Newcomer Questions
05-16-2007, 16:48
Newcomer Questions
Hello to All,
My wife and I are now in our early sixties and are seriously contemplating full-timing for a few years. We anticipate spending much of the winter well south of the Mason-Dixon and summers in the northeast. We'd probably put approximately two to three thousand miles a year on any rig purchased. I have long admired the BlueBird approach to RVing; however, I must admit that my knowledge in this area is shallow at best. My wife and I would greatly appreciate any comments from current full-timers regarding years and models to look for as well as features that are considered truly indispensable. When considering any used unit, are there problem areas that consistently appear and for which we definitely should be on the lookout? Also, we are determined to avoid purchasing more vehicle than is necessary. Generally speaking, what minimum size seems to function properly for most full-timers and provide the best compromise between convenience and maneuverability? Anyone wishing to offer rough estimates on annual utility costs are encouraged to do so. Thanks in advance to anyone willing to take the time and make the effort. Allen Jarvis Merchantville, N.J. |
05-17-2007, 06:08
Newcomer Questions
--- In WanderlodgeForum@yahoogroups.com, "skip_slade" <skip@...>
wrote: > > Hello to All, > > My wife and I are now in our early sixties and are seriously > contemplating full-timing for a few years. [deletia] Hi Allan and Co, I am a BB wannabee but only after more than a year of research. (I have been accused of over-analysing things a tad.) I will be purchasing one as soon as I have a better grasp on when I will be retiring: this year or next. I will try to share some thoughts with you that I have been through and which have been shared with me by generous seasoned veterans. 1. First of all, no one here or anywhere else can tell you what is the "best" choice for fulltiming. There are folks fulltiming in just about every shape and flavour or rig you can imagine. So, you just have to put your head down and start researching and testing. 2. If you haven't done any RVing, do some with rental equipment before you invest $$$$ in something you and your wife don't like. 3. What style of RV do you want? Motorhome - class A diesel pusher - class A diesel forward control - class A gas forward control - class C - class C + - class B Trailer - pull behind - fifth wheel Generally speaking, motorhomes are better for folks who are on the move a lot (which, from your message doesn't sound like you) and trailers are better for folks who go somewhere and stay put for extended periods. But this is a generalisation and not a RULE. Bear in mind that choosing a motorhome will not necessarily eliminate the need to tow something since you will possibly want something other than a 15 - 20 ton bus to go out to pick up a quart of milk. So, you may need to tow a "dingy" (what the cognocenti refer to as a "towed"). For this reason, some folks choose a smallish class C, say under 28 feet and no towed. This too has its problems since you must unhook everything to go shopping or sightseeing. With a trailer, once you unhook, you have your drive-around vehicle. Now, if you have a trailer of any significant size, it's probably at least a 3/4 ton or bigger truck. Some fifth wheels in the 30'plus size require nothing smaller than a one ton. The 40 footers need medium duty trucks like the Freightligner Fl60 or Sportchassis. These are seriously big vehicles, costing serious $$$$. 4. If you've been through all this and KNOW that you want a motorhome and that it should be a BB (congratulations on your good taste), the next decision you need to make is how much you should invest in your first "bird". 5. Once that is set out deduct about $10,000 from that. The remainder is what you have to check out, collect, licence and pay for your vehicle. The $10K is for the first two years' expenses to fix, replace and/or upgrade the vehicle to suit _your_ needs. 6. Next, do you want a forward control (engine in front) or a pusher (engine in the back)? There are pros and cons to each. Do some research - there will be a test. ;-) Hint: read everything at http://www.vintagebirds.com. Read at least a years' worth of messages here. Preferably, scan everything. 7. Do you want to have access to state/provincial parks? If so, you probably want something in the 35/36' size as a maximum. 