Gray Water tank crossover to sewage tank
04-26-2007, 14:09
My coach seems to have a very small sewage tank and when in a park
that > does not have sewage hook-up it fill up fast! Now I was wondering if > any of the newer coaches have cross connects to use gray water tank for > sewage also. Or has anyone here made up a system so they could both > tanks at once ? And lastly has anyone installed another tank for the > main sewage waste overflow?. Thanks Jon PS. I think my sewage holding tank is probably around 36 gallons and my gray one maybe 40 to 50 gallons Jipjob@... 1978 Wanderlodge (Rebel Bird) Bremerton Washington http://i2.photobucket.com/albums/y4/1942...aru005.jpg |
04-27-2007, 00:48
Hey Jon,
If your FC is like mine was (Dave's coach), the toilet and bath sink feed the black tank, shower and kitchen sink feed the grey. Have you looked down the toilet opening with a flashlight to make sure it really is full, versus a bad sensor on the tank? Also shine a light down in the tank when empty to see if you have a "buildup" of material reducing the capacity. I believe you may violate some code if you run black into gray. We always keep both valves closed until nearly full, then dump black first. Dump gray second and it rinses the worst of the sewage from the hose. We practice low water use management when without sewage hookups to avoid the drive to the dump station. You can look on camping world for a blue sewage tote. You can dump a small amount at a time and take the tote to the dump station. Thats too much hassle in my opionion, but it could work. Dan NM --- In WanderlodgeForum@yahoogroups.com, "Jon" > > My coach seems to have a very small sewage tank and when in a park > that > > does not have sewage hook-up it fill up fast! Now I was wondering if > > any of the newer coaches have cross connects to use gray water tank > for > > sewage also. Or has anyone here made up a system so they could both > > tanks at once ? And lastly has anyone installed another tank for the > > main sewage waste overflow?. Thanks Jon > > PS. I think my sewage holding tank is probably around 36 gallons and my > gray one maybe 40 to 50 gallons > > Jipjob@... > 1978 Wanderlodge (Rebel Bird) > Bremerton Washington > http://i2.photobucket.com/albums/y4/1942...aru005.jpg > |
04-27-2007, 03:15
Some of the new high-end (Prevost) coaches have a single combined
gray/black water holding tank so there's no practical reason that the holding tanks can't be connected ... indeed, some folks have cross connected the holding tanks to solve a gray water surplus situation (I plan to look into this later on ... typically my gray water tank gets quite full and the black tank is still nearly empty.) You might consider simply replacing both the gray and black water tanks with a single (larger) holding tank -- depending on the access and plumbing situation in your coach. I note that the tanks sizes seem small compared to more recent 'birds... but '78 was a long time ago. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road near Dripping Springs Texas On Apr 26, 2007, at 9:09 PM, Jon wrote: > My coach seems to have a very small sewage tank and when in a park > that >> does not have sewage hook-up it fill up fast! Now I was wondering if >> any of the newer coaches have cross connects to use gray water tank > for >> sewage also. Or has anyone here made up a system so they could both >> tanks at once ? And lastly has anyone installed another tank for the >> main sewage waste overflow?. Thanks Jon > > PS. I think my sewage holding tank is probably around 36 gallons > and my > gray one maybe 40 to 50 gallons > > Jipjob@... > 1978 Wanderlodge (Rebel Bird) > |
04-27-2007, 04:25
Jon, My older Newell had a single waste tank although I believe it might
