Headlight switch
02-29-2008, 14:01
Headlight switch
George, do you need a headlight switch? I have a couple of new ones
from BB. Can check the part number for you if you have the number for
your switch?
Terry
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
George Burke wrote:
My headlight switch has smoked its self. The connector went out
with
it. BB doesn't carry the connector, found at NAPA, EC20, along with the
switch, a Delco, which some parts places say is prone to failure. I
have found a wire that was in slot #3, (B/Y) that according to my BB
schematic, is supposed to be in slot #7. Maybe that is why my dash
lights won't dim, which was a previous problem. Also previously, I had
to jiggle the rod to get the headlights to come on sometimes. I have
had to do that once with the new switch. Has anyone had to deal with
this problem. Would be appreciative of some insight, as I am worried
that some other wire switching may have occured. I might add that on
this bus, when I replaced the gen.hr. meter, someone had crossed the
wires, putting the previous one to rest. You see why I am concerned
about correct wiring here. Thanks for any help, George Burke 1977 FC31
Charlotte
02-29-2008, 17:24
Headlight switch
Thanks Terry, but I also got the switch from NAPA, just before I found out that the connector had melted down. I used the old Delco Remy #, and they crossed it over. There was no actual # on either part.Earl Davissaid henowhas the switches in stock. I'm not sureif it matters switch wise, but my Bird is powered by a 534 c.i. Ford gas engine. The electrical diagram in my book actuallyshows a release dateof 9-18-1973. Mine is a 1977. Actually some of the wires do not match the diagram. If anyone has a gas engine powered Bird from the 70's, thatshows a different Electrical Diagram date than the above, I would love to talk to them.Thanks, George Burke 1977 FC31 Charlotte PS. the Delco # 1995163 = NAPA HL6554SB
On Fri, Feb 29, 2008 at 9:01 PM, Terry Neal <"bird@mountainrovers.com"> wrote:
George, do you need a headlight switch? I have a couple of new ones from BB. Can check the part number for you if you have the number for your switch?
Terry
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
George Burke wrote:
My headlight switch has smoked its self. The connector went out with
Charlotte
03-01-2008, 03:51
Headlight switch
Often a switch burns out when an appliance it turns on draw too much juice.
Setting up a relay to power the lights will route the juice to glow the light away from the dash switch. the dash switch will then only power or trip the relays. JohnF has an article about a headlight relay upgrade some place.
You can use several relays to trip different lights that the switch powers. Set the dash switch to trip each relay in parellel. that way a fault in one light orlength of wirewill not darken the remaining lights.
The relay also helps supply more juice to the lights and they glow brighter İmage.
CurtS of this forum built a relay board for my ailing tail lights and an independent set of relays for the trailer plug. that way the toad or trailer wont effect the bus running lights.
94pt Taillight relays
http://www.pbase.com/gregoryoc/image/82214174
GregoryO'Connor
94ptRomolandCa
03-01-2008, 04:17
Headlight switch
Terry, are you going with leds for your tail lites? Dave hardy gave me some front turn signal leds. They sure are bright.
83PT40
Livingston, Montana
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
03-01-2008, 04:30
Headlight switch
Mine are Doran, that Dave gave me. I have the originals at home. Plus I have some original tail lites at home, also. If anyone needs a lite, I can ask Brenda to send them out.
83PT40
Livingston, Montana
03-01-2008, 09:11
Headlight switch
Good stuff Greg. Am going to do head & tail lights on mine as soon
as the snow melts a little. A lot of protection in these upgrades.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
juice.
remaining lights.
brighter İmage.
94pt
Taillight relays
GregoryO'Connor
94ptRomolandCa
03-01-2008, 09:27
Headlight switch
Hey Ernie,
Yes, planned to use LEDs What brand, etc are your turn signals? I
need them too as mine are all rusted out & I understand the
originals are NLA.
Welcome back to the snow country. Will stop & say hello soon.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
83PT40
Livingston, Montana
03-01-2008, 09:44
Headlight switch
There is a headlight relay modification description in the forum files at
http://autos.groups.yahoo.com/group/Wand...ficat\
ion/
1991 WB40 "Texas Minivan"
> juice.
> some place.
> a fault in one light or length of wire will not darken the remaining
> lights.
> brighter [B-)] .
> 94pt Taillight relays <http://www.pbase.com/gregoryoc/image/82214174>
> GregoryO'Connor
> 94ptRomolandCa
03-01-2008, 16:05
Headlight switch
Terry:
I sure could use that 74 of yours to run up and down the hills here, gosh would that be nice LOL.
Can I borrow it for a while .
Bill 84 FC 35 SB "$quanderlodge"
Terrace, B.C. Canada
----- Original Message ----
Sent: Saturday, March 1, 2008 1:11:20 PM
Subject: Re: [WanderlodgeForum] Re: Headlight Switch
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
juice.
remaining lights.
brighter B-).
94pt
Taillight relays
http://www.pbase. com/gregoryoc/ image/82214174
GregoryO'Connor
94ptRomolandCa
Ask a question on any topic and get answers from real people. Go to Yahoo! Answers.
03-01-2008, 16:58
Headlight switch
>Thanks for the info. on relays Gregg. Great looking board. I now
know that Harry the Butcher has worked on my bus at some point. I
moved the B/Y wire from #3 to #7 as my diagram showed and "YES", I
can now dim my dash lights for the first time. I also found a wire up
top that was labeled "Fog Lights", but wasn't attached anywhere. It
may have been attached to the accessory solenoid at one time. Looks
like I've got more re-wiring to chase down. That problem will be for
another day, as needless to say they don't work. On these older BB's,
can anyone tell me what is normal here. I pull the H/L switch out one
click, and get both parking lights up front, both in the rear, plus
the tag light. When I turn on the low beams, or high beams, the front
parking lights aren't on, the rear lights all work fine. Is this the
BB way on these older buses, or is Harry still messing with me. Tia,
> juice.
power or
upgrade
> some place.
way
remaining
> lights.
> brighter [B-)] .
and an
> GregoryO'Connor
> 94ptRomolandCa