8. As for size with respect to manouverability, once you get up to 35 feet, incremental length isn't such a big deal, IMHO. I've driven vehicles up to 45 feet profesionally and to be honest, 45 feet just doesn't feel that much bigger than 35 feet. Access to parks etc is a much bigger issue. If you're driving a 40-45 foot rig, you're probably looking for large commercial "destination" type parks and those generally have pull-through sites. One thing to remember when you're driving something BIG is never to go down a road unless you KNOW that you can exit (either by going around a block, making a U-turn (make sure you know how big your vehicle's turning circle is), or turning around in a large open area). The last thing you want to do is to have to back up 5 miles along a rutted, dirt road to get back to civilisation. You cannot back up with your towed attached. It must be disconnected. 9. For full-timers, size is of some important since this is your home 24/7 but, keep in mind that where ever you are, you have the whole outdoors to "live". The weather will always be temperate so you aren't locked indoors. Many folks set up very comfortable outdoor "rooms" under their large awning. If you feel the need to sulk or to get away by yourself, it's not difficult. You also now have the time to bicycle or hike. Visit with the neighbours. Take crafting/dancing/RV repair classes... well you get the idea. Drive around to see the sights. Storage is better in the pushers than in the forward controls. Mainly in the basement bins. 10. Operating costs, well.... there probably is a correlation between age of vehicle and costs. But, I suspect that your diligence regarding PM is a bigger factor in the long run. Blue Birds are complicated beasts. There are lots of things that can break. Most vehicles that I've looked into have many things that do not work and haven't for a long time with the owner having no intention of fixing them. If you are the kind of person where everything must be perfect, you will have higher costs than a more fault tolerant person. A good example is the dash air. Many coaches have been used for years with no dash air, cooling instead with the forward A/C unit running off the genny. But there are other things that cannot be ignored. For example, if you purchase an older rig it will probably have the Caterpiller 3208 engine. You must attend to valve adjustments on this engine. Leaving this job too long will begin with increasingly degraded engine performance right up until a valve snaps off and falls onto a piston. Unless you have a close relative who is a diesel mechanic, say hello to a major engine overhaul and bye bye to a lot of money. For myself, I'm budgeting about $1,500 annual PM costs. (After the initial $10K) Anyway, I've certainly wasted way too much bandwidth. If you find it interesting, I've considered fivers, class C's and finally decided on a BB, specifically a forward control, 35 feet in length from the years 85 - 89. I want a side bath and a full-size side bed. I would prefer 87 - 89 but money will probably dictate an 85 or 86. Fine print. This barely skims the surface and is entirely my opinion. Make sure you get lots of opinions, do tons of research and form your own opinion. Then... have fun. Cheers, Ginger BB wannabee 85FC35 |
05-17-2007, 08:06
Newcomer Questions
--- In WanderlodgeForum@yahoogroups.com, "runnerful"
> Fine print. This barely skims the surface and is entirely my > opinion. Make sure you get lots of opinions, do tons of research > and form your own opinion. Then... have fun. Ginger, Thanks for your excellent post. While I realize that generalizations are a poor choice for direct extensive experience, the reality is that it would take years to carefully explore all BB possibilities personally. Most of the older units I've seen advertised are not within a realistic day's journey from Southern N.J. Seeing, examining, and driving all the basic engine and drive train configurations in these older BBs would take some doing, particularly when you factor in the condition criterion. When you start mixing in room layouts, etc., it really gets wild. We're simply attempting to narrow the field just a bit. I would imagine that there are more than a few individuals who have full- timed over a number of years in a variety of different Birds. There may well be strong similarities in what they prefer or must have in such a vehicle. This information would be of value to anyone starting his or her search for a BB. Then again, perhaps not. ![]() Thanks again for your fine effort. -- Regards, Allen |
05-17-2007, 12:12
Newcomer Questions
Allen,
Have you checked out: http://www.vintagebirds.com/ history section yet? You can click on each year, and also click on changes per year. That would be a start on different layouts and years. http://www.birdconnection.com/ has some pics and some "asking" prices, and that may also help. If you see some that fit your fancy, tell us what models and years might work for you, and we can offer further advice. Regards, Dan 94 BB BMC 37' --- In WanderlodgeForum@yahoogroups.com, "skip_slade" <skip@...> wrote: > > Hello to All, > > My wife and I are now in our early sixties and are seriously > contemplating full-timing for a few years. We anticipate spending > much of the winter well south of the Mason-Dixon and summers in the > northeast. We'd probably put approximately two to three thousand > miles a year on any rig purchased. > > I have long admired the BlueBird approach to RVing; however, I must > admit that my knowledge in this area is shallow at best. My wife and > I would greatly appreciate any comments from current full-timers > regarding years and models to look for as well as features that are > considered truly indispensable. When considering any used unit, are > there problem areas that consistently appear and for which we > definitely should be on the lookout? > > Also, we are determined to avoid purchasing more vehicle than is > necessary. Generally speaking, what minimum size seems to function > properly for most full-timers and provide the best compromise between > convenience and maneuverability? Anyone wishing to offer rough > estimates on annual utility costs are encouraged to do so. > > Thanks in advance to anyone willing to take the time and make the > effort. > > Allen Jarvis > Merchantville, N.J. > |
05-19-2007, 19:16
Newcomer Questions
Allen,
I haven't had my bird a month yet and have never full timed in an RV, so take everything I say with a huge grain of salt. That said: I bought a PT-40 and I'm very glad I did. I wouldn't want anything smaller, to be honest, not for the weekend warrior type camping I plan to do and certainly not for full timing. I'm the type who likes to be prepared and independent. I don't like looking for a laundromat and then waiting around several hours to wash my clothes. I like having huge storage tanks so I can fill up once and not deal with it for the next thousand miles. I shop at Costco so I always have thirty extra rolls of toilet paper handy and eight huge, juicy steaks in my freezer. If we didn't have kids at home, my wife and I could full time in this RV (as soon as I add that washer/dryer). No problem. Anything smaller, no way. This one's big enough for two people and their stuff and all of the amenities and it has amazing fuel, water, & holding capacities, not to mention more storage than I know what to do with. Now, I know many people full time in smaller vehicles and use laundromats and so on but I'm not one of them. I like my privacy, my independence, and the feeling of security I get from being fully stocked up and able to last for long(er) periods of time without help from the world. (It's part convenience, part paranoia.) Certainly there are downsides to the larger vehicle (more expensive to buy and operate, can't get in to some parks, slightly more difficult to maneuver, etc) but for me, the pluses far, far outweigh the minuses. BTW, I talked to a guy down the street who has been full timing in a PT-40 for several years and he loves it. After having mine, even for such a short time, I can fully see why. This size vehicle is very livable with few, if any, sacrifices necessary. -Ryan '86 PT-40 8V92 Tri-Cities, WA On 5/16/07, skip_slade <skip@...> wrote: > > Hello to All, > > My wife and I are now in our early sixties and are seriously > contemplating full-timing for a few years. We anticipate spending > much of the winter well south of the Mason-Dixon and summers in the > northeast. We'd probably put approximately two to three thousand > miles a year on any rig purchased. > > I have long admired the BlueBird approach to RVing; however, I must > admit that my knowledge in this area is shallow at best. My wife and > I would greatly appreciate any comments from current full-timers > regarding years and models to look for as well as features that are > considered truly indispensable. When considering any used unit, are > there problem areas that consistently appear and for which we > definitely should be on the lookout? > > Also, we are determined to avoid purchasing more vehicle than is > necessary. Generally speaking, what minimum size seems to function > properly for most full-timers and provide the best compromise between > convenience and maneuverability? Anyone wishing to offer rough > estimates on annual utility costs are encouraged to do so. > > Thanks in advance to anyone willing to take the time and make the > effort. > > Allen Jarvis > Merchantville, N.J. |
