Air horn pedal valve
05-01-2007, 13:06
I have a cracked and leaking brass floor air horn pedal valve.The name
on it is Boell Mfg Co.I have not being able to locate through Google or truck supply shops.Any ideas? Ken Kalmakoff 1982 35sb Richmond BC Canada |
05-01-2007, 13:33
Ken
I think you find it is buell buellairhorns.com Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "four_heavyfeet" > > I have a cracked and leaking brass floor air horn pedal valve.The name > on it is Boell Mfg Co.I have not being able to locate through Google or > truck supply shops.Any ideas? > > Ken Kalmakoff > 1982 35sb > Richmond BC Canada > |
05-01-2007, 13:53
Ken,
Here is another site with foot operated air valves for horns. http://www.wolo-mfg.com/truck.htm Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > Ken > I think you find it is buell > > buellairhorns.com > > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "four_heavyfeet" > > > > > I have a cracked and leaking brass floor air horn pedal valve.The name > > on it is Boell Mfg Co.I have not being able to locate through Google or > > truck supply shops.Any ideas? > > > > Ken Kalmakoff > > 1982 35sb > > Richmond BC Canada > > > |
05-01-2007, 15:36
> > Ken > I think you find it is buell > Thanks Stephen: It is buell and I looked up the site.It looks like manual valve #2040 Thanks all. Ken Kalmakoff 1982 35sb Richmond BC Canada > buellairhorns.com > > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, "four_heavyfeet" > > > > > I have a cracked and leaking brass floor air horn pedal valve.The name > > on it is Boell Mfg Co.I have not being able to locate through Google or > > truck supply shops.Any ideas? > > > > Ken Kalmakoff > > 1982 35sb > > Richmond BC Canada > > > |
