Microphor toilet and variable speed pump
04-10-2007, 12:57
A few weeks ago, I installed (as did several others) a variable speed
ShurFlo water pump to replace the (leaking) dual water pumps in my coach. So far, I've been well satisfied ... but an unexpected issue has come to light. We've found that the higher water pressure available from the pump (65 lbs.) makes washing dishes and taking showers more pleasant ... so even when parked where shore water is available, we've tended to use the pump. Recently, we noticed a problem with the Microphor toilet ... it was not refilling after flushing and sometimes it would not flush properly -- or you'd need to hold down the handle a very long time for it to function as expected. After reviewing the troubleshooting section of the Microphor documentation, I saw that the problems I was having was due to "excess" water pressure. The Microphor is designed to operate with 30 to 50 lbs of water pressure. If higher water pressure is present, the very problems we were having may occur. Others who have upgraded to a variable may want to take this into consideration. Microphor suggests inserting a pressure limiter in the water supply line to solve/avoid problems. (I just turned off the pump -- we'll only turn it on for dishes and showers, now.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... |
04-10-2007, 14:49
Pete,
Thank you for the posting. Do you have the air operated Microphor toilet in you coach? Interesting...I was under the bed and found the water line strainer to be cracked on the top, and dripping only a slight trace of water on the floor. I change out the strainer and now the original water pump works a lot better. I'm assuming the cracked strainer was sucking air. Can't wait to install the variable speed ShurFlo water pump. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Pete Masterson wrote: > A few weeks ago, I installed (as did several others) a variable speed > ShurFlo water pump to replace the (leaking) dual water pumps in my > coach. So far, I've been well satisfied ... but an unexpected issue > has come to light. We've found that the higher water pressure > available from the pump (65 lbs.) makes washing dishes and taking > showers more pleasant ... so even when parked where shore water is > available, we've tended to use the pump. > > Recently, we noticed a problem with the Microphor toilet ... it was > not refilling after flushing and sometimes it would not flush > properly -- or you'd need to hold down the handle a very long time > for it to function as expected. After reviewing the troubleshooting > section of the Microphor documentation, I saw that the problems I was > having was due to "excess" water pressure. The Microphor is designed > to operate with 30 to 50 lbs of water pressure. If higher water > pressure is present, the very problems we were having may occur. > > Others who have upgraded to a variable may want to take this into > consideration. Microphor suggests inserting a pressure limiter in the > water supply line to solve/avoid problems. (I just turned off the > pump -- we'll only turn it on for dishes and showers, now.) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > |
04-11-2007, 14:37
Yes, I have the air-operated Microphor (with a small 12v compressor
in the basement compartment nearby). It would be worthwhile to check the Microphor website for the installation/troubleshooting manual for your model. I may get around to installing a pressure controller for the water supply to the toilet. I actually have a nice one in my 'junk' box from a long-dead drip irrigation system I once had. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 Currently in Golden Colorado where we're getting on the road early tomorrow heading south to get out of the way of another $@$!% snow storm! aeonix1@... On Apr 10, 2007, at 7:49 PM, Curt Sprenger wrote: > Pete, > > Thank you for the posting. Do you have the air operated Microphor > toilet > in you coach? > > Interesting...I was under the bed and found the water line strainer to > be cracked on the top, and dripping only a slight trace of water on > the > floor. I change out the strainer and now the original water pump > works a > lot better. I'm assuming the cracked strainer was sucking air. Can't > wait to install the variable speed ShurFlo water pump. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Pete Masterson wrote: > >> A few weeks ago, I installed (as did several others) a variable speed >> ShurFlo water pump to replace the (leaking) dual water pumps in my >> coach. So far, I've been well satisfied ... but an unexpected issue >> has come to light. We've found that the higher water pressure >> available from the pump (65 lbs.) makes washing dishes and taking >> showers more pleasant ... so even when parked where shore water is >> available, we've tended to use the pump. >> >> Recently, we noticed a problem with the Microphor toilet ... it was >> not refilling after flushing and sometimes it would not flush >> properly -- or you'd need to hold down the handle a very long time >> for it to function as expected. After reviewing the troubleshooting >> section of the Microphor documentation, I saw that the problems I was >> having was due to "excess" water pressure. The Microphor is designed >> to operate with 30 to 50 lbs of water pressure. If higher water >> pressure is present, the very problems we were having may occur. >> >> Others who have upgraded to a variable may want to take this into >> consideration. Microphor suggests inserting a pressure limiter in the >> water supply line to solve/avoid problems. (I just turned off the >> pump -- we'll only turn it on for dishes and showers, now.) >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> El Sobrante CA >> aeonix1@... >> >> > > > > > Yahoo! Groups Links > > > |
04-12-2007, 04:29
Along with air regulators for the Microphor we all should put them on the air
line to the dump valves. According to Randy it would extend the valves life by not pushing so hard when running with the air pressure is over 100 lbs. Just another project I haven't gotten around too yet. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 11, 2007 7:37 PM Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump Yes, I have the air-operated Microphor (with a small 12v compressor in the basement compartment nearby). It would be worthwhile to check the Microphor website for the installation/troubleshooting manual for your model. I may get around to installing a pressure controller for the water supply to the toilet. I actually have a nice one in my 'junk' box from a long-dead drip irrigation system I once had. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 Currently in Golden Colorado where we're getting on the road early tomorrow heading south to get out of the way of another $@$!% snow storm! aeonix1@... On Apr 10, 2007, at 7:49 PM, Curt Sprenger wrote: > Pete, > > Thank you for the posting. Do you have the air operated Microphor > toilet > in you coach? > > Interesting...I was under the bed and found the water line strainer to > be cracked on the top, and dripping only a slight trace of water on > the > floor. I change out the strainer and now the original water pump > works a > lot better. I'm assuming the cracked strainer was sucking air. Can't > wait to install the variable speed ShurFlo water pump. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Pete Masterson wrote: > >> A few weeks ago, I installed (as did several others) a variable speed >> ShurFlo water pump to replace the (leaking) dual water pumps in my >> coach. So far, I've been well satisfied ... but an unexpected issue >> has come to light. We've found that the higher water pressure >> available from the pump (65 lbs.) makes washing dishes and taking >> showers more pleasant ... so even when parked where shore water is >> available, we've tended to use the pump. >> >> Recently, we noticed a problem with the Microphor toilet ... it was >> not refilling after flushing and sometimes it would not flush >> properly -- or you'd need to hold down the handle a very long time >> for it to function as expected. After reviewing the troubleshooting >> section of the Microphor documentation, I saw that the problems I was >> having was due to "excess" water pressure. The Microphor is designed >> to operate with 30 to 50 lbs of water pressure. If higher water >> pressure is present, the very problems we were having may occur. >> >> Others who have upgraded to a variable may want to take this into >> consideration. Microphor suggests inserting a pressure limiter in the >> water supply line to solve/avoid problems. (I just turned off the >> pump -- we'll only turn it on for dishes and showers, now.) >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> El Sobrante CA >> aeonix1@... >> >> > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
04-12-2007, 15:20
Dick,
Right you are. Our air dump valves are installed with the air regulators per Randy. No problems so far. The black tank stinks...anything to do with the air valves...Ha!!! Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Richard Hayden wrote: > Along with air regulators for the Microphor we all should put them on > the air line to the dump valves. According to Randy it would extend > the valves life by not pushing so hard when running with the air > pressure is over 100 lbs. Just another project I haven't gotten around > too yet. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, April 11, 2007 7:37 PM > Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump > > Yes, I have the air-operated Microphor (with a small 12v compressor > in the basement compartment nearby). It would be worthwhile to check > the Microphor website for the installation/troubleshooting manual for > your model. I may get around to installing a pressure controller for > the water supply to the toilet. I actually have a nice one in my > 'junk' box from a long-dead drip irrigation system I once had. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > Currently in Golden Colorado where we're getting on the road early > tomorrow heading south to get out of the way of another $@$!% snow > storm! > aeonix1@... > > On Apr 10, 2007, at 7:49 PM, Curt Sprenger wrote: > > > Pete, > > > > Thank you for the posting. Do you have the air operated Microphor > > toilet > > in you coach? > > > > Interesting...I was under the bed and found the water line strainer to > > be cracked on the top, and dripping only a slight trace of water on > > the > > floor. I change out the strainer and now the original water pump > > works a > > lot better. I'm assuming the cracked strainer was sucking air. Can't > > wait to install the variable speed ShurFlo water pump. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > Pete Masterson wrote: > > > >> A few weeks ago, I installed (as did several others) a variable speed > >> ShurFlo water pump to replace the (leaking) dual water pumps in my > >> coach. So far, I've been well satisfied ... but an unexpected issue > >> has come to light. We've found that the higher water pressure > >> available from the pump (65 lbs.) makes washing dishes and taking > >> showers more pleasant ... so even when parked where shore water is > >> available, we've tended to use the pump. > >> > >> Recently, we noticed a problem with the Microphor toilet ... it was > >> not refilling after flushing and sometimes it would not flush > >> properly -- or you'd need to hold down the handle a very long time > >> for it to function as expected. After reviewing the troubleshooting > >> section of the Microphor documentation, I saw that the problems I was > >> having was due to "excess" water pressure. The Microphor is designed > >> to operate with 30 to 50 lbs of water pressure. If higher water > >> pressure is present, the very problems we were having may occur. > >> > >> Others who have upgraded to a variable may want to take this into > >> consideration. Microphor suggests inserting a pressure limiter in the > >> water supply line to solve/avoid problems. (I just turned off the > >> pump -- we'll only turn it on for dishes and showers, now.) > >> > >> Pete Masterson > >> '95 Blue Bird Wanderlodge WBDA 42 > >> El Sobrante CA > >> aeonix1@... > >> > >> > > > > > > > > > > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed] > > |
04-12-2007, 17:27
I don't think so, Curt. I use that white stuff I get at Quartzite and it works
great, no odor. I think it's called "Happy Camper". What did you use for air regulators? And, did you put them in? Where? Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Thursday, April 12, 2007 8:20 PM Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump Dick, Right you are. Our air dump valves are installed with the air regulators per Randy. No problems so far. The black tank stinks...anything to do with the air valves...Ha!!! Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Richard Hayden wrote: > Along with air regulators for the Microphor we all should put them on > the air line to the dump valves. According to Randy it would extend > the valves life by not pushing so hard when running with the air > pressure is over 100 lbs. Just another project I haven't gotten around > too yet. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, April 11, 2007 7:37 PM > Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump > > Yes, I have the air-operated Microphor (with a small 12v compressor > in the basement compartment nearby). It would be worthwhile to check > the Microphor website for the installation/troubleshooting manual for > your model. I may get around to installing a pressure controller for > the water supply to the toilet. I actually have a nice one in my > 'junk' box from a long-dead drip irrigation system I once had. > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > Currently in Golden Colorado where we're getting on the road early > tomorrow heading south to get out of the way of another $@$!% snow > storm! > aeonix1@... > > > On Apr 10, 2007, at 7:49 PM, Curt Sprenger wrote: > > > Pete, > > > > Thank you for the posting. Do you have the air operated Microphor > > toilet > > in you coach? > > > > Interesting...I was under the bed and found the water line strainer to > > be cracked on the top, and dripping only a slight trace of water on > > the > > floor. I change out the strainer and now the original water pump > > works a > > lot better. I'm assuming the cracked strainer was sucking air. Can't > > wait to install the variable speed ShurFlo water pump. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > > > Pete Masterson wrote: > > > >> A few weeks ago, I installed (as did several others) a variable speed > >> ShurFlo water pump to replace the (leaking) dual water pumps in my > >> coach. So far, I've been well satisfied ... but an unexpected issue > >> has come to light. We've found that the higher water pressure > >> available from the pump (65 lbs.) makes washing dishes and taking > >> showers more pleasant ... so even when parked where shore water is > >> available, we've tended to use the pump. > >> > >> Recently, we noticed a problem with the Microphor toilet ... it was > >> not refilling after flushing and sometimes it would not flush > >> properly -- or you'd need to hold down the handle a very long time > >> for it to function as expected. After reviewing the troubleshooting > >> section of the Microphor documentation, I saw that the problems I was > >> having was due to "excess" water pressure. The Microphor is designed > >> to operate with 30 to 50 lbs of water pressure. If higher water > >> pressure is present, the very problems we were having may occur. > >> > >> Others who have upgraded to a variable may want to take this into > >> consideration. Microphor suggests inserting a pressure limiter in the > >> water supply line to solve/avoid problems. (I just turned off the > >> pump -- we'll only turn it on for dishes and showers, now.) > >> > >> Pete Masterson > >> '95 Blue Bird Wanderlodge WBDA 42 > >> El Sobrante CA > >> aeonix1@... > > >> > >> > > > > > > > > > > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
04-13-2007, 00:53
My original post was about _water_ pressure. But the air pressure
issue is also an excellent point. As it happens, I have a Microphor 12v compressor that's independent from the coach air system. It's limited to 90 psi. I plan to move my dump valves over to the Microphor compressor when time allows as it will eliminate needing to 'air up' to dump. I notice that the air-dump valves seem to work ok with about 70 psi but are a little sluggish with less -- but I was in a very cold place when I was taking note of the pressures (I'd pumped up the coach with an external compressor since it wasn't worth the difficulty in starting the engine in 25 degree weather...) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 Currently in Amarillo TX -- heading south out of winter's last gasp... aeonix1@... On Apr 12, 2007, at 11:29 AM, Richard Hayden wrote: > Along with air regulators for the Microphor we all should put them > on the air line to the dump valves. According to Randy it would > extend the valves life by not pushing so hard when running with the > air pressure is over 100 lbs. Just another project I haven't > gotten around too yet. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Pete Masterson > To: > WanderlodgeForum@yahoogroups.com > Sent: Wednesday, April 11, 2007 7:37 PM > Subject: Re: [WanderlodgeForum] Microphor toilet and variable > speed pump > > > Yes, I have the air-operated Microphor (with a small 12v compressor > in the basement compartment nearby). It would be worthwhile to check > the Microphor website for the installation/troubleshooting manual > for > your model. <snip> |
04-13-2007, 02:34
Dick,
I sent you photos showing the air regulators installed. I zip tied them in place. Adjust them until the dump valve will open/close. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Richard Hayden wrote: > I don't think so, Curt. I use that white stuff I get at Quartzite and > it works great, no odor. I think it's called "Happy Camper". What did > you use for air regulators? And, did you put them in? Where? > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, April 12, 2007 8:20 PM > Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump > > Dick, > Right you are. Our air dump valves are installed with the air regulators > per Randy. No problems so far. The black tank stinks...anything to do > with the air valves...Ha!!! > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Richard Hayden wrote: > > > Along with air regulators for the Microphor we all should put them on > > the air line to the dump valves. According to Randy it would extend > > the valves life by not pushing so hard when running with the air > > pressure is over 100 lbs. Just another project I haven't gotten around > > too yet. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > ----- Original Message ----- > > From: Pete Masterson > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Sent: Wednesday, April 11, 2007 7:37 PM > > Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump > > > > Yes, I have the air-operated Microphor (with a small 12v compressor > > in the basement compartment nearby). It would be worthwhile to check > > the Microphor website for the installation/troubleshooting manual for > > your model. I may get around to installing a pressure controller for > > the water supply to the toilet. I actually have a nice one in my > > 'junk' box from a long-dead drip irrigation system I once had. > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > Currently in Golden Colorado where we're getting on the road early > > tomorrow heading south to get out of the way of another $@$!% snow > > storm! > > aeonix1@... > > > > > > > On Apr 10, 2007, at 7:49 PM, Curt Sprenger wrote: > > > > > Pete, > > > > > > Thank you for the posting. Do you have the air operated Microphor > > > toilet > > > in you coach? > > > > > > Interesting...I was under the bed and found the water line strainer to > > > be cracked on the top, and dripping only a slight trace of water on > > > the > > > floor. I change out the strainer and now the original water pump > > > works a > > > lot better. I'm assuming the cracked strainer was sucking air. Can't > > > wait to install the variable speed ShurFlo water pump. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > Pete Masterson wrote: > > > > > >> A few weeks ago, I installed (as did several others) a variable speed > > >> ShurFlo water pump to replace the (leaking) dual water pumps in my > > >> coach. So far, I've been well satisfied ... but an unexpected issue > > >> has come to light. We've found that the higher water pressure > > >> available from the pump (65 lbs.) makes washing dishes and taking > > >> showers more pleasant ... so even when parked where shore water is > > >> available, we've tended to use the pump. > > >> > > >> Recently, we noticed a problem with the Microphor toilet ... it was > > >> not refilling after flushing and sometimes it would not flush > > >> properly -- or you'd need to hold down the handle a very long time > > >> for it to function as expected. After reviewing the troubleshooting > > >> section of the Microphor documentation, I saw that the problems I was > > >> having was due to "excess" water pressure. The Microphor is designed > > >> to operate with 30 to 50 lbs of water pressure. If higher water > > >> pressure is present, the very problems we were having may occur. > > >> > > >> Others who have upgraded to a variable may want to take this into > > >> consideration. Microphor suggests inserting a pressure limiter in the > > >> water supply line to solve/avoid problems. (I just turned off the > > >> pump -- we'll only turn it on for dishes and showers, now.) > > >> > > >> Pete Masterson > > >> '95 Blue Bird Wanderlodge WBDA 42 > > >> El Sobrante CA > > >> aeonix1@... > > > > > >> > > >> > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > |
04-13-2007, 03:03
Thanks Curt. It looks like they are a common garden variety air regulator.
Should be readily available, maybe even at Harbor Freight. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, April 13, 2007 7:34 AM Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump Dick, I sent you photos showing the air regulators installed. I zip tied them in place. Adjust them until the dump valve will open/close. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Richard Hayden wrote: > I don't think so, Curt. I use that white stuff I get at Quartzite and > it works great, no odor. I think it's called "Happy Camper". What did > you use for air regulators? And, did you put them in? Where? > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Curt Sprenger > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, April 12, 2007 8:20 PM > Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump > > Dick, > Right you are. Our air dump valves are installed with the air regulators > per Randy. No problems so far. The black tank stinks...anything to do > with the air valves...Ha!!! > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Richard Hayden wrote: > > > Along with air regulators for the Microphor we all should put them on > > the air line to the dump valves. According to Randy it would extend > > the valves life by not pushing so hard when running with the air > > pressure is over 100 lbs. Just another project I haven't gotten around > > too yet. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > ----- Original Message ----- > > From: Pete Masterson > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > Sent: Wednesday, April 11, 2007 7:37 PM > > Subject: Re: [WanderlodgeForum] Microphor toilet and variable speed pump > > > > Yes, I have the air-operated Microphor (with a small 12v compressor > > in the basement compartment nearby). It would be worthwhile to check > > the Microphor website for the installation/troubleshooting manual for > > your model. I may get around to installing a pressure controller for > > the water supply to the toilet. I actually have a nice one in my > > 'junk' box from a long-dead drip irrigation system I once had. > > > > Pete Masterson > > '95 Blue Bird Wanderlodge WBDA 42 > > Currently in Golden Colorado where we're getting on the road early > > tomorrow heading south to get out of the way of another $@$!% snow > > storm! > > aeonix1@... > > > > > > > > > > On Apr 10, 2007, at 7:49 PM, Curt Sprenger wrote: > > > > > Pete, > > > > > > Thank you for the posting. Do you have the air operated Microphor > > > toilet > > > in you coach? > > > > > > Interesting...I was under the bed and found the water line strainer to > > > be cracked on the top, and dripping only a slight trace of water on > > > the > > > floor. I change out the strainer and now the original water pump > > > works a > > > lot better. I'm assuming the cracked strainer was sucking air. Can't > > > wait to install the variable speed ShurFlo water pump. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > > > Pete Masterson wrote: > > > > > >> A few weeks ago, I installed (as did several others) a variable speed > > >> ShurFlo water pump to replace the (leaking) dual water pumps in my > > >> coach. So far, I've been well satisfied ... but an unexpected issue > > >> has come to light. We've found that the higher water pressure > > >> available from the pump (65 lbs.) makes washing dishes and taking > > >> showers more pleasant ... so even when parked where shore water is > > >> available, we've tended to use the pump. > > >> > > >> Recently, we noticed a problem with the Microphor toilet ... it was > > >> not refilling after flushing and sometimes it would not flush > > >> properly -- or you'd need to hold down the handle a very long time > > >> for it to function as expected. After reviewing the troubleshooting > > >> section of the Microphor documentation, I saw that the problems I was > > >> having was due to "excess" water pressure. The Microphor is designed > > >> to operate with 30 to 50 lbs of water pressure. If higher water > > >> pressure is present, the very problems we were having may occur. > > >> > > >> Others who have upgraded to a variable may want to take this into > > >> consideration. Microphor suggests inserting a pressure limiter in the > > >> water supply line to solve/avoid problems. (I just turned off the > > >> pump -- we'll only turn it on for dishes and showers, now.) > > >> > > >> Pete Masterson > > >> '95 Blue Bird Wanderlodge WBDA 42 > > >> El Sobrante CA > > >> aeonix1@... > > > > > > > > >> > > >> > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
04-13-2007, 03:13
> Pete Masterson
> '95 Blue Bird Wanderlodge WBDA 42 > Currently in Amarillo TX -- heading south out of winter's last gasp... So Pete,.... are you going to join us in San Antonio at the Lone Star Birds Rally this weekend? We are definitely south of Amarillo! And warm. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > My original post was about _water_ pressure. But the air pressure > issue is also an excellent point. As it happens, I have a Microphor > 12v compressor that's independent from the coach air system. It's > limited to 90 psi. I plan to move my dump valves over to the > Microphor compressor when time allows as it will eliminate needing to > 'air up' to dump. > > I notice that the air-dump valves seem to work ok with about 70 psi > but are a little sluggish with less -- but I was in a very cold place > when I was taking note of the pressures (I'd pumped up the coach with > an external compressor since it wasn't worth the difficulty in > starting the engine in 25 degree weather...) > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > Currently in Amarillo TX -- heading south out of winter's last gasp... > aeonix1@... > > > > On Apr 12, 2007, at 11:29 AM, Richard Hayden wrote: > > > Along with air regulators for the Microphor we all should put them > > on the air line to the dump valves. According to Randy it would > > extend the valves life by not pushing so hard when running with the > > air pressure is over 100 lbs. Just another project I haven't > > gotten around too yet. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > ----- Original Message ----- > > From: Pete Masterson > > To: > > WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, April 11, 2007 7:37 PM > > Subject: Re: [WanderlodgeForum] Microphor toilet and variable > > speed pump > > > > > > Yes, I have the air-operated Microphor (with a small 12v compressor > > in the basement compartment nearby). It would be worthwhile to check > > the Microphor website for the installation/troubleshooting manual > > for > > your model. > <snip> > |
