Florescent 12V Lights
04-25-2007, 17:34
I am a new guy please bear with me. I have a question about the 12V
florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. The new Thin-lites won't fit the hole. I found the 12V florescent rebuild in the files section (thanks), but where can I buy parts (balast)? Thanks, Brad Bloxham, Yuma AZ. |
04-25-2007, 20:25
Brad, Stephen Birtles has those ballasts in stock. _cape0001@...
Ernie Ekberg 83PT40 Livingston, Mt _ (mailto:cape0001@...) ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
04-26-2007, 00:25
Brad,
A lot of RV and Marine places will have the 12V ballasts. If you're into improvements, you might want to consider low voltage halogen or even LED lighting. In my 86 coach, I almost never had all the flourescents working at one time. Good luck. Brad Barton 00LXiDFW bbartonwx@... >From: "kingmtpg" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Florescent 12V Lights >Date: Thu, 26 Apr 2007 05:34:12 -0000 > > I am a new guy please bear with me. I have a question about the 12V >florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. >The new Thin-lites won't fit the hole. I found the 12V florescent >rebuild in the files section (thanks), but where can I buy parts >(balast)? Thanks, Brad Bloxham, Yuma AZ. > _________________________________________________________________ Exercise your brain! Try Flexicon. http://games.msn.com/en/flexicon/default...ineapril07 |
04-26-2007, 01:13
I have the ballasts for the 12 volt lights
stephen 77fc35 905 328 0162 --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" > > I am a new guy please bear with me. I have a question about the 12V > florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. > The new Thin-lites won't fit the hole. I found the 12V florescent > rebuild in the files section (thanks), but where can I buy parts > (balast)? Thanks, Brad Bloxham, Yuma AZ. > |
04-26-2007, 01:34
Are those cameras on the water??????????
Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FLK ----- Original Message ----- From: Stephen Birtles To: WanderlodgeForum@yahoogroups.com Sent: Thursday, April 26, 2007 8:13 AM Subject: [WanderlodgeForum] Re: Florescent 12V Lights I have the ballasts for the 12 volt lights stephen 77fc35 905 328 0162 --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" > > I am a new guy please bear with me. I have a question about the 12V > florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. > The new Thin-lites won't fit the hole. I found the 12V florescent > rebuild in the files section (thanks), but where can I buy parts > (balast)? Thanks, Brad Bloxham, Yuma AZ. > [Non-text portions of this message have been removed] |
04-26-2007, 03:14
They are on their way I got the tracking number. Which is a start
Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Are those cameras on the water?????????? > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FLK > > > ----- Original Message ----- > From: Stephen Birtles > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, April 26, 2007 8:13 AM > Subject: [WanderlodgeForum] Re: Florescent 12V Lights > > > I have the ballasts for the 12 volt lights > stephen 77fc35 > 905 328 0162 > > --- In WanderlodgeForum@yahoogroups.com, "kingmtpg" > > > > I am a new guy please bear with me. I have a question about the 12V > > florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. > > The new Thin-lites won't fit the hole. I found the 12V florescent > > rebuild in the files section (thanks), but where can I buy parts > > (balast)? Thanks, Brad Bloxham, Yuma AZ. > > > > > > > > [Non-text portions of this message have been removed] > |
04-26-2007, 04:32
Brad,
I have a 79FC33SB As mine are failing I am replaceing them with the lights used in scanners and also computer cases. Pros, Easy to install I use glue low power less than 1 amp low cost 2 12" tubes with blast, wireing and tube protecters, 15$ at Frys good for 30K hours for more light 2 sets can be installed in 1 housing Cons require warm up time 30 seconds to full brightness light is a bright white My next project is to install them at the top of the bin doors. this will give me more light in the center of the coach, and I will drill holes to allow the light into the bins as well. Chuck Port Angeles Wa. On Thursday, April 26, 2007, at 05:25 AM, brad barton wrote: > Brad, > A lot of RV and Marine places will have the 12V ballasts. > If you're into improvements, you might want to consider low voltage > halogen > or even LED lighting. In my 86 coach, I almost never had all the > flourescents working at one time. Good luck. > > Brad Barton 00LXiDFW > bbartonwx@... > > >From: "kingmtpg" > >Reply-To: WanderlodgeForum@yahoogroups.com > >To: WanderlodgeForum@yahoogroups.com > >Subject: [WanderlodgeForum] Florescent 12V Lights > >Date: Thu, 26 Apr 2007 05:34:12 -0000 > > > > I am a new guy please bear with me. I have a question about the 12V > >florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. > >The new Thin-lites won't fit the hole. I found the 12V florescent > >rebuild in the files section (thanks), but where can I buy parts > >(balast)? Thanks, Brad Bloxham, Yuma AZ. > > > > __________________________________________________________ > Exercise your brain! Try Flexicon. > http://games.msn.com/en/flexicon/ > default.htm?icid=flexicon_hmemailtaglineapril07 > > |
