To buy or not part II
04-12-2007, 12:47
Man, what terrific feedback! Much appreciated. My observation of the
33FC with rear bath is that it is more wide-open than the side bath (making it feel bigger), providing good (but seperate) sleep arrangements for 2, and adequate sleep arrangements for 4. The twin couches and booth also provide adequate seating for 4. The 33 does have limited floor space... basically an aisle, which might get a little tight for extended time inside, and limited storage. The trade-off appears to be good fuel economy and excellent maneuverability. having grown up traveling the country with my folks and sis in a 16' Shasta in the 60's, the 33 feels like a palace to me. Go's to show how times change. Overall though, I'm rethinking the size issue more carefully at this point. Thanks to everyone for your advice. RW in Central Illinois |
04-12-2007, 14:03
If you budget $10,000 for upgrades and repairs in the first 2 years,
then you can't go wrong. After that $1,000 per year may be enough. Check the condition and age of the batteries, and especially check the date on the tires. There is a DOT code on the tires that give the manufactured date. If older than 5 years consider replacement. If older than 7 years, replace immediately for your family's safety. A search on "DOT tire date" should get the info you need. A FC35 NEEDS 16 ply tires, a FC33 may get by with 14 ply tires. Michelin etc truck tire sites have good info to include weight versus plys and the date code. Dan - prior 83 FC35, current 94 BB BMC 37, NM, in AZ currently. --- In WanderlodgeForum@yahoogroups.com, "littlehouseonprairie1" <murphy4@...> wrote: > > Man, what terrific feedback! Much appreciated. My observation of the > 33FC with rear bath is that it is more wide-open than the side bath > (making it feel bigger), providing good (but seperate) sleep > arrangements for 2, and adequate sleep arrangements for 4. The twin > couches and booth also provide adequate seating for 4. The 33 does > have limited floor space... basically an aisle, which might get a > little tight for extended time inside, and limited storage. The > trade-off appears to be good fuel economy and excellent maneuverability. > having grown up traveling the country with my folks and sis in a 16' > Shasta in the 60's, the 33 feels like a palace to me. Go's to show > how times change. Overall though, I'm rethinking the size issue more > carefully at this point. Thanks to everyone for your advice. > > RW in Central Illinois > |
04-12-2007, 22:21
I agree with that to Crit as we had a 79 FC 33' with a side bath.
Don 89 SP 36' Butler, PA one more thought and then I will leave you alone, I prefer the side bath because: if the forward living area is to be used for sleeping then every one has access to the bath with out having to walk through any other sleeping areas. Crit Bliss '80FC33 Harwich, ma. "crittenden_"crittenden ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-12-2007, 22:41
Hey RW, my wife and I have spent 7 months a year for the past 5 years living aboard our coach and traveling everywhere. A big trailer solved any space issues as it pertains to gear. We have had almost no repairs ( I remember a h2o heater at RATS), but we have performed many upgrades to tailor the coach to our needs and likes. Maintaining the coach is simple, oil changes and belts and such, thats why a swing out radiator is so important. My advise would be to by a coach that is the owners pride and joy and used a lot, I have a friend that tried to save a basket case FC, it was a losing battle, he paid ten grand less than me, that ten grand went fast and he still had a long way to go. Find a turbo coach, that means it will have almost enough power. Ours had been re-powered up to the 250hp, that also means someone had been through about everything associated with that motor and drive train, he had also put in a new genset. Follow the link in the "link" section over to Bruce's site to see how fiberglass coaches hold up when the have a bad day. Good luck. Crit Bliss '80FC33 Harwich, ma. "ac7880" > > If you budget $10,000 for upgrades and repairs in the first 2 years, > then you can't go wrong. After that $1,000 per year may be enough. > > Check the condition and age of the batteries, and especially check > the date on the tires. There is a DOT code on the tires that give > the manufactured date. If older than 5 years consider replacement. > If older than 7 years, replace immediately for your family's safety. > A search on "DOT tire date" should get the info you need. A FC35 > NEEDS 16 ply tires, a FC33 may get by with 14 ply tires. Michelin > etc truck tire sites have good info to include weight versus plys and > the date code. > > Dan - prior 83 FC35, current 94 BB BMC 37, NM, in AZ currently. > > --- In WanderlodgeForum@yahoogroups.com, "littlehouseonprairie1" > <murphy4@> wrote: > > > > Man, what terrific feedback! Much appreciated. My observation of > the > > 33FC with rear bath is that it is more wide-open than the side bath > > (making it feel bigger), providing good (but seperate) sleep > > arrangements for 2, and adequate sleep arrangements for 4. The twin > > couches and booth also provide adequate seating for 4. The 33 does > > have limited floor space... basically an aisle, which might get a > > little tight for extended time inside, and limited storage. The > > trade-off appears to be good fuel economy and excellent > maneuverability. > > having grown up traveling the country with my folks and sis in a 16' > > Shasta in the 60's, the 33 feels like a palace to me. Go's to show > > how times change. Overall though, I'm rethinking the size issue > more > > carefully at this point. Thanks to everyone for your advice. > > > > RW in Central Illinois > > > |
