PressurePro Questions
05-05-2007, 05:32
Those that have the PressurePro system installed on your 'Bird. What is
your system configuration, are you using the cabled antenna, no antenna, something else? Any issues with the control module receiving the toad signals. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
05-05-2007, 06:16
Curt,
The system that I'm ordering from Stephen has the optional RV ECHO REPEATER; http://www.doranmfg.com/cgi-bin/gzpstore.pl? user_action=detail&catalogno=7007 The basic system will be this model, but without the DORAN name on it; http://www.doranmfg.com/cgi-bin/gzpstore.pl? user_action=detail&catalogno=RV7008 I'm only getting eight sensors, as I have CrossFires on my rear duals and I haven't contacted CrossFire about using the sensors on them, but if that wont work I will have two spare sensors, or I can place them on two of my trailer spare tires, that way I will have at least 6 of my ten tires on the ground monitored and that is more than I have now. I prefer using the CrossFires on the rear duals, rather than removing them. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA ////////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Those that have the PressurePro system installed on your 'Bird. What is > your system configuration, are you using the cabled antenna, no antenna, > something else? Any issues with the control module receiving the toad > signals. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > |
05-05-2007, 10:46
I have about 40K miles with a PressurePro system and love it. I have a
M380 and tow a Honda CR-V. I was not able to get reliable readings on the rear tires on the tow using the standard antenna. I installed the cabled antenna inside the coach about 2/3 of the way back. I works very reliably now. I preferred to mount the antenna inside the coach to avoid road hazards with the antenna mounted under the coach. I am sure there are many other options but this works well for me. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Those that have the PressurePro system installed on your 'Bird. What is > your system configuration, are you using the cabled antenna, no antenna, > something else? Any issues with the control module receiving the toad > signals. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > |
05-05-2007, 11:33
Hey i never thought of that mounting under the coach
no more holes in the roof plenty in floor to use Thanaks for the heads up Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Marv & Jean" > > I have about 40K miles with a PressurePro system and love it. I have a > M380 and tow a Honda CR-V. I was not able to get reliable readings on > the rear tires on the tow using the standard antenna. I installed the > cabled antenna inside the coach about 2/3 of the way back. I works > very reliably now. I preferred to mount the antenna inside the coach > to avoid road hazards with the antenna mounted under the coach. I am > sure there are many other options but this works well for me. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > Those that have the PressurePro system installed on your 'Bird. What > is > > your system configuration, are you using the cabled antenna, no > antenna, > > something else? Any issues with the control module receiving the toad > > signals. > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > |
