EMS is Up & Working
05-12-2007, 10:36
EMS is Up & Working
Today I finally got back to the EMS (Electrical Management System)
install, finished the wiring. All is purring like it's suppose too.The monitor display shows the same as the dash gauges. I need to buy the longer cable to reach the front of the coach so the monitor can be mounted in the upper dash area. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
05-13-2007, 04:18
EMS is Up & Working
Curt,
I put my remote inside the TV switch/amp. area. I did make up a new wire for it. Not fun getting by the shower area. Be careful when making up a new wire for the remote. It is not like a telephone connection. Look at the one supplied and follow the colors. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Curt Sprenger To: wanderlodge@yahoogroups.com WanderlodgeForum@yahoogroups.com Sent: Saturday, May 12, 2007 3:36 PM Subject: [WanderlodgeForum] EMS is Up & Working Today I finally got back to the EMS (Electrical Management System) install, finished the wiring. All is purring like it's suppose too.The monitor display shows the same as the dash gauges. I need to buy the longer cable to reach the front of the coach so the monitor can be mounted in the upper dash area. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
05-13-2007, 05:44
EMS is Up & Working
Curt if you do need extra cable length the Progressive folks do provide that
option On 13/05/07, Richard Hayden > > Curt, > I put my remote inside the TV switch/amp. area. I did make up a new wire > for it. Not fun getting by the shower area. Be careful when making up a new > wire for the remote. It is not like a telephone connection. Look at the one > supplied and follow the colors. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: Curt Sprenger > > To: wanderlodge@yahoogroups.com > WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, May 12, 2007 3:36 PM > Subject: [WanderlodgeForum] EMS is Up & Working > > Today I finally got back to the EMS (Electrical Management System) > install, finished the wiring. All is purring like it's suppose too.The > monitor display shows the same as the dash gauges. I need to buy the > longer cable to reach the front of the coach so the monitor can be > mounted in the upper dash area. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-13-2007, 08:00
EMS is Up & Working
I contacted Progressive a while back. They said you can purchase any
fax machine RJ-11 type cable to use, as it is a straight through design on the connectors. Do not use a phone cable, they cross the wire connectors. Dan 94 BB BMC 37' --- In WanderlodgeForum@yahoogroups.com, "Rob Robinson" > > Curt if you do need extra cable length the Progressive folks do provide that > option > > On 13/05/07, Richard Hayden > > > > Curt, > > I put my remote inside the TV switch/amp. area. I did make up a new wire > > for it. Not fun getting by the shower area. Be careful when making up a new > > wire for the remote. It is not like a telephone connection. Look at the one > > supplied and follow the colors. > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > ----- Original Message ----- > > From: Curt Sprenger > > > > To: wanderlodge@yahoogroups.com > > WanderlodgeForum@yahoogroups.com > > > > > > Sent: Saturday, May 12, 2007 3:36 PM > > Subject: [WanderlodgeForum] EMS is Up & Working > > > > Today I finally got back to the EMS (Electrical Management System) > > install, finished the wiring. All is purring like it's suppose too.The > > monitor display shows the same as the dash gauges. I need to buy the > > longer cable to reach the front of the coach so the monitor can be > > mounted in the upper dash area. > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
05-13-2007, 08:22
EMS is Up & Working
Yes that's what I've heard too
On 13/05/07, ac7880 > > I contacted Progressive a while back. They said you can purchase any > fax machine RJ-11 type cable to use, as it is a straight through > design on the connectors. Do not use a phone cable, they cross the > wire connectors. > > Dan > 94 BB BMC 37' > > --- In WanderlodgeForum@yahoogroups.com > "Rob Robinson" > > > > > Curt if you do need extra cable length the Progressive folks do > provide that > > option > > > > On 13/05/07, Richard Hayden > > > > > > Curt, > > > I put my remote inside the TV switch/amp. area. I did make up a > new wire > > > for it. Not fun getting by the shower area. Be careful when > making up a new > > > wire for the remote. It is not like a telephone connection. Look > at the one > > > supplied and follow the colors. > > > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > ----- Original Message ----- > > > From: Curt Sprenger > > > > > > To: wanderlodge@yahoogroups.com > > > WanderlodgeForum@yahoogroups.com > > > > > > > > > > Sent: Saturday, May 12, 2007 3:36 PM > > > Subject: [WanderlodgeForum] EMS is Up & Working > > > > > > Today I finally got back to the EMS (Electrical Management System) > > > install, finished the wiring. All is purring like it's suppose > too.The > > > monitor display shows the same as the dash gauges. I need to buy > the > > > longer cable to reach the front of the coach so the monitor can be > > > mounted in the upper dash area. > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > -- > > Rob, Sue & Merlin Robinson > > 94 WLWB > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
