1980 35FC won't start via the ignition, please help
05-16-2007, 21:21
John, I wonder if your ignition key switch is bad?
Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-16-2007, 21:49
John I had a problem like that a couple of years ago & & couldn't figure
it out till I was under the coach & did the same as you did. When I touched the solenoid a 14 gauge wire coming from a fuse block in the engine compartment dropped off the solenoid. It was completely corroded off. We had just returned from AZ couple of months before that. Don 89 SP 36' Butler, PA The name showing is Adria, who is my fair and lovely bride. I hijacked her ID to ask for help and my name is John. I'm more of a lurker than anything else, and I HAVE used the search function and done some reading, but I still need some help very badly. Please help if you can. We have a 1980 35FC. The batteries are new and charged, but when you hit the key there is nothing going on. My hots and grounds are good at the starter, but not at the solenoid when the key is in the start position. I was able to start it by jumping the hot over to the solenoid and despite having just been sitting there for MONTHS, the ole sweetie fired right up and just purred like a sewing machine. So, I've since spoken with a few people who thought that it could be a neutral safety switch on the trans. Remembering my dad had a similar problem on an old motorhome he had, I used his method and ran the shifter back and forth about 30 times in a lazy man's attempt to gain a conection at said switch. Much to nobody's surprise, that did not help. I opened up the panel at nose of the bus (by my feet) and I see that there is the most wonderful rainbow of wiring I could have ever expected, and 3 or 4 solenoids down there as well. All those solenoids show to be hot on all posts except for the ones that are supposed to be ground. The scematic, although in greek, shows fuses and circuit breakers. I gather that the wiring in the nose is what it's referring to as the circuit breakers, but with the key on - every one of them shows hot as I would have expected, and I cannot for the LIFE of me locate a fuse panel for the chassis. As you know, there are a few fuses in the battery area, a few in the overhead area, and I can't find any others. So now that you know a little about what I have going on, I would GREATLY appreciate any and all advice you kind folks could offer. I'm told that there is a relay that comes BEFORE the starter solenoid, but I can't seem to locate it - or even if I was staring at it, I wouldn't know what it is. DO you know where it is and/or how to check it? Please don't laugh, but is there even a chassis fuse panel for me to check a starter fuse on - or is that about as "noob" as saying that I can't find the carburator under the hood? If there IS a fuse panel - where, in the name of all things holy, are they hiding the dang thing??!! ![]() I really need to get this baby going via the key ASAP. We have Memorial day reservations and I'd rather not have to hotwire it to go to and from - but if it's between that and telling the wife and kids that we aren't going camping, you know I'll be under there rain or shine. I'm sure that the end solution to this problem will most likely be laughable, but until then, I really need help and it doesn't seem very amusing just yet. Thanks in advance and I will try to reply ASAP with any return questions that you may have for me. Peace, John ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-17-2007, 01:16
hijacked her ID to ask for help and my name is John. I'm more of a lurker than anything else, and I HAVE used the search function and done some reading, but I still need some help very badly. Please help if you can. We have a 1980 35FC. The batteries are new and charged, but when you hit the key there is nothing going on. My hots and grounds are good at the starter, but not at the solenoid when the key is in the start position. I was able to start it by jumping the hot over to the solenoid and despite having just been sitting there for MONTHS, the ole sweetie fired right up and just purred like a sewing machine. So, I've since spoken with a few people who thought that it could be a neutral safety switch on the trans. Remembering my dad had a similar problem on an old motorhome he had, I used his method and ran the shifter back and forth about 30 times in a lazy man's attempt to gain a conection at said switch. Much to nobody's surprise, that did not help. I opened up the panel at nose of the bus (by my feet) and I see that there is the most wonderful rainbow of wiring I could have ever expected, and 3 or 4 solenoids down there as well. All those solenoids show to be hot on all posts except for the ones that are supposed to be ground. The scematic, although in greek, shows fuses and circuit breakers. I gather that the wiring in the nose is what it's referring to as the circuit breakers, but with the key on - every one of them shows hot as I would have expected, and I cannot for the LIFE of me locate a fuse panel for the chassis. As you know, there are a few fuses in the battery area, a few in the overhead area, and I can't find any others. So now that you know a little about what I have going on, I would GREATLY appreciate any and all advice you kind folks could offer. I'm told that there is a relay that comes BEFORE the starter solenoid, but I can't seem to locate it - or even if I was staring at it, I wouldn't know what it is. DO you know where it is and/or how to check it? Please don't laugh, but is there even a chassis fuse panel for me to check a starter fuse on - or is that about as "noob" as saying that I can't find the carburator under the hood? If there IS a fuse panel - where, in the name of all things holy, are they hiding the dang thing??!! ![]() I really need to get this baby going via the key ASAP. We have Memorial day reservations and I'd rather not have to hotwire it to go to and from - but if it's between that and telling the wife and kids that we aren't going camping, you know I'll be under there rain or shine. I'm sure that the end solution to this problem will most likely be laughable, but until then, I really need help and it doesn't seem very amusing just yet. Thanks in advance and I will try to reply ASAP with any return questions that you may have for me. Peace, John |
05-17-2007, 01:22
Morning John:
Try switching the A/T switch in the center of the lower upper dash panel. Safe travels, Ralph and Charolette Fullenwider 84FC35 Ralph's RV Solutions, Duncan, Oklahoma At 01:16 PM 5/17/2007 +0000, you wrote: >The name showing is Adria, who is my fair and lovely bride. I >hijacked her ID to ask for help and my name is John. > >I'm more of a lurker than anything else, and I HAVE used the search >function and done some reading, but I still need some help very >badly. Please help if you can. > >We have a 1980 35FC. The batteries are new and charged, but when you >hit the key there is nothing going on. My hots and grounds are good >at the starter, but not at the solenoid when the key is in the start >position. I was able to start it by jumping the hot over to the >solenoid and despite having just been sitting there for MONTHS, the >ole sweetie fired right up and just purred like a sewing machine. > >So, I've since spoken with a few people who thought that it could be >a neutral safety switch on the trans. Remembering my dad had a >similar problem on an old motorhome he had, I used his method and >ran the shifter back and forth about 30 times in a lazy man's >attempt to gain a conection at said switch. Much to nobody's >surprise, that did not help. > >I opened up the panel at nose of the bus (by my feet) and I see that >there is the most wonderful rainbow of wiring I could have ever >expected, and 3 or 4 solenoids down there as well. All those >solenoids show to be hot on all posts except for the ones that are >supposed to be ground. > >The scematic, although in greek, shows fuses and circuit breakers. >I gather that the wiring in the nose is what it's referring to as >the circuit breakers, but with the key on - every one of them shows >hot as I would have expected, and I cannot for the LIFE of me locate >a fuse panel for the chassis. > >As you know, there are a few fuses in the battery area, a few in the >overhead area, and I can't find any others. > >So now that you know a little about what I have going on, I would >GREATLY appreciate any and all advice you kind folks could offer. > >I'm told that there is a relay that comes BEFORE the starter >solenoid, but I can't seem to locate it - or even if I was staring >at it, I wouldn't know what it is. DO you know where it is and/or >how to check it? > >Please don't laugh, but is there even a chassis fuse panel for me to >check a starter fuse on - or is that about as "noob" as saying that >I can't find the carburator under the hood? If there IS a fuse >panel - where, in the name of all things holy, are they hiding the >dang thing??!! ![]() > >I really need to get this baby going via the key ASAP. We have >Memorial day reservations and I'd rather not have to hotwire it to >go to and from - but if it's between that and telling the wife and >kids that we aren't going camping, you know I'll be under there rain >or shine. > >I'm sure that the end solution to this problem will most likely be >laughable, but until then, I really need help and it doesn't seem >very amusing just yet. Thanks in advance and I will try to reply >ASAP with any return questions that you may have for me. > >Peace, >John > > > |
05-17-2007, 01:35
Center Lower Upper - GOT IT!!
![]() I'll try that as soon as I get home. I looked for switches that looked to be the wrong way, but I could have missed it, and it's very possible one of the kids could have clicked it for me. Thanks. Lets hope that's it! Until then, I'd still love to hear other plans of attack if it isn't. Peace, John --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Morning John: > > Try switching the A/T switch in the center of the lower upper dash panel. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma |
05-17-2007, 02:18
Don,
Thank you. I have been looking all over for something obvious like an eyelet without a wire, etc. I have no idea where ANY fuse block is, but I did give the solenoid wire a tug, and it's secure - and none of the wires behind the flip out nose door have any corrosion at all. I checked every single post there and they were ALL hot with the key on. --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > John I had a problem like that a couple of years ago & & couldn't figure > it out till I was under the coach & did the same as you did. When I touched > the solenoid a 14 gauge wire coming from a fuse block in the engine > compartment dropped off the solenoid. It was completely corroded off. We had just > returned from AZ couple of months before that. > Don > 89 SP 36' > Butler, PA |
05-17-2007, 03:15
Have you tried th A/T Switch?
Jim Riordan 88 WBWL XXV Stuart, Fl. Adria Haynes <mrbeebody@...> wrote: The name showing is Adria, who is my fair and lovely bride. I hijacked her ID to ask for help and my name is John. I'm more of a lurker than anything else, and I HAVE used the search function and done some reading, but I still need some help very badly. Please help if you can. We have a 1980 35FC. The batteries are new and charged, but when you hit the key there is nothing going on. My hots and grounds are good at the starter, but not at the solenoid when the key is in the start position. I was able to start it by jumping the hot over to the solenoid and despite having just been sitting there for MONTHS, the ole sweetie fired right up and just purred like a sewing machine. So, I've since spoken with a few people who thought that it could be a neutral safety switch on the trans. Remembering my dad had a similar problem on an old motorhome he had, I used his method and ran the shifter back and forth about 30 times in a lazy man's attempt to gain a conection at said switch. Much to nobody's surprise, that did not help. I opened up the panel at nose of the bus (by my feet) and I see that there is the most wonderful rainbow of wiring I could have ever expected, and 3 or 4 solenoids down there as well. All those solenoids show to be hot on all posts except for the ones that are supposed to be ground. The scematic, although in greek, shows fuses and circuit breakers. I gather that the wiring in the nose is what it's referring to as the circuit breakers, but with the key on - every one of them shows hot as I would have expected, and I cannot for the LIFE of me locate a fuse panel for the chassis. As you know, there are a few fuses in the battery area, a few in the overhead area, and I can't find any others. So now that you know a little about what I have going on, I would GREATLY appreciate any and all advice you kind folks could offer. I'm told that there is a relay that comes BEFORE the starter solenoid, but I can't seem to locate it - or even if I was staring at it, I wouldn't know what it is. DO you know where it is and/or how to check it? Please don't laugh, but is there even a chassis fuse panel for me to check a starter fuse on - or is that about as "noob" as saying that I can't find the carburator under the hood? If there IS a fuse panel - where, in the name of all things holy, are they hiding the dang thing??!! ![]() I really need to get this baby going via the key ASAP. We have Memorial day reservations and I'd rather not have to hotwire it to go to and from - but if it's between that and telling the wife and kids that we aren't going camping, you know I'll be under there rain or shine. I'm sure that the end solution to this problem will most likely be laughable, but until then, I really need help and it doesn't seem very amusing just yet. Thanks in advance and I will try to reply ASAP with any return questions that you may have for me. Peace, John --------------------------------- Get the free Yahoo! toolbar and rest assured with the added security of spyware protection. [Non-text portions of this message have been removed] |
05-17-2007, 03:19
That there solinoid/relay on the frame rail is critical to provide enough
amperage to the cylindrical soliniod on top of the starter. The automotive key switch will not cycle the starter, the relay is required. MH ----- Original Message ----- From: dspithaler@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 7:49 AM Subject: Re: [WanderlodgeForum] 1980 35FC won't start via the ignition, please help John I had a problem like that a couple of years ago & & couldn't figure it out till I was under the coach & did the same as you did. When I touched the solenoid a 14 gauge wire coming from a fuse block in the engine compartment dropped off the solenoid. It was completely corroded off. We had just returned from AZ couple of months before that. Don 89 SP 36' Butler, PA The name showing is Adria, who is my fair and lovely bride. I hijacked her ID to ask for help and my name is John. I'm more of a lurker than anything else, and I HAVE used the search function and done some reading, but I still need some help very badly. Please help if you can. We have a 1980 35FC. The batteries are new and charged, but when you hit the key there is nothing going on. My hots and grounds are good at the starter, but not at the solenoid when the key is in the start position. I was able to start it by jumping the hot over to the solenoid and despite having just been sitting there for MONTHS, the ole sweetie fired right up and just purred like a sewing machine. So, I've since spoken with a few people who thought that it could be a neutral safety switch on the trans. Remembering my dad had a similar problem on an old motorhome he had, I used his method and ran the shifter back and forth about 30 times in a lazy man's attempt to gain a conection at said switch. Much to nobody's surprise, that did not help. I opened up the panel at nose of the bus (by my feet) and I see that there is the most wonderful rainbow of wiring I could have ever expected, and 3 or 4 solenoids down there as well. All those solenoids show to be hot on all posts except for the ones that are supposed to be ground. The scematic, although in greek, shows fuses and circuit breakers. I gather that the wiring in the nose is what it's referring to as the circuit breakers, but with the key on - every one of them shows hot as I would have expected, and I cannot for the LIFE of me locate a fuse panel for the