have been modified because I had two valves. I just left the "black" open at all times and emptied with the gray valve. And with today's plastic tanks..I don't think it would be too much trouble to modify it. Brad Barton 00LXiDFW bbartonwx@... > > >On Apr 26, 2007, at 9:09 PM, Jon wrote: > > > My coach seems to have a very small sewage tank and when in a park > > that > >> does not have sewage hook-up it fill up fast! Now I was wondering if > >> any of the newer coaches have cross connects to use gray water tank > > for > >> sewage also. Or has anyone here made up a system so they could both > >> tanks at once ? And lastly has anyone installed another tank for the > >> main sewage waste overflow?. Thanks Jon > > > > PS. I think my sewage holding tank is probably around 36 gallons > > and my > > gray one maybe 40 to 50 gallons > > > > Jipjob@... > > 1978 Wanderlodge (Rebel Bird) > > > _________________________________________________________________ Mortgage refinance is Hot. *Terms. Get a 5.375%* fix rate. Check savings https://www2.nextag.com/goto.jsp?product...h=mor\ tgage_text_links_88_h2bbb&disc=y&vers=925&s=4056&p=5117 |
04-27-2007, 08:23
Jon, I bought a blade valve in quartz site a couple years ago that
replaces the cap on your dump pipe. Just remove the end cap twist on the valve and then open both gray and black dump valves and you now have one big tank. When you go to dump you just twist the hose onto the other end of the valve. Works GREAT for extended stay's. I use it on my fifth wheel trailer a lot. You can go to the local rv store and buy the pieces and make your own for about $25.00. Bob 93pt illinois > > Jon, My older Newell had a single waste tank although I believe it might > have been modified because I had two valves. I just left the "black" open > at all times and emptied with the gray valve. And with today's plastic > tanks..I don't think it would be too much trouble to modify it. > > > > Brad Barton 00LXiDFW > bbartonwx@... > > > > > > > > >On Apr 26, 2007, at 9:09 PM, Jon wrote: > > > > > My coach seems to have a very small sewage tank and when in a park > > > that > > >> does not have sewage hook-up it fill up fast! Now I was wondering if > > >> any of the newer coaches have cross connects to use gray water tank > > > for > > >> sewage also. Or has anyone here made up a system so they could both > > >> tanks at once ? And lastly has anyone installed another tank for the > > >> main sewage waste overflow?. Thanks Jon > > > > > > PS. I think my sewage holding tank is probably around 36 gallons > > > and my > > > gray one maybe 40 to 50 gallons > > > > > > Jipjob@... > > > 1978 Wanderlodge (Rebel Bird) > > > > > > > _________________________________________________________________ > Mortgage refinance is Hot. *Terms. Get a 5.375%* fix rate. Check savings > https://www2.nextag.com/goto.jsp?product...0035&url=% 2fst.jsp&tm=y&search=mortgage_text_links_88_h2bbb&disc=y&vers=925&s=40 56&p=5117 > |
04-27-2007, 09:01
Pete,
I thought of many quips regarding you're situation with you waste tanks! I try to remember them at a future rally Jim Riordan 88 WBWL XXV Stuart, Fl. Pete Masterson Some of the new high-end (Prevost) coaches have a single combined gray/black water holding tank so there's no practical reason that the holding tanks can't be connected ... indeed, some folks have cross connected the holding tanks to solve a gray water surplus situation (I plan to look into this later on ... typically my gray water tank gets quite full and the black tank is still nearly empty.) You might consider simply replacing both the gray and black water tanks with a single (larger) holding tank -- depending on the access and plumbing situation in your coach. I note that the tanks sizes seem small compared to more recent 'birds... but '78 was a long time ago. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road near Dripping Springs Texas On Apr 26, 2007, at 9:09 PM, Jon wrote: > My coach seems to have a very small sewage tank and when in a park > that >> does not have sewage hook-up it fill up fast! Now I was wondering if >> any of the newer coaches have cross connects to use gray water tank > for >> sewage also. Or has anyone here made up a system so they could both >> tanks at once ? And lastly has anyone installed another tank for the >> main sewage waste overflow?. Thanks Jon > > PS. I think my sewage holding tank is probably around 36 gallons > and my > gray one maybe 40 to 50 gallons > > Jipjob@... > 1978 Wanderlodge (Rebel Bird) > --------------------------------- Ahhh...imagining that irresistible "new car" smell? Check outnew cars at Yahoo! Autos. [Non-text portions of this message have been removed] |
