Air Level Master - Dim Suspension Dump Light
05-17-2007, 04:56
What is the "Air Level Master" as labeled on the dash? Mine has a flat
plastic plate, not a switch. It does have the LED, but it never lights up.
I aired up the suspension system this morning. Everything aired up as it
should. I've used my leak detector tools and have not found a leak one.
I'll let it stand for a couple hours to see if it settles any. When I
turn the ignition key to on I get a very dim suspension dump light. Any
thoughts on why the dim light?
Curt Sprenger
Anaheim Hills, Calif.
05-17-2007, 11:41
Curt:
I don't have an Air Level Master that I know of. I would like to know what it
does. I did have a ghost monitor light on the marker light switch and found a
dirty ground. Could it possibly be the main ground in the lower load center.
The main ground bus bar connection?
Leroy Eckert
1990 WB-40 "Smoke N Mirrors"
Niceville, FL
To: wanderlodge@yahoogroups.com ; WanderlodgeForum@yahoogroups.com
Sent: Thursday, May 17, 2007 11:56 AM
Subject: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light
Curt Sprenger
05-17-2007, 11:48
I was wondering if it was supposed to be "Air Compressor Master"?
On 5/17/2007 at 6:41 PM Leroy Eckert wrote:
>Curt:
>what it does. I did have a ghost monitor light on the marker light switch
>and found a dirty ground. Could it possibly be the main ground in the
>lower load center. The main ground bus bar connection?
>Leroy Eckert
>Niceville, FL
> From: Curt Sprenger
>up.
> Curt Sprenger
>Yahoo! Groups Links
05-17-2007, 12:42
Leroy,
Bluebird offered an Air Leveling system instead of the jack system. I
believe my dash has the place holder for the air leveling switch, if it
had the system. I have the jack leveling system.
Could be the main ground, good thought. If I understand the Lower Load
Center, it's in the generator fan/control bay, up top in that bay. Right?
Curt Sprenger
Leroy Eckert wrote:
> Curt:
> switch and found a dirty ground. Could it possibly be the main ground
> in the lower load center. The main ground bus bar connection?
> Leroy Eckert
> Niceville, FL
> From: Curt Sprenger
> Curt Sprenger
05-17-2007, 12:44
I have an "air compressor master" switch on my dash that's similarly
a 'blank' instead of a switch. Indeed, I do not have a _supplemental_
air compressor that is an option (at least on my year bird). Instead,
a previous owner installed a Microphor compressor that provides air
for the toilet. One annoyance is that they didn't hook up the dump
valves to the Microphor compressor -- an oversight that I plan to
remedy when I have the time...
aeonix1@...
On the road at Lockhart Texas
>> Curt:
>> know
>> light switch
>> the
>> Leroy Eckert
>> Niceville, FL
>> From: Curt Sprenger
>> Dump Light
>> flat
>> lights
>> up.
>> up as it
>> leak one.
>> When I
>> light. Any
05-17-2007, 12:51
Don,
No, I have one of those too. It turns on/off the 120V compressor.
Curt Sprenger
> >Curt:
> >Leroy Eckert
> >Niceville, FL
> > From: Curt Sprenger
> >up.
> as it
> > Curt Sprenger
> >Yahoo! Groups Links
05-17-2007, 13:20
Huh> Didn't know about the early air leveler. It's always good to learn
something new.
My lower load center is behind the large removable plate attached with Camloc
fasteners in the nose of the coach. At least that is how it is described on my
prints. It is where I have a major ground bus bar and three(I think) power bus
bars. Constant, Ignition and Filtered power. It is where numerous relays reside.
Leroy Eckert
1990 "Smoke N Mirrors"
Niceville, FL
Sent: Thursday, May 17, 2007 7:42 PM
Subject: Re: [WanderlodgeForum] Air Level Master - Dim Suspension Dump Light
Leroy,
Curt Sprenger
Leroy Eckert wrote:
> Curt:
> Leroy Eckert
> Niceville, FL
> From: Curt Sprenger
> Curt Sprenger
05-17-2007, 17:34
Curt,
That blank position, complete with blue light, on our dashes is for an option
that I don't have and neither do you apparently. I would suppose that BB was
anticipating offering air leveling but either didn't or didn't want to list it
is Section XI for what ever reason.
Makes sense to me.
Sent: Thursday, May 17, 2007 4:41 PM
Curt:
dirty ground. Could it possibly be the main ground in the lower load center. The
Leroy Eckert
Niceville, FL
Curt Sprenger
05-18-2007, 14:06
Curt... I have the Air Level System in my 89sp and dont know how to
use it. A rocker switch with "level" on one side and "Ride" on the
other side. Middle position is off. All i have done is put it
in "ride" when in motion.
Any body else use this option?? And how??
Thanks
Ed Gardels 89sp
Arlington Texas
> Leroy,
I
if it
Load
Right?
> Curt Sprenger
> Leroy Eckert wrote:
> > Curt:
know
light
ground
> > Leroy Eckert
> > Niceville, FL
> > From: Curt Sprenger
> > To: wanderlodge@yahoogroups.com 40yahoogroups.com>
Dump Light
flat
lights up.
up as it
leak one.
When I
light. Any
> > Curt Sprenger
05-19-2007, 02:33
Ed,
What does it do when in the "level" setting?
Curt Sprenger
> , Curt Sprenger
> Thanks
> Ed Gardels 89sp
> Arlington Texas
> > Leroy,
> I
> if it
> Load
> Right?
> > Curt Sprenger
> > Leroy Eckert wrote:
> > > Curt:
> know
> light
> ground
> > > Leroy Eckert
> > > Niceville, FL
> > > From: Curt Sprenger
> > 40yahoogroups.com>
> Dump Light
> flat
> lights up.
> up as it
> leak one.
> When I
> light. Any
> > > Curt Sprenger