chassis. As you know, there are a few fuses in the battery area, a few in the overhead area, and I can't find any others. So now that you know a little about what I have going on, I would GREATLY appreciate any and all advice you kind folks could offer. I'm told that there is a relay that comes BEFORE the starter solenoid, but I can't seem to locate it - or even if I was staring at it, I wouldn't know what it is. DO you know where it is and/or how to check it? Please don't laugh, but is there even a chassis fuse panel for me to check a starter fuse on - or is that about as "noob" as saying that I can't find the carburator under the hood? If there IS a fuse panel - where, in the name of all things holy, are they hiding the dang thing??!! ![]() I really need to get this baby going via the key ASAP. We have Memorial day reservations and I'd rather not have to hotwire it to go to and from - but if it's between that and telling the wife and kids that we aren't going camping, you know I'll be under there rain or shine. I'm sure that the end solution to this problem will most likely be laughable, but until then, I really need help and it doesn't seem very amusing just yet. Thanks in advance and I will try to reply ASAP with any return questions that you may have for me. Peace, John ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
05-17-2007, 03:30
John since you have done to obvious you will now have to trace the
problem out. I would start by bypassing the neutral saftery switch on the transmission. A jumper with aligator clips is the simplist way to do this. Be very careful getting under the bus. Do not rely ont the air bags or jacks. If that does not do it then you will need to trace out the problem. To save pulling the Ignition switch out prematuraly use a test light or multimeter. have someone hold the key over and see if you get voltage on either side of the neutral safety switch. If you have power there than the problem is the connection to from the neutral saftey harness to the solinoid. If you do not have power there then I would suspect that your ignition switch has given up the ghost. Run a continuity test across the neutral safety switch to make certain that it is good. Then put the wires back on it. Remove the ignition switch so that you can get to the back of it. Leave the wires on it. Try jumping from the battery side to the stater side of the switch if she turns over you have a bad switch. If not you missed something underneath. One last thought... Pull the dash and make sure you are getting a circut throught the A/T switch. Good Luck Jim 83 FC Yorba Linda, ca --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" <mrbeebody@...> wrote: > > Don, > > Thank you. I have been looking all over for something obvious like an > eyelet without a wire, etc. I have no idea where ANY fuse block is, > but I did give the solenoid wire a tug, and it's secure - and none of > the wires behind the flip out nose door have any corrosion at all. I > checked every single post there and they were ALL hot with the key on. > > > --- In WanderlodgeForum@yahoogroups.com, dspithaler@ wrote: > > > > John I had a problem like that a couple of years ago & & > couldn't figure > > it out till I was under the coach & did the same as you did. When I > touched > > the solenoid a 14 gauge wire coming from a fuse block in the engine > > compartment dropped off the solenoid. It was completely corroded > off. We had just > > returned from AZ couple of months before that. > > Don > > 89 SP 36' > > Butler, PA > |
05-17-2007, 03:41
Thanks Jim, Great tips and help - I'll try to give those a try. Can
you give me a quick heads up as to where the neutral safety switch is at on the tranny? Expecting to have to be under theere again, when I started it via hotwire last time, I let it run until the suspension fully aired up. I then stacked 4x4 wood beams under the frame, and in the day that followed - as the bags let out - it settled nicely on the wood - so I do feel very safe under there. Also, again - is there or is there NOT a chassis fuse panel, and if so, where can I find it? --- In WanderlodgeForum@yahoogroups.com, "bluebird3208" wrote: > > John since you have done to obvious you will now have to trace the > problem out. I would start by bypassing the neutral saftery switch > on the transmission. A jumper with aligator clips is the simplist way > to do this. Be very careful getting under the bus. Do not rely ont > the air bags or jacks. If that does not do it then you will need to > trace out the problem. To save pulling the Ignition switch out > prematuraly use a test light or multimeter. have someone hold the key > over and see if you get voltage on either side of the neutral safety > switch. If you have power there than the problem is the connection > to from the neutral saftey harness to the solinoid. If you do not > have power there then I would suspect that your ignition switch has > given up the ghost. Run a continuity test across the neutral safety > switch to make certain that it is good. Then put the wires back on > it. Remove the ignition switch so that you can get to the back of it. > Leave the wires on it. Try jumping from the battery side to the > stater side of the switch if she turns over you have a bad switch. > If not you missed something underneath. One last thought... Pull the > dash and make sure you are getting a circut throught the A/T switch. > > Good Luck > > Jim > 83 FC > Yorba Linda, ca > --- In WanderlodgeForum@yahoogroups.com, "Adria Haynes" > <mrbeebody@> wrote: |