05-19-2007, 22:40
Newcomer Questions
Ryan I agree with you except for the washer/dryer. We have never had to wait
at a laundromat. In fact we use campground facilities and there has never in our three years of full-timing been a problem in that regard. The first thing I did was throw that Splendid out the front door. I now use the available space for storage and a large laundry hamper. The hamper, like my tanks, let's us go a long time between 'wash Mondays' and when we chose to do a wash it is done much faster in a campground laundromat. Having said this you could put an apartment style washer/dryer in but I believe the dryer would be slower than taking it to a regular laundry. On 20/05/07, Ryan Wright > > Allen, > > I haven't had my bird a month yet and have never full timed in an RV, > so take everything I say with a huge grain of salt. That said: > > I bought a PT-40 and I'm very glad I did. I wouldn't want anything > smaller, to be honest, not for the weekend warrior type camping I plan > to do and certainly not for full timing. I'm the type who likes to be > prepared and independent. I don't like looking for a laundromat and > then waiting around several hours to wash my clothes. I like having > huge storage tanks so I can fill up once and not deal with it for the > next thousand miles. I shop at Costco so I always have thirty extra > rolls of toilet paper handy and eight huge, juicy steaks in my > freezer. > > If we didn't have kids at home, my wife and I could full time in this > RV (as soon as I add that washer/dryer). No problem. Anything smaller, > no way. This one's big enough for two people and their stuff and all > of the amenities and it has amazing fuel, water, & holding capacities, > not to mention more storage than I know what to do with. Now, I know > many people full time in smaller vehicles and use laundromats and so > on but I'm not one of them. I like my privacy, my independence, and > the feeling of security I get from being fully stocked up and able to > last for long(er) periods of time without help from the world. (It's > part convenience, part paranoia.) > > Certainly there are downsides to the larger vehicle (more expensive to > buy and operate, can't get in to some parks, slightly more difficult > to maneuver, etc) but for me, the pluses far, far outweigh the > minuses. > > BTW, I talked to a guy down the street who has been full timing in a > PT-40 for several years and he loves it. After having mine, even for > such a short time, I can fully see why. This size vehicle is very > livable with few, if any, sacrifices necessary. > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > On 5/16/07, skip_slade <skip@... <skip%40ajarvis.net>> wrote: > > > > Hello to All, > > > > My wife and I are now in our early sixties and are seriously > > contemplating full-timing for a few years. We anticipate spending > > much of the winter well south of the Mason-Dixon and summers in the > > northeast. We'd probably put approximately two to three thousand > > miles a year on any rig purchased. > > > > I have long admired the BlueBird approach to RVing; however, I must > > admit that my knowledge in this area is shallow at best. My wife and > > I would greatly appreciate any comments from current full-timers > > regarding years and models to look for as well as features that are > > considered truly indispensable. When considering any used unit, are > > there problem areas that consistently appear and for which we > > definitely should be on the lookout? > > > > Also, we are determined to avoid purchasing more vehicle than is > > necessary. Generally speaking, what minimum size seems to function > > properly for most full-timers and provide the best compromise between > > convenience and maneuverability? Anyone wishing to offer rough > > estimates on annual utility costs are encouraged to do so. > > > > Thanks in advance to anyone willing to take the time and make the > > effort. > > > > Allen Jarvis > > Merchantville, N.J. > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-20-2007, 03:50
Newcomer Questions
The washer/dryer argument will never end, but being on the Splendide side I find
