Painting where clearcoat has peeled
04-06-2007, 07:44
Blue Thunder has peeling clearcoat all along the upper edges. I'm not likely to
spring for a full paint job, so my choices were to do nothing, or attempt some spot repair. The back cap was the worst, depending on angle and lighting. I tried some test spots of fresh clear-coat, but the colors did not match, so I decided to paint. Over the past couple of days, because we had good weather for it, I did the largest area which is blue. Clearcoat was removed with plastic scraper and 220-grit sandpaper, then everything was sanded with 400-grit. I used Dupont Nason 2K Ful-Thane urethane, which does not need a clearcoat. Saves a lot of work and about half the cost. The results are not professional, but more than adequate especially for an area 11 feet off the ground where nobody is going to be looking at it closely. I've put up a page with before/during/after pictures at http://www.arcatapet.net/travel/painting.cfm I probably won't get to the rest of the blue, or the red and gold portions, until sometime this summer. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
04-06-2007, 08:42
From: Don Bradner To: wanderlodgeforum@yahoogroups.com Sent: Friday, April 06, 2007 2:44 PM Subject: [WanderlodgeForum] Painting where clearcoat has peeled Don Looks good to me. Bob Loomas @hughes.net Blue Thunder has peeling clearcoat all along the upper edges. I'm not likely to spring for a full paint job, so my choices were to do nothing, or attempt some spot repair. The back cap was the worst, depending on angle and lighting. I tried some test spots of fresh clear-coat, but the colors did not match, so I decided to paint. Over the past couple of days, because we had good weather for it, I did the largest area which is blue. Clearcoat was removed with plastic scraper and 220-grit sandpaper, then everything was sanded with 400-grit. I used Dupont Nason 2K Ful-Thane urethane, which does not need a clearcoat. Saves a lot of work and about half the cost. The results are not professional, but more than adequate especially for an area 11 feet off the ground where nobody is going to be looking at it closely. I've put up a page with before/during/after pictures at http://www.arcatapet.net/travel/painting.cfm I probably won't get to the rest of the blue, or the red and gold portions, until sometime this summer. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA [Non-text portions of this message have been removed] |
04-06-2007, 09:11
Don, Good looking bus. Do you have a closer picture of the finished paint job,
as a little further out than the first pic., but closer than the last finished pic. I have some of the same paint problems, along with some peeling. Am looking for a (quick and cheep), way to get it to hold until next year. Have to many other issures to deal with at present. BTY, were you ever in the USAF? G.Burke 77FC 31 Charlotte ----- Original Message ----- From: Don Bradner To: wanderlodgeforum@yahoogroups.com Sent: Friday, April 06, 2007 3:44 PM Subject: [WanderlodgeForum] Painting where clearcoat has peeled Blue Thunder has peeling clearcoat all along the upper edges. I'm not likely to spring for a full paint job, so my choices were to do nothing, or attempt some spot repair. The back cap was the worst, depending on angle and lighting. I tried some test spots of fresh clear-coat, but the colors did not match, so I decided to paint. Over the past couple of days, because we had good weather for it, I did the largest area which is blue. Clearcoat was removed with plastic scraper and 220-grit sandpaper, then everything was sanded with 400-grit. I used Dupont Nason 2K Ful-Thane urethane, which does not need a clearcoat. Saves a lot of work and about half the cost. The results are not professional, but more than adequate especially for an area 11 feet off the ground where nobody is going to be looking at it closely. I've put up a page with before/during/after pictures at http://www.arcatapet.net/travel/painting.cfm I probably won't get to the rest of the blue, or the red and gold portions, until sometime this summer. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA [Non-text portions of this message have been removed] |
04-06-2007, 14:58
I'll see what I can do tomorrow. The first picture doesn't show how bad the
peeling was, and I fear a closeup may make my paint job look worse than it is, but we'll see. On 4/6/2007 at 5:11 PM gnburke@... wrote: >Don, Good looking bus. Do you have a closer picture of the finished paint >job, as a little further out than the first pic., but closer than the last >finished pic. I have some of the same paint problems, along with some >peeling. Am looking for a (quick and cheep), way to get it to hold until >next year. Have to many other issures to deal with at present. BTY, were >you ever in the USAF? G.Burke 77FC 31 Charlotte > ----- Original Message ----- > From: Don Bradner > To: wanderlodgeforum@yahoogroups.com > Sent: Friday, April 06, 2007 3:44 PM > Subject: [WanderlodgeForum] Painting where clearcoat has peeled > > > Blue Thunder has peeling clearcoat all along the upper edges. I'm not >likely to spring for a full paint job, so my choices were to do nothing, >or attempt some spot repair. > > The back cap was the worst, depending on angle and lighting. I tried >some test spots of fresh clear-coat, but the colors did not match, so I >decided to paint. > > Over the past couple of days, because we had good weather for it, I did >the largest area which is blue. Clearcoat was removed with plastic scraper >and 220-grit sandpaper, then everything was sanded with 400-grit. > > I used Dupont Nason 2K Ful-Thane urethane, which does not need a >clearcoat. Saves a lot of work and about half the cost. The results are >not professional, but more than adequate especially for an area 11 feet >off the ground where nobody is going to be looking at it closely. > > I've put up a page with before/during/after pictures at >http://www.arcatapet.net/travel/painting.cfm > > I probably won't get to the rest of the blue, or the red and gold >portions, until sometime this summer. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
04-06-2007, 16:23
Don, It looks good! some times you can clean the 'color coat' with
clay then re clearcoat. often the clearcoat failed because the colorcoat degraded. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Blue Thunder has peeling clearcoat all along the upper edges. I'm not likely to spring for a full paint job, so my choices were to do nothing, or attempt some spot repair. > > The back cap was the worst, depending on angle and lighting. I tried some test spots of fresh clear-coat, but the colors did not match, so I decided to paint. > > Over the past couple of days, because we had good weather for it, I did the largest area which is blue. Clearcoat was removed with plastic scraper and 220-grit sandpaper, then everything was sanded with 400-grit. > > I used Dupont Nason 2K Ful-Thane urethane, which does not need a clearcoat. Saves a lot of work and about half the cost. The results are not professional, but more than adequate especially for an area 11 feet off the ground where nobody is going to be looking at it closely. > > I've put up a page with before/during/after pictures at http://www.arcatapet.net/travel/painting.cfm > > I probably won't get to the rest of the blue, or the red and gold portions, until sometime this summer. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > |
04-06-2007, 18:10
Nope, army. 66-69, mostly in Iran and Ethiopia.
On 4/6/2007 at 5:11 PM gnburke@... wrote: >BTY, were >you ever in the USAF? G.Burke 77FC 31 Charlotte Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
04-07-2007, 07:01
I added a new picture at the bottom that approximates the view in the original
peeling picture. That original picture was taken by the inspector I hired to look at the Bird before I had seen it. It rained this morning, so I had to wait for it to dry some. There is still water pooled below the marker lights in the picture. On 4/6/2007 at 5:11 PM gnburke@... wrote: >Don, Good looking bus. Do you have a closer picture of the finished paint >job, as a little further out than the first pic., but closer than the last >finished pic. I have some of the same paint problems, along with some >peeling. Am looking for a (quick and cheep), way to get it to hold until >next year. Have to many other issures to deal with at present. BTY, were >you ever in the USAF? G.Burke 77FC 31 Charlotte > ----- Original Message ----- > From: Don Bradner > To: wanderlodgeforum@yahoogroups.com > Sent: Friday, April 06, 2007 3:44 PM > Subject: [WanderlodgeForum] Painting where clearcoat has peeled > > > Blue Thunder has peeling clearcoat all along the upper edges. I'm not >likely to spring for a full paint job, so my choices were to do nothing, >or attempt some spot repair. > > The back cap was the worst, depending on angle and lighting. I tried >some test spots of fresh clear-coat, but the colors did not match, so I >decided to paint. > > Over the past couple of days, because we had good weather for it, I did >the largest area which is blue. Clearcoat was removed with plastic scraper >and 220-grit sandpaper, then everything was sanded with 400-grit. > > I used Dupont Nason 2K Ful-Thane urethane, which does not need a >clearcoat. Saves a lot of work and about half the cost. The results are >not professional, but more than adequate especially for an area 11 feet >off the ground where nobody is going to be looking at it closely. > > I've put up a page with before/during/after pictures at >http://www.arcatapet.net/travel/painting.cfm > > I probably won't get to the rest of the blue, or the red and gold >portions, until sometime this summer. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
