Dual Tire Valves
05-10-2007, 03:22
Dual Tire Valves
Hi All,
Does anyone have good supplier on heavy duty brass or chrome inside dual tire valves of different lengths. Also a heavy duty chrome straight and C curved valve for outer dual and other tires. Howard Truitt Camilla, Ga. 86 PT40 |
05-12-2007, 11:45
Dual Tire Valves
Howard I have found a source for really nice valve stems and ordered
enough to replace all of mine. I chose them because of the type of seal which does not deteriorate due to UV. Remember you need the valve stems for aluminum wheels. http://tinyurl.com/2hblmj Tom Warner Vernon Center,NY 1984 PT 40 thAt 11:22 AM 5/10/2007, you wrote: >Hi All, >Does anyone have good supplier on heavy duty brass or chrome inside >dual tire valves of different lengths. Also a heavy duty chrome >straight and C curved valve for outer dual and other tires. >Howard Truitt >Camilla, Ga. >86 PT40 > > > > > >Yahoo! Groups Links > > > |
05-13-2007, 03:03
Dual Tire Valves
Tom,
As usual "Your the Man". Thanks, Howard Truitt Camilla, Ga. 86 PT40 > > From: Tom Warner > Date: 2007/05/12 Sat PM 07:45:56 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Dual Tire Valves > > Howard I have found a source for really nice valve stems and ordered > enough to replace all of mine. I chose them because of the type of > seal which does not deteriorate due to UV. Remember you need the > valve stems for aluminum wheels. http://tinyurl.com/2hblmj > > > Tom Warner > Vernon Center,NY > 1984 PT 40 > > > > > thAt 11:22 AM 5/10/2007, you wrote: > >Hi All, > >Does anyone have good supplier on heavy duty brass or chrome inside > >dual tire valves of different lengths. Also a heavy duty chrome > >straight and C curved valve for outer dual and other tires. > >Howard Truitt > >Camilla, Ga. > >86 PT40 > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > |
05-14-2007, 08:32
Dual Tire Valves
Howard will call you in just a minute. Here is the picture of the
charger ckt for the generator. Will describe it to you using schematic tom |
