86 PT38...any pitfalls?
04-18-2007, 08:08
Scott, when I bought our PT40, the major difference was that I could not
hear the different pitches of noise from the engine that I was so used to hearing on our FC. And since I went to a year older bird, all the gauges that I was used to looking at were not included on my coach. Other then that, glad I made the switch. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-18-2007, 09:51
Pete Its easier to wash it off the toad than the rad. I took mine to the
curb & get it on my wrangler but my rad stays clean. Don 89 SP 36' Butler, PA The series 60 only has one ... located in the dumbest possible position, all things considered. When the engine cover is open, sitting at idle (warmed up) you can see the vapor coming out of the tube and being drawn by the fan under the street side of the coach and back through the radiator. On my 'to do' list is to rig up some pipe to route the tube out to the curb side (opposite from the fan). I don't want to route it out the back as that would end up all over my toad. ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-18-2007, 10:38
Are there are common problems on PT's I should look out for? I have an
FC and know a lot about them, but have zero hands-on experience with a PT. Anything I should pay special attention to outside of the "normal" things would be helpful. Thanks Scott Forman 82 FC35RB (Might be for sale soon) Memphis |
04-18-2007, 11:34
PTs have a tendency for the radiator to become clogged with dirt.
It's difficult to examine as shrouds and other appliances get in the way. The area swept by the fan usually is clear, but the surrounding area can be clogged with oily-dirt. (The "slobber tubes" feed hot oil vapor that mixes with dirt kicked up by the fan to clog the radiator.) This is a maintenance item (wash out with sudsy, warm water from time to time) but can become a serious issue if it causes the engine to overheat. Most of the rest is standard 'bird stuff... Of course the engine can have some considerable differences -- cat 3208 vs DD 6v92 or 8v92 (depending on year). You won't need a 'swing away' radiator! Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Johnson City Texas On Apr 18, 2007, at 5:38 PM, Scott Forman wrote: > Are there are common problems on PT's I should look out for? I > have an > FC and know a lot about them, but have zero hands-on experience with a > PT. Anything I should pay special attention to outside of the > "normal" > things would be helpful. |
04-18-2007, 11:47
Pete:
Do your slobber tubes hang down and touch the road? Just wondering. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 18, 2007 6:34 PM Subject: Re: [WanderlodgeForum] 86 PT38...any pitfalls? PTs have a tendency for the radiator to become clogged with dirt. It's difficult to examine as shrouds and other appliances get in the way. The area swept by the fan usually is clear, but the surrounding area can be clogged with oily-dirt. (The "slobber tubes" feed hot oil vapor that mixes with dirt kicked up by the fan to clog the radiator.) This is a maintenance item (wash out with sudsy, warm water from time to time) but can become a serious issue if it causes the engine to overheat. Most of the rest is standard 'bird stuff... Of course the engine can have some considerable differences -- cat 3208 vs DD 6v92 or 8v92 (depending on year). You won't need a 'swing away' radiator! Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Johnson City Texas On Apr 18, 2007, at 5:38 PM, Scott Forman wrote: > Are there are common problems on PT's I should look out for? I > have an > FC and know a lot about them, but have zero hands-on experience with a > PT. Anything I should pay special attention to outside of the > "normal" > things would be helpful. [Non-text portions of this message have been removed] |
04-18-2007, 12:01
What is a "slobber tube"? Never heard that one....
Scott --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > PTs have a tendency for the radiator to become clogged with dirt. > It's difficult to examine as shrouds and other appliances get in the > way. The area swept by the fan usually is clear, but the surrounding > area can be clogged with oily-dirt. (The "slobber tubes" feed hot oil > vapor that mixes with dirt kicked up by the fan to clog the > radiator.) This is a maintenance item (wash out with sudsy, warm > water from time to time) but can become a serious issue if it causes > the engine to overheat. > > Most of the rest is standard 'bird stuff... Of course the engine can > have some considerable differences -- cat 3208 vs DD 6v92 or 8v92 > (depending on year). > > You won't need a 'swing away' radiator! > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Johnson City Texas > > > > On Apr 18, 2007, at 5:38 PM, Scott Forman wrote: > > > Are there are common problems on PT's I should look out for? I > > have an > > FC and know a lot about them, but have zero hands-on experience with a > > PT. Anything I should pay special attention to outside of the > > "normal" > > things would be helpful. > |
04-18-2007, 13:37
position, all things considered. When the engine cover is open, sitting at idle (warmed up) you can see the vapor coming out of the tube and being drawn by the fan under the street side of the coach and back through the radiator. On my 'to do' list is to rig up some pipe to route the tube out to the curb side (opposite from the fan). I don't want to route it out the back as that would end up all over my toad. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Apr 18, 2007, at 6:47 PM, Leroy Eckert wrote: > Pete: > Do your slobber tubes hang down and touch the road? Just wondering. > > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FL > > > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, April 18, 2007 6:34 PM > Subject: Re: [WanderlodgeForum] 86 PT38...any pitfalls? > > > PTs have a tendency for the radiator to become clogged with dirt. > It's difficult to examine as shrouds and other appliances get in the > way. The area swept by the fan usually is clear, but the surrounding > area can be clogged with oily-dirt. (The "slobber tubes" feed hot > oil > vapor that mixes with dirt kicked up by the fan to clog the > radiator.) This is a maintenance item (wash out with sudsy, warm > water from time to time) but can become a serious issue if it causes > the engine to overheat. > > Most of the rest is standard 'bird stuff... Of course the engine can > have some considerable differences -- cat 3208 vs DD 6v92 or 8v92 > (depending on year). > > You won't need a 'swing away' radiator! > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Johnson City Texas > > On Apr 18, 2007, at 5:38 PM, Scott Forman wrote: > >> Are there are common problems on PT's I should look out for? I >> have an >> FC and know a lot about them, but have zero hands-on experience >> with a >> PT. Anything I should pay special attention to outside of the >> "normal" >> things would be helpful. > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > |
04-18-2007, 13:39
A part of the crankcase ventilation system. I my case one each tube attached to
the left and right cylinder heads near the valve covers which drop to road level and one large crankcase breather tube which hangs well below the engine pan. In my set up any oil slobber hits the road. Hence, the buzz word "slobber tubes" Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 18, 2007 7:01 PM Subject: [WanderlodgeForum] Re: 86 PT38...any pitfalls? What is a "slobber tube"? Never heard that one.... Scott --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > PTs have a tendency for the radiator to become clogged with dirt. > It's difficult to examine as shrouds and other appliances get in the > way. The area swept by the fan usually is clear, but the surrounding > area can be clogged with oily-dirt. (The "slobber tubes" feed hot oil > vapor that mixes with dirt kicked up by the fan to clog the > radiator.) This is a maintenance item (wash out with sudsy, warm > water from time to time) but can become a serious issue if it causes > the engine to overheat. > > Most of the rest is standard 'bird stuff... Of course the engine can > have some considerable differences -- cat 3208 vs DD 6v92 or 8v92 > (depending on year). > > You won't need a 'swing away' radiator! > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Johnson City Texas > > > > On Apr 18, 2007, at 5:38 PM, Scott Forman wrote: > > > Are there are common problems on PT's I should look out for? I > > have an > > FC and know a lot about them, but have zero hands-on experience with a > > PT. Anything I should pay special attention to outside of the > > "normal" > > things would be helpful. > [Non-text portions of this message have been removed] |
04-18-2007, 13:41
Slobber tube also known as "breather tube(s)". This is a crank case
breather to allow air pressure to escape from the engine as it heats up. DD 6v92 and 8v92 engines have two of them (one for each bank of cylinders) and they are notorious for dribbling oil. The DD Series 60 engine (an inline-6, four cycle engine) is not as serious an oil- dribbler as some 8v92s ... but the location in relation to the radiator is not well thought out. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Johnson CIty, Texas On Apr 18, 2007, at 7:01 PM, Scott Forman wrote: > What is a "slobber tube"? Never heard that one.... > > Scott > > --- In WanderlodgeForum@yahoogroups.com, Pete Masterson > wrote: >> >> PTs have a tendency for the radiator to become clogged with dirt. >> It's difficult to examine as shrouds and other appliances get in > the >> way. The area swept by the fan usually is clear, but the > surrounding >> area can be clogged with oily-dirt. (The "slobber tubes" feed hot > oil >> vapor that mixes with dirt kicked up by the fan to clog the >> radiator.) This is a maintenance item (wash out with sudsy, warm >> water from time to time) but can become a serious issue if it > causes >> the engine to overheat. >> >> Most of the rest is standard 'bird stuff... Of course the engine > can >> have some considerable differences -- cat 3208 vs DD 6v92 or 8v92 >> (depending on year). >> >> You won't need a 'swing away' radiator! >> >> Pete Masterson >> '95 Blue Bird Wanderlodge WBDA 42 >> aeonix1@... >> On the road at Johnson City Texas >> >> >> >> On Apr 18, 2007, at 5:38 PM, Scott Forman wrote: >> >>> Are there are common problems on PT's I should look out for? I >>> have an >>> FC and know a lot about them, but have zero hands-on experience > with a >>> PT. Anything I should pay special attention to outside of the >>> "normal" >>> things would be helpful. >> > > > > > > Yahoo! Groups Links > > > |
04-18-2007, 13:43
Thanks, I forgot you have a Series 60. Getting it to road level will certainly
help. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, April 18, 2007 8:37 PM Subject: Re: [WanderlodgeForum] 86 PT38...any pitfalls? The series 60 only has one ... located in the dumbest possible position, all things considered. When the engine cover is open, sitting at idle (warmed up) you can see the vapor coming out of the tube and being drawn by the fan under the street side of the coach and back through the radiator. On my 'to do' list is to rig up some pipe to route the tube out to the curb side (opposite from the fan). I don't want to route it out the back as that would end up all over my toad. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Apr 18, 2007, at 6:47 PM, Leroy Eckert wrote: > Pete: > Do your slobber tubes hang down and touch the road? Just wondering. > > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FL > > > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, April 18, 2007 6:34 PM > Subject: Re: [WanderlodgeForum] 86 PT38...any pitfalls? > > > PTs have a tendency for the radiator to become clogged with dirt. > It's difficult to examine as shrouds and other appliances get in the > way. The area swept by the fan usually is clear, but the surrounding > area can be clogged with oily-dirt. (The "slobber tubes" feed hot > oil > vapor that mixes with dirt kicked up by the fan to clog the > radiator.) This is a maintenance item (wash out with sudsy, warm > water from time to time) but can become a serious issue if it causes > the engine to overheat. > > Most of the rest is standard 'bird stuff... Of course the engine can > have some considerable differences -- cat 3208 vs DD 6v92 or 8v92 > (depending on year). > > You won't need a 'swing away' radiator! > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > aeonix1@... > On the road at Johnson City Texas > > On Apr 18, 2007, at 5:38 PM, Scott Forman wrote: > >> Are there are common problems on PT's I should look out for? I >> have an >> FC and know a lot about them, but have zero hands-on experience >> with a >> PT. Anything I should pay special attention to outside of the >> "normal" >> things would be helpful. > > > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
