Power steering ?
05-02-2007, 10:07
Power steering ?
Larry, I believe that is for your hydraulic jacks. If your jacks are
extended, don't add fluid- you will have a mess. Yes, it is transmission fluid. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-02-2007, 13:53
Power steering ?
I was cleaning the steps today and found a door, Under the door was a
plate and under the plate was a screw handle with a dip stick. I am guessing it is the fill for the power steering. Nothing showing on the dip stick. I put a screw driver in and the fluid looks like transmission fluid. Could not find any info on what fluid is recommended. Please tell me what to use.. Larry Kehler 94 PT-40 |
05-02-2007, 14:15
Power steering ?
It is the reservoir for the HWH Leveling System on my coach. The system calls
for Dextron II. I think Dextron II is not available but Dextron III is compatable. If you look under the step toward the center of the bus you should see a valve surrounded by a protective shroud which has 4 solenoids on it. That is what makes the jacks go. Your power steering reservoir is the large black canister in the left engine bay that uses 30w oil and also is the reservoir for the hydraulic cooling fan. That is how my coach is. Check to be certain. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Larry Kehler To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 02, 2007 8:53 PM Subject: [WanderlodgeForum] Power steering ? I was cleaning the steps today and found a door, Under the door was a plate and under the plate was a screw handle with a dip stick. I am guessing it is the fill for the power steering. Nothing showing on the dip stick. I put a screw driver in and the fluid looks like transmission fluid. Could not find any info on what fluid is recommended. Please tell me what to use.. Larry Kehler 94 PT-40 [Non-text portions of this message have been removed] |
05-02-2007, 14:18
Power steering ?
Thanks Ernie
OK so where is the power steering fill? Larry Kehler 94 PT-40 St Louis --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Larry, I believe that is for your hydraulic jacks. If your jacks are > extended, don't add fluid- you will have a mess. Yes, it is transmission fluid. > > Ernie Ekberg > 83PT40 > Livingston, Mt |
05-02-2007, 15:40
Power steering ?
Powersteering and Fan are the same hydrolic pump and resevoir. In the
engine bay to the left of the turbo. may have a rubber plumbers expand plug in it. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Larry Kehler" > > Thanks Ernie > > OK so where is the power steering fill? > > Larry Kehler > 94 PT-40 > St Louis > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > Larry, I believe that is for your hydraulic jacks. If your jacks are > > extended, don't add fluid- you will have a mess. Yes, it is > transmission fluid. > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > |
