ECM Location
04-23-2007, 00:54
ECM Location
Anyone have a location of the ECM on a 92 Wide Body 40' Coach. It is
not in the closet. Need info quickly. R.E. (Ron) Marabito, Dallas, TX 92WB40 Currently in Bottomless Lake State Park, Roswell, NM |
04-23-2007, 01:02
ECM Location
Is the ECM = electronic control modual? if you are looking for the
detroit and allison control hookups to plug in a reader, they are below the tranny shift panel in the cockpit. remove 4 small screws. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Anyone have a location of the ECM on a 92 Wide Body 40' Coach. It is > not in the closet. Need info quickly. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Currently in Bottomless Lake State Park, Roswell, NM > |
04-23-2007, 01:20
ECM Location
Not looking for the connection to a reader. Looking for the unit itself.
R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Is the ECM = electronic control modual? if you are looking for the > detroit and allison control hookups to plug in a reader, they are below > the tranny shift panel in the cockpit. remove 4 small screws. > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > Anyone have a location of the ECM on a 92 Wide Body 40' Coach. It is > > not in the closet. Need info quickly. > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > Currently in Bottomless Lake State Park, Roswell, NM > > > |
04-23-2007, 01:51
ECM Location
Ron,
Hope you found it! There are two one for tranny and one for engine. In my 88 WBWL tranny is in the front of coach. Open the door at the left front quarter where you can access the colloing system for the Generator. Mine is on the back wall of this compartment. The Engine ecm is in the closet in the baclk of the bus. I have a queen and the closet is at the head of the bed most rear of the coach. I have to climb into the closet(no jokes) remove a panel in the closet and there it is. Benny at the time told me where it was but it wasn't easy to find. I have had problems with the wiring that attaches just above the engine. espoecially after working around it I have reseated those plugs using dieelectric grease. one of the connector wires did not seat properly and had some error codes till I got it right. Jim Riordan 88 WBWL XXV Stuart, Fl --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > Not looking for the connection to a reader. Looking for the unit itself. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Is the ECM = electronic control modual? if you are looking for the > > detroit and allison control hookups to plug in a reader, they are below > > the tranny shift panel in the cockpit. remove 4 small screws. > > GregoryO'Connor > > 94ptRomolandCa > > > > --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > Anyone have a location of the ECM on a 92 Wide Body 40' Coach. It is > > > not in the closet. Need info quickly. > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > Currently in Bottomless Lake State Park, Roswell, NM > > > > > > |