04-26-2007, 05:18
another con is that the colder itis the longer it takes for the bulb
to come to full brightness you will find decreased longevity of the bulb and ballast because it is hard on both the bulb and ballast to run at less than optimum brightness and temperatures If the lamp fails to start instantly it will place a high current load on the ballast if this load remains too long it can overheat the ballast and cause premature failure our ballasts run at 1 amp at 12 volts In your case trying to warm of the bulbs for 30 seconds I would also put a 1 or 2 amp fuse at the light for your own protection Stephen 77fc35 no warm up time and good to 30 below --- In WanderlodgeForum@yahoogroups.com, keyriffic > > Brad, > > I have a 79FC33SB As mine are failing I am replaceing them with the > lights used in scanners and also computer cases. > Pros, > Easy to install I use glue > low power less than 1 amp > low cost 2 12" tubes with blast, wireing and tube protecters, 15$ at > Frys > good for 30K hours > for more light 2 sets can be installed in 1 housing > Cons > require warm up time 30 seconds to full brightness > light is a bright white > > My next project is to install them at the top of the bin doors. this > will give me more light in the center of the coach, and I will drill > holes to allow the light into the bins as well. > > Chuck > Port Angeles Wa. > > On Thursday, April 26, 2007, at 05:25 AM, brad barton wrote: > > > Brad, > > A lot of RV and Marine places will have the 12V ballasts. > > If you're into improvements, you might want to consider low voltage > > halogen > > or even LED lighting. In my 86 coach, I almost never had all the > > flourescents working at one time. Good luck. > > > > Brad Barton 00LXiDFW > > bbartonwx@... > > > > >From: "kingmtpg" > > >Reply-To: WanderlodgeForum@yahoogroups.com > > >To: WanderlodgeForum@yahoogroups.com > > >Subject: [WanderlodgeForum] Florescent 12V Lights > > >Date: Thu, 26 Apr 2007 05:34:12 -0000 > > > > > > I am a new guy please bear with me. I have a question about the 12V > > >florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. > > >The new Thin-lites won't fit the hole. I found the 12V florescent > > >rebuild in the files section (thanks), but where can I buy parts > > >(balast)? Thanks, Brad Bloxham, Yuma AZ. > > > > > > > __________________________________________________________ > > Exercise your brain! Try Flexicon. > > http://games.msn.com/en/flexicon/ > > default.htm?icid=flexicon_hmemailtaglineapril07 > > > > > |
04-26-2007, 09:19
Brad,
I use the ones that Stephen Birtles sells. They work very well in cold weather and we spend a lot of time in Nebraska and Sought Dakota around the holidays. I got tired of the lights failing one at a time so I ordered enough to replace all the ballasts. I haven't done them all yet but the repaired ones come right on even in the cold after my bird has not been plugged in for awhile. I had a interesting test a few weeks ago when I forgot to turn off the mail switch. The fluorescents would still come on but the batteries were too low to crank. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of kingmtpg Sent: Thursday, April 26, 2007 12:34 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Florescent 12V Lights I am a new guy please bear with me. I have a question about the 12V florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. The new Thin-lites won't fit the hole. I found the 12V florescent rebuild in the files section (thanks), but where can I buy parts (balast)? Thanks, Brad Bloxham, Yuma AZ. [Non-text portions of this message have been removed] |
04-26-2007, 10:39
I sent one of my florescents in to RGM over 3 weeks ago and still
haven't gotten it back yet..hard to reach..must not be a fulltime business. Bob Lawrence 84 PT36 Tacoma, Wa. > I am a new guy please bear with me. I have a question about the 12V > florescents in my 78FC. They say RGM Ind, Titusville, FL on the back. > The new Thin-lites won't fit the hole. I found the 12V florescent > rebuild in the files section (thanks), but where can I buy parts > (balast)? Thanks, Brad Bloxham, Yuma AZ. > |
