzzer (and light which come off the same sender)
A headlight alert buzzer (and light from the same sender)
A leveling jacks not UP alert (and lights if you have the master
switch on - not sure how they're related)
If you have no light (assuming all lights work, which you can check
by activating the associated system. The engine alarm should come on
with the engine off and key on, may take a few moments though.) I
would guess you have a leveling jack not quite all the way up or a
misaligned or bad mercury switch on it. From your post, I'm assuming
you have no associated light.
The buzzers are all behind the drivers headlight panel. You can
always open the panel and see which one is on, note the wire color,
and post again to have it checked on a schematic for you. You can
also change out these annoying buzzers for some friendlier chimes
from your local NAPA store.
One last buzzer is the Racor water in fuel alarm and light on the
overhead panel. (I think it's on the overhead in your '85)
Gary Miller
83 FC 33
Wauwatosa, WI
I
stored
warning
discharged
run
as
would
contention
I
> Steve Meach
> 85 FC35
> Paw Paw, MI
05-01-2005, 12:17
How could I have forgotten about the engine alert buzzer? Oh yes,
they're often disconnected.
The low-coolant sensor is the most common cause of this one, screwed
into the upper tank of the radiator on the curbside rear. Often
disconnected. Check coolant level. It might have risen enough when
the engine was warm to turn off this buzzer. In this case you might
also need to replace the engine alert light.
- Jeff Miller
--- In WanderlodgeForum@yahoogroups.com, "Gary Miller"
> Steve,
never
> switch on - not sure how they're related)<<snip>>
05-01-2005, 12:20
Steve, Congratulations on your new coach. We also have a FC and love
it...Between Jeff and Gary you prolly got the most accumulative
knowledge of BB out there today.. They can put you on the money
with "issues" that crop up. Did the engine coolant light come on when
you got the buzzer? If you have low coolant but engine temp ok
sometimes when going over bumps it will sound..I know from
experiance.. you might want to check the coolant level just a
thought.
Scott
86FC35
Murrells Inlet SC "right next to heaven"
> Steve,
never
on
assuming
> Gary Miller
> 83 FC 33
> Wauwatosa, WI
bus
> I
> stored
> warning
The
> discharged
not
> run
off
> as
> would
with
> the
> contention
125
peg.
> I
> > Steve Meach
> > 85 FC35
> > Paw Paw, MI
05-01-2005, 12:30
Thanks Jeff, Gary and Scott for the tips. I will check the leveling
jacks and sensors as well as the coolant level. Both sound like
likely causes. I am glad that it probably was nothing that was
serious that could have caused damage to the driveline.
Steve Meach
85FC35
Paw Paw, MI
--- In WanderlodgeForum@yahoogroups.com, "Scott"
love
when
> thought.
> Scott
> 86FC35
> > Steve,
> never
check
come
> on
I
a
> assuming
color,
can
chimes
> > Gary Miller
> > 83 FC 33
> > Wauwatosa, WI
<sfmeach@y...>
> bus
> > I
> > stored
> > warning
> The
> > discharged
> not
> > run
go
> off
> > as
it
> > would
> with
> > the
> > contention
> 125
> peg.
> > I
> > > Steve Meach
> > > 85 FC35
> > > Paw Paw, MI
05-01-2005, 12:44
Maybe???...I had a frequent beep (not buzzer) in our PT38 and discovered
it coming from the radar detector.
Curt Sprenger ‘87PT38, Anaheim, Calif.
05-01-2005, 21:52
Steve ,My check engine light & buzzer came on intermitanly & the gauges were
good. I took the old sensor unit out of the rad & took it to a BlueBird
garage near me & they matched it up with a one. The new one was grounded & the
old one wasn't. The guy in the parts called their shop foreman & he said it
didn't need to be grounded if the rad was grounded. Sense the new one had a
ground screw on it I went ahead & grounded it. That was all it needed. Works
fine.
Don
89SP 36'
Butler, PA
05-01-2005, 23:44
Steve,
One more point. My buzzer and light came on with temps. Oil and Water
OK.
Benny at BB indicated that the sensor on the top left side of the
radiator had to be grounded. In my case the wire, which you can reach
and feel from the doghouse, had been rubbing against the AC pully and
broke.
Kurt
83FC35 in NH(again 28° this morning)
leveling
> Steve Meach
> 85FC35
> Paw Paw, MI
> love
> when
> > thought.
> > Scott
> > 86FC35
> > wrote:
> > > Steve,
> > never
master
> check
> come
> > on
> I
or
> a
> > assuming
can
> color,
> can
> chimes
> the
> > > Gary Miller
> > > 83 FC 33
> > > Wauwatosa, WI
> <sfmeach@y...>
> > bus
> > > I
from
> > > stored
> > > warning
area.
> > The
> > > discharged
did
> > not
> > > run
> go
> > off
> > > as
> it
> > > would
> > with
> > > the
few
> > > contention
> the
about
> > 125
> > peg.
> > > I
> > > > Steve Meach
> > > > 85 FC35
> > > > Paw Paw, MI
