Good Mornin on This Fine Day
05-14-2007, 21:45
A quick problem and hopefully some
"solution oriented direction." ( I can spit out those Fancy phrases,
but no luck at remebering how to find a fuel blockage)
Issue:
Cat won't start, has done this every other Spring and in fact was the
issue that got me turned on to the unit in the first place.In
retrospect I think it might have been An Evil Omen sent by the Demons
of The Sticks and Staples crowd.
So far
Per Bennnie, Checked A/T switch and cleaned cables, replaced any Iffy
( tech term for crap maintenance).Got first lesson in Master
Electrical Disconnect.Traced wiring and found and replaced two
Thermal O/L's that were not reseting. Proud moment on that Snowy Hill
when The 3208 fired, kept running and I made Maiden Bluebird voyage
home
Started and ran like a sewing macine and only took Three ratchet
straps to keep the loose stuff attached until I got home. Going to be
a lot nicer to pilot, just as soon as I figure out some heat.
Fast forward six months or so. Same Symptoms, same results, after
glass replacement completed.
Per Mike H., recheckd all earlier areas.Replaced ignition switch and
no change, so decided time for a lttle OJT, self taught, In the
parking lot. That Racor thing I was hearing folk allude to. 4
tries later am now a Racor Master Tech and cleaned up spilled diesel
and drove it home.
Fast forward to last week, new deep cycle batteries, Cables and
grounds. Yeppers, thats right wont start. Will fire right up with
short snort of Ether. ( warning duly noted about evils of that
Dastardly Stuff) Racor gage slightly above zero.
I think I need to check fuel shut off solenoid and check every
component from the fuel pump, to and through ejectors and back to the
tank(s)and back to the solenoid via the Racor. I stored the unit with
tanks filled and treated with some Truck Stop stabilizer. Think all I
should consider doing to fuel system is topping off by hand carying
fuel until filled again. One of the tanks is showing empty on the
gage.
Will consider bestowing Knighthood/ Sainthood, one box of wine at a
time, to person/ persons unknown that can help me regulate this
problem to the cutesy story area of (The Tale Of The Day I switched
from gasoline SOB's to A Bluebird Diesel Puller. All previous
experience with diesels was limited to My Backyard Backhoe). My
advance apologies If I ramble, but the drugs from The VA have got a
brain Fog grip.
DrDigger
83FC35
Kansas City Bo
05-15-2007, 00:19
Sounds like your problem could be as simple as air getting into your
fuel system. Check to make sure filters are tight as a starter. Also
check to see if the filters are full of fuel. If not, that could
indicate that air is leaking into the system.
I'm sure it could be something else also, but that's a good place to
start.
--- In WanderlodgeForum@yahoogroups.com, "glennshehorn"
> Issue:
> So far
> home
> and drove it home.
> gage.
> brain Fog grip.
> DrDigger
> 83FC35
> Kansas City Bo
