Front end alignment question
04-23-2007, 05:20
I just got back from my first long range journey and found that my
84FC35 has a tendency to pull to the right. When I first bought it (February) I noticed a tendency to lean a little to the right side occasionally ut didn't know what to make of it. I just replaced the tires with Remington steer only and Sumitomo's in the back. From a rookie's point of view I'm wondering if I need an alignment or could it be a function of ride height adjustment? If it's alignment what should I know before I seek out a place to do it? Is it as simple as a car or light truck? Remember, there are no stupid questions... but I like to push the envelope. Keith (Just back from Casa Blanca (AZ) Sundance. 84FC35 |
04-23-2007, 06:33
Hi Keith,
Had the same problem and got alignment done for around $100 (give or take a few $) Coach steers and rides much better. No longer pulls to one side when braking either. Money well spent. If you don't do it, tires will wear unevenly. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > I just got back from my first long range journey and found that my > 84FC35 has a tendency to pull to the right. When I first bought it > (February) I noticed a tendency to lean a little to the right side > occasionally ut didn't know what to make of it. I just replaced the > tires with Remington steer only and Sumitomo's in the back. > > From a rookie's point of view I'm wondering if I need an alignment or > could it be a function of ride height adjustment? > > If it's alignment what should I know before I seek out a place to do > it? Is it as simple as a car or light truck? > > Remember, there are no stupid questions... but I like to push the > envelope. > > Keith (Just back from Casa Blanca (AZ) Sundance. > 84FC35 > |
04-23-2007, 06:41
Keith,
I just want to remind you,if you weren't already aware, Mostly all Arizona highways are extremely crowned,or in some cases sloped to to right side. I know I-8 is very sloped,between Yuma and Casa Grande. I have to remind myself of this each trip we are on that stretch. Fred & Jeanne Hulse Morristown,Arizona 1997 Wanderlodge WB41 [Non-text portions of this message have been removed] |
04-23-2007, 10:08
Keith,
One thing I noted while test driving that coach for you was how nice and straight it went down the highway, there was no pull at all to the left or right just straight down the highway. Did you notice this when you drove it home from San Jose? Do the air bags hold air after shut down? Robert Britton 87FC Hollister, California --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > I just got back from my first long range journey and found that my > 84FC35 has a tendency to pull to the right. When I first bought it > (February) I noticed a tendency to lean a little to the right side > occasionally ut didn't know what to make of it. I just replaced the > tires with Remington steer only and Sumitomo's in the back. > > From a rookie's point of view I'm wondering if I need an alignment or > could it be a function of ride height adjustment? > > If it's alignment what should I know before I seek out a place to do > it? Is it as simple as a car or light truck? > > Remember, there are no stupid questions... but I like to push the > envelope. > > Keith (Just back from Casa Blanca (AZ) Sundance. > 84FC35 > |
04-24-2007, 03:07
Hey Robert, I didn't notice it when I first got it. But since I got
news tires it's noticible. The old tires were so hard it was difficult to tell. With the new tires I noticed right away that it was much easier to steer but also noticed the pull to the right. I thought it might have been the road surface but it's too much even for that. I noticed in some situations that the coach felt like it was leaning to the right. The air tends to bleed off fairly quickly but I attributed most of that to the leaking step cylinder. So as always I'm open for suggestions. I think I'll start with getting a front end alignment. If that doesn't solve the problem I'll move to the next most likely culprit. Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "Robert Britton" > > Keith, > One thing I noted while test driving that coach for you was how nice > and straight it went down the highway, there was no pull at all to > the left or right just straight down the highway. > Did you notice this when you drove it home from San Jose? > Do the air bags hold air after shut down? > > Robert Britton > 87FC > Hollister, California > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > I just got back from my first long range journey and found that my > > 84FC35 has a tendency to pull to the right. When I first bought it > > (February) I noticed a tendency to lean a little to the right side > > occasionally ut didn't know what to make of it. I just replaced > the > > tires with Remington steer only and Sumitomo's in the back. > > > > From a rookie's point of view I'm wondering if I need an alignment > or > > could it be a function of ride height adjustment? > > > > If it's alignment what should I know before I seek out a place to > do > > it? Is it as simple as a car or light truck? > > > > Remember, there are no stupid questions... but I like to push the > > envelope. > > > > Keith (Just back from Casa Blanca (AZ) Sundance. > > 84FC35 > > > |
