BLUEBIRD CLOCK
11-18-2008, 12:29
Post: #31
BLUEBIRD CLOCK
> Also, does the movement protrude out the back of the
> wood?
NO. It is recessed into the bird body. I have one that I can trace
for you in a few days if that would help. Joe Losh in the Lone Star
Birds has made some of these, so he might have exact dimensions.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Leroy A. Eckert"
> Anyone out there with a BB clock? If you would give me a measurement
> from the nose of the bird to the end of the lower tail it would be
> appreciated. Also, does the movement protrude out the back of the
> wood? If so how far?
> I cut a prototype today out of 3/4" thick wood and it is 19" long by
> 6" high. It will accept a 2 3/4" to 3" quality quartz movement in
> wing. My prototype is made from white pine and the original will be
> blonde. I plan to make 7 prototypes to see what I can do with them.
I
> will use red oak on others and I plan to prime, base coat and clear
> coat some of the pine to see what happens. I don't have anything
else
> to do. Colors I am considering are rose,lagoon, black, red and blue.
I
> may air brush one in a bluebird style and see how that goes. I would
> clear coat that one. I would like to put a chime movement in one of
> them but it may need to be larger because of constraints in the size
> if available dials.
> All are being hand made.
> Thanks for any info.
> Leroy Eckert
> 1990 WB-40 Smoke N Mirrors
> Dahlonega, GA
> Royale Conversion
11-18-2008, 12:35
Post: #32
BLUEBIRD CLOCK
Leroy,
I have a clock, have not installed it yet so you can call me and I
will give you the stats. Matthew 562-691-3620
79FC 35 SB
Socal
I
else
blue. I
> if available dials.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
11-18-2008, 12:37
Post: #33
BLUEBIRD CLOCK
Leroy,
20-3/8".
n Tue, Nov 18, 2008 at 4:23 PM, Leroy A. Eckert <"jwasnewski@yahoo.com"> wrote:
6" high. It will accept a 2 3/4" to 3" quality quartz movement in the
blonde. I plan to make 7 prototypes to see what I can do with them. I
coat some of the pine to see what happens. I don't have anything else
to do. Colors I am considering are rose,lagoon, black, red and blue. I
if available dials.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Curt Sprenger
Anaheim Hills, CA
11-18-2008, 12:47
Post: #34
BLUEBIRD CLOCK
Leroy:
20 1/2 in. from noxe to tip of bottom wing, 5 3/4 in. high and 1 1/2
inches thick. That is from an original clock out of a 1982.
The numberals are: Blue Bird Emblem for 12 o'c;clock, W for 11, A
for 10 and so forth until you spell out Wanderlodge. It looks to me
if that is backwards but that is the way that they did it. Any other
questions mine is in the room with me.
Marv
2004 M380
Ocean Shores, WA
I
else
blue. I
> if available dials.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
11-18-2008, 13:10
Post: #35
BLUEBIRD CLOCK
If you would please, and how thick is the wood. The prototype movements will include face mounts and rear mounts. I am just jacking around with them to see where they can be used, tables, walls and in the home.
Leroy Eckert
Dahlonega, GA
--- On Tue, 11/18/08, mbulriss <mbulriss@...> wrote:
Subject: [WanderlodgeForum] Re: Bluebird Clock
Date: Tuesday, November 18, 2008, 7:29 PM
> wood?
--- In "WanderlodgeForum%40yahoogroups.com", "Leroy A. Eckert"
I
else
I
> if available dials.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
11-18-2008, 13:38
Post: #36
BLUEBIRD CLOCK
Thank you. No hurry, when you get a chance would you tell me the measurement between the numbers OD to get a diameter of the face. As well, the measurement of the minute and hour hands from the center point to the end of the hands. More questions. How thick is the wood on the original clock. Thanks.
Leroy Eckert
Dahlonega, GA
Royale Conversion
--- On Tue, 11/18/08, Curt Sprenger wrote:
Subject: Re: [WanderlodgeForum] Bluebird Clock
Date: Tuesday, November 18, 2008, 7:37 PM
Leroy,
20-3/8".
if available dials.
Leroy Eckert
Dahlonega, GA
Royale Conversion
Curt Sprenger
Anaheim Hills, CA
11-18-2008, 14:10
Post: #37
BLUEBIRD CLOCK
Leroy
Are your clocks going to be for sale? I know the quality of your work so the end product has to be excellent. Please let me know your price if they are for sale.
Jvredden
91 PT 40
Sent from my BlackBerry® smartphone with SprintSpeed
Date: Wed, 19 Nov 2008 00:23:17 -0000
To:
Subject: [WanderlodgeForum] Bluebird Clock
if available dials.
Leroy Eckert
Dahlonega, GA
Royale Conversion
11-18-2008, 15:19
Post: #38
BLUEBIRD CLOCK
Leroy:
The wood is 1 1/2 inches thick. The numbers at spaced out from the
stem of the clock that comes through the wood 1 1/2 inches. That
make the number 3 inches across. That is from the center of one
number to the center of the opposing number on the opposite site of
the shaft. I hope I have made myself understood.
If you are not aware of them http://www.klockit.com is the place to order
clock stuff. They have just about any kind of movement you want.
HTH
Marv
2004 M380
Ocean Shores, WA
the home.
> Leroy Eckert
> Dahlonega, GA
> From: mbulriss <mbulriss@...>
> > wood?
trace
Star
> Mike Bulriss
> San Antonio, TX
> --- In WanderlodgeForum@ yahoogroups. com, "Leroy A. Eckert"
measurement
by
> the
be
them.
> I
clear
> else
blue.
> I
would
of
size
> > if available dials.
> > Leroy Eckert
> > Dahlonega, GA
> > Royale Conversion
11-19-2008, 01:03
Post: #39
BLUEBIRD CLOCK
Thanks, How big are the letters and what are they made of. Thanks again.
Leory Eckert
Dahlonega, GA
Date: Tuesday, November 18, 2008, 7:47 PM
Leroy:
Marv
2004 M380
Ocean Shores, WA
I
else
blue. I
> if available dials.
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
11-19-2008, 01:07
Post: #40
BLUEBIRD CLOCK
Maybe, but have not gotten that far yet. I want to do a couple of designs, original as possible an a more modern face also. I am trying to find dial parts that will fit. I will provide photos when I get them together and go from there. Never know, the whole thing might flop. lol I have never fabricated a clock.
Leroy Eckert
Dahlonega, GA
Date: Tuesday, November 18, 2008, 9:10 PM
Leroy
Jvredden
91 PT 40
To:
if available dials.
Leroy Eckert
Dahlonega, GA
Royale