Coach air hanging at 60 psi?
04-24-2007, 09:58
Good evening to all:
Just a couple of review points on airing up the suspension; Coach air gauges seem to stop at 60 psi and does not seem to go further. There are two systems in the Coach that can and will cause this, besides having a hole in the air bag or break pods. One being the winterizing settings. If you leave the air purge switch in the wrong position (we have all done this at one time or other) The water heater switch to drain instead of fill. Another is the bulk oil fill switch. If left on, the coach will not air past 60 psi usually. I mention this because we all are starting to bring the Coaches on line for summer use and it is easy to have these systems with the settings needed to de winterize. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma |
