Air pres gauge &
05-07-2007, 02:21
Air pres gauge &
Thanks to Don Spithaler I found replacing the air governor to be a
relatively easy task. The original was a bendix unit with an adjustable pres. range of 120-160psi and the new one is 105-125psi. I turned the adjustment fully clockwise after install but the gauge still reads ~135psi. There is an orange indicator hand and a green one and only the orange one moves, the green one is stuck at ~145psi. Do I need to replace the gauge? Also, I still need to know where the pickup is located for the boost pressure gauge. |