04-12-2007, 23:50
one more thought and then I will leave you alone, I prefer the side bath because: if the forward living area is to be used for sleeping then every one has access to the bath with out having to walk through any other sleeping areas. Crit Bliss '80FC33 Harwich, ma. "crittenden_bliss" > > --- In WanderlodgeForum@yahoogroups.com, > > Hey RW, my wife and I have spent 7 months a year for the past 5 years > living aboard our coach and traveling everywhere. A big trailer > solved any space issues as it pertains to gear. We have had almost no > repairs ( I remember a h2o heater at RATS), but we have performed many > upgrades to tailor the coach to our needs and likes. Maintaining the > coach is simple, oil changes and belts and such, thats why a swing out > radiator is so important. My advise would be to by a coach that is > the owners pride and joy and used a lot, I have a friend that tried to > save a basket case FC, it was a losing battle, he paid ten grand less > than me, that ten grand went fast and he still had a long way to go. > Find a turbo coach, that means it will have almost enough power. Ours > had been re-powered up to the 250hp, that also means someone had been > through about everything associated with that motor and drive train, > he had also put in a new genset. Follow the link in the "link" > section over to Bruce's site to see how fiberglass coaches hold up > when the have a bad day. Good luck. > Crit Bliss '80FC33 Harwich, ma. > > > > > > "ac7880" > > > > If you budget $10,000 for upgrades and repairs in the first 2 years, > > then you can't go wrong. After that $1,000 per year may be enough. > > > > Check the condition and age of the batteries, and especially check > > the date on the tires. There is a DOT code on the tires that give > > the manufactured date. If older than 5 years consider replacement. > > If older than 7 years, replace immediately for your family's safety. > > A search on "DOT tire date" should get the info you need. A FC35 > > NEEDS 16 ply tires, a FC33 may get by with 14 ply tires. Michelin > > etc truck tire sites have good info to include weight versus plys and > > the date code. > > > > Dan - prior 83 FC35, current 94 BB BMC 37, NM, in AZ currently. > > > > --- In WanderlodgeForum@yahoogroups.com, "littlehouseonprairie1" > > <murphy4@> wrote: > > > > > > Man, what terrific feedback! Much appreciated. My observation of > > the > > > 33FC with rear bath is that it is more wide-open than the side bath > > > (making it feel bigger), providing good (but seperate) sleep > > > arrangements for 2, and adequate sleep arrangements for 4. The twin > > > couches and booth also provide adequate seating for 4. The 33 does > > > have limited floor space... basically an aisle, which might get a > > > little tight for extended time inside, and limited storage. The > > > trade-off appears to be good fuel economy and excellent > > maneuverability. > > > having grown up traveling the country with my folks and sis in a 16' > > > Shasta in the 60's, the 33 feels like a palace to me. Go's to show > > > how times change. Overall though, I'm rethinking the size issue > > more > > > carefully at this point. Thanks to everyone for your advice. > > > > > > RW in Central Illinois > > > > > > |
04-13-2007, 09:37
RW
We have a rear bath and love it, the bath is larger and you are right about it being much more open inside. With a 33 foot it looks like all you really lose is some kitchen counter space and the counter next to the couches and one overhead storage box on each side. We like the twin beds as well because the corner fullsize just is to small for both of us and the dog. There are some good things about a side bath as well, it splits the coach into living sections or areas. You can't go wrong with eather one, just know whatever you buy there will be unexpected issues. Good Luck Michelle & Jeff August 1980FC35RB Plymouth Wi. --- In WanderlodgeForum@yahoogroups.com, "littlehouseonprairie1" <murphy4@...> wrote: > > Man, what terrific feedback! Much appreciated. My observation of the > 33FC with rear bath is that it is more wide-open than the side bath > (making it feel bigger), providing good (but seperate) sleep > arrangements for 2, and adequate sleep arrangements for 4. The twin > couches and booth also provide adequate seating for 4. The 33 does > have limited floor space... basically an aisle, which might get a > little tight for extended time inside, and limited storage. The > trade-off appears to be good fuel economy and excellent maneuverability. > having grown up traveling the country with my folks and sis in a 16' > Shasta in the 60's, the 33 feels like a palace to me. Go's to show > how times change. Overall though, I'm rethinking the size issue more > carefully at this point. Thanks to everyone for your advice. > > RW in Central Illinois > |