04-07-2007, 13:31
Base coat, clear coat is not really difficult to use. My bus got the crap beat
out of it in an SPI gail. I have repainted it and no one could ever find the area if not previously known. Your paint codes should be on the frame behind the engine above the bumper. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Saturday, April 07, 2007 2:01 PM Subject: Re: [WanderlodgeForum] Painting where clearcoat has peeled I added a new picture at the bottom that approximates the view in the original peeling picture. That original picture was taken by the inspector I hired to look at the Bird before I had seen it. It rained this morning, so I had to wait for it to dry some. There is still water pooled below the marker lights in the picture. On 4/6/2007 at 5:11 PM gnburke@... wrote: >Don, Good looking bus. Do you have a closer picture of the finished paint >job, as a little further out than the first pic., but closer than the last >finished pic. I have some of the same paint problems, along with some >peeling. Am looking for a (quick and cheep), way to get it to hold until >next year. Have to many other issures to deal with at present. BTY, were >you ever in the USAF? G.Burke 77FC 31 Charlotte > ----- Original Message ----- > From: Don Bradner > To: wanderlodgeforum@yahoogroups.com > Sent: Friday, April 06, 2007 3:44 PM > Subject: [WanderlodgeForum] Painting where clearcoat has peeled > > > Blue Thunder has peeling clearcoat all along the upper edges. I'm not >likely to spring for a full paint job, so my choices were to do nothing, >or attempt some spot repair. > > The back cap was the worst, depending on angle and lighting. I tried >some test spots of fresh clear-coat, but the colors did not match, so I >decided to paint. > > Over the past couple of days, because we had good weather for it, I did >the largest area which is blue. Clearcoat was removed with plastic scraper >and 220-grit sandpaper, then everything was sanded with 400-grit. > > I used Dupont Nason 2K Ful-Thane urethane, which does not need a >clearcoat. Saves a lot of work and about half the cost. The results are >not professional, but more than adequate especially for an area 11 feet >off the ground where nobody is going to be looking at it closely. > > I've put up a page with before/during/after pictures at >http://www.arcatapet.net/travel/painting.cfm > > I probably won't get to the rest of the blue, or the red and gold >portions, until sometime this summer. > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > Don Bradner 90 PT40 "Blue Thunder" Eureka, CA [Non-text portions of this message have been removed] |
04-07-2007, 17:22
Didn't think that you were him, but I remember a fellow named Don from Eureka,
that I was stationed with when in Mass. Couldn't remember his last name, but I will be 60 in August, and he was in our age group. Where did it go, 1967 to 1971 was only 4 yrs., but seems like an eternity ago. Good Luck with your project. George Burke 77FC31 Charlotte ----- Original Message ----- From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Saturday, April 07, 2007 2:10 AM Subject: Re: [WanderlodgeForum] Painting where clearcoat has peeled Nope, army. 66-69, mostly in Iran and Ethiopia. On 4/6/2007 at 5:11 PM gnburke@... wrote: >BTY, were >you ever in the USAF? G.Burke 77FC 31 Charlotte Don Bradner 90 PT40 "Blue Thunder" Eureka, CA [Non-text portions of this message have been removed] |
04-08-2007, 02:37
Great discussion! I am planning to do some touch up and paint a new
gen door panel(don't ask) on my 83' FC35. It's the brown / tan combo outside. Anybody know where the paint codes are on it or what colors those are? If not I will just pull something small off to have it matched. I'm guessing these older birds don't have clearcoat on them as I have never seen one pealing. I'm sure I can get decent results with lots of patience and a little elbow grease. M Thomas Eastham Houston, TX 83' FC35 84' FC33 parting out [Non-text portions of this message have been removed] |