it amusing that the slowness of its dry cycle is ever an argument. I see it this way. Laundromat: Dry in 20 minutes Splendide: Dry in 60 minutes Laundromat: Wait 20 minutes for it to dry. Splendide: Wait zero minutes for it to dry. Same for the wash part, not to mention the time to haul the clothes somewhere. When the W/D is in your own house, it takes up none of your time to wash and dry, regardless of the chronological time spent by the machine. On 5/20/2007 at 3:40 AM Rob Robinson wrote: >Ryan I agree with you except for the washer/dryer. We have never had to >wait >at a laundromat. In fact we use campground facilities and there has never >in >our three years of full-timing been a problem in that regard. The first >thing I did was throw that Splendid out the front door. I now use the >available space for storage and a large laundry hamper. The hamper, like my >tanks, let's us go a long time between 'wash Mondays' and when we chose to >do a wash it is done much faster in a campground laundromat. Having said >this you could put an apartment style washer/dryer in but I believe the >dryer would be slower than taking it to a regular laundry. |
05-20-2007, 04:33
Newcomer Questions
I hear ya Don but you got to admit to do a large wash in a Splendid you have
to spend all day with many loads or many days with single loads waiting zero minutes to do the wash. Then you have to do the zero minute thing all over again to accomplish the drying. At least you get your exercise I guess VBG. You are also right that the washer/dryer thing is like tires and batteries. A never-ending source or conjecture. On 20/05/07, Don Bradner > > The washer/dryer argument will never end, but being on the Splendide > side I find it amusing that the slowness of its dry cycle is ever an > argument. I see it this way. > > Laundromat: Dry in 20 minutes > Splendide: Dry in 60 minutes > Laundromat: Wait 20 minutes for it to dry. > Splendide: Wait zero minutes for it to dry. > > Same for the wash part, not to mention the time to haul the clothes > somewhere. When the W/D is in your own house, it takes up none of your time > to wash and dry, regardless of the chronological time spent by the machine. > > On 5/20/2007 at 3:40 AM Rob Robinson wrote: > > >Ryan I agree with you except for the washer/dryer. We have never had to > >wait > >at a laundromat. In fact we use campground facilities and there has never > >in > >our three years of full-timing been a problem in that regard. The first > >thing I did was throw that Splendid out the front door. I now use the > >available space for storage and a large laundry hamper. The hamper, like > my > >tanks, let's us go a long time between 'wash Mondays' and when we chose > to > >do a wash it is done much faster in a campground laundromat. Having said > >this you could put an apartment style washer/dryer in but I believe the > >dryer would be slower than taking it to a regular laundry. > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-20-2007, 04:35
Newcomer Questions
---Ryan:
For us,....a washer/dryer is a MUST in our bird. We had a Splendide 5200 and a 6200 in each of our birds and they are fine...we do a bit of washing each day as they do not take a large load. To us, functional utility of the space used by the Splendide is better utilized with the washer/dryer v. storage "stuff." I have never been able to get over the "doggy rugs" etc. in the campground laundramats. LOL, Hank Hannigan..still chillin in Vegas 90SP36 In WanderlodgeForum@yahoogroups.com, "Rob Robinson" wrote: > > Ryan I agree with you except for the washer/dryer. We have never had to wait > at a laundromat. In fact we use campground facilities and there has never in > our three years of full-timing been a problem in that regard. The first > thing I did was throw that Splendid out the front door. I now use the > available space for storage and a large laundry hamper. The hamper, like my > tanks, let's us go a long time between 'wash Mondays' and when we chose to > do a wash it is done much faster in a campground laundromat. Having said > this you could put an apartment style washer/dryer in but I believe the > dryer would be slower than taking it to a regular laundry. > > On 20/05/07, Ryan Wright > > > > Allen, > > > > I haven't had my bird a month yet and have never full timed in an RV, > > so take everything I say with a huge grain of salt. That said: > > > > I bought a PT-40 and I'm very glad I did. I wouldn't want anything > > smaller, to be honest, not for the weekend warrior type camping I plan > > to do and certainly not for full timing. I'm the type who likes to be > > prepared and independent. I don't like looking for a laundromat and > > then waiting around several hours to wash my clothes. I like having > > huge storage tanks so I can fill up once and not deal with it for the > > next thousand miles. I shop at Costco so I always have thirty extra > > rolls of toilet paper handy and eight huge, juicy steaks in my > > freezer. > > > > If we didn't have kids at home, my wife and I could full time in this > > RV (as soon as I add that washer/dryer). No problem. Anything smaller, > > no way. This one's big enough for two people and their stuff and all > > of the amenities and it has amazing fuel, water, & holding capacities, > > not to mention more storage than I know what to do with. Now, I know > > many people full time in smaller vehicles and use laundromats and so > > on but I'm not one of them. I like my privacy, my independence, and > > the feeling of security I get from being fully stocked up and able to > > last for long(er) periods of time without help from the world. (It's > > part convenience, part paranoia.) > > > > Certainly there are downsides to the larger vehicle (more expensive to > > buy and operate, can't get in to some parks, slightly more difficult > > to maneuver, etc) but for me, the pluses far, far outweigh the > > minuses. > > > > BTW, I talked to a guy down the street who has been full timing in a > > PT-40 for several years and he loves it. After having mine, even for > > such a short time, I can fully see why. This size vehicle is very > > livable with few, if any, sacrifices necessary. > > > > -Ryan > > '86 PT-40 8V92 > > Tri-Cities, WA > > > > On 5/16/07, skip_slade <skip@... <skip%40ajarvis.net>> wrote: > > > > > > Hello to All, > > > > > > My wife and I are now in our early sixties and are seriously > > > contemplating full-timing for a few years. We anticipate spending > > > much of the winter well south of the Mason-Dixon and summers in the > > > northeast. We'd probably put approximately two to three thousand > > > miles a year on any rig purchased. > > > > > > I have long admired the BlueBird approach to RVing; however, I must > > > admit that my knowledge in this area is shallow at best. My wife and > > > I would greatly appreciate any comments from current full-timers > > > regarding years and models to look for as well as features that are > > > considered truly indispensable. When considering any used unit, are > > > there problem areas that consistently appear and for which we > > > definitely should be on the lookout? > > > > > > Also, we are determined to avoid purchasing more vehicle than is > > > necessary. Generally speaking, what minimum size seems to function > > > properly for most full-timers and provide the best compromise between > > > convenience and maneuverability? Anyone wishing to offer rough > > > estimates on annual utility costs are encouraged to do so. > > > > > > Thanks in advance to anyone willing to take the time and make the > > > effort. > > > > > > Allen Jarvis > > > Merchantville, N.J. > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > > [Non-text portions of this message have been removed] > |
05-20-2007, 04:54
Newcomer Questions
The usage pattern with a Splendide is definitely different than when you have
high-capacity W/Ds available, but it is not hard to get in a habit of one or two loads per day that don't interfere with anything else you might be doing (except driving!). The zero minutes waiting for wash and zero minutes waiting for dry are concurrent, since the machine does both automatically. Don Bradner 90 PT40 "Blue Thunder" Posting on the road by satellite from Portland, Oregon On 5/20/2007 at 9:33 AM Rob Robinson wrote: >I hear ya Don but you got to admit to do a large wash in a Splendid you >have >to spend all day with many loads or many days with single loads waiting >zero >minutes to do the wash. Then you have to do the zero minute thing all over >again to accomplish the drying. At least you get your exercise I guess VBG. >You are also right that the washer/dryer thing is like tires and batteries. >A never-ending source or conjecture. > >On 20/05/07, Don Bradner >> >> The washer/dryer argument will never end, but being on the Splendide >> side I find it amusing that the slowness of its dry cycle is ever an >> argument. I see it this way. >> >> Laundromat: Dry in 20 minutes >> Splendide: Dry in 60 minutes >> Laundromat: Wait 20 minutes for it to dry. >> Splendide: Wait zero minutes for it to dry. >> >> Same for the wash part, not to mention the time to haul the clothes >> somewhere. When the W/D is in your own house, it takes up none of your >time >> to wash and dry, regardless of the chronological time spent by the >machine. |
