Retarder use
05-01-2007, 02:51
Retarder use
My new PT has a retarder, the first vehicle I have owned with one. I
noticed in reading the manual that when the retarder dash switch is on,
it is engaged each time I hit the brake pedal, not just by using the
hand lever. What's the word on keeping the retarder on all the time?
Is that bad for the transmission? Or, will using the retarder all the
time extend brake life?
Thanks
Scott Forman
82 FC35RB for sale
86 PT38
05-01-2007, 03:23
Retarder use
Leave it on all the time. These big Birds can use the assist and it
saves on brake shoes.
Curt Sprenger
Anaheim Hills, Calif.
> Thanks
> Scott Forman
> 82 FC35RB for sale
> 86 PT38
05-01-2007, 07:21
Retarder use
Indeed, the newer BBs have the retarder completely integrated into
the automatic transmission. With the "engage" switch on, the retarder
(exhaust type) comes on whenever you simply remove your foot from the
throttle pedal. The strength of the response is modulated by setting
'low', 'medium', or 'high' on an adjacent switch. Using the retarder
in this manner, I can often go many miles without ever actually
stepping on the brakes to adjust speed on small downgrades, etc.
Pete Masterson
aeonix1@...
On the road at Lockhart Texas
> Curt Sprenger
>> is on,
>> Thanks
>> Scott Forman
>> 82 FC35RB for sale
>> 86 PT38
> Yahoo! Groups Links
05-01-2007, 08:03
Retarder use
I leave mine on all the time also unless the streets are wet. As well I gear
down the transmission to help slow the coach. Heavy use of the retarder causes
tranny temps to rise rapidly.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Tuesday, May 01, 2007 10:23 AM
Subject: Re: [WanderlodgeForum] Retarder use
Curt Sprenger
> Thanks
> Scott Forman
> 82 FC35RB for sale
> 86 PT38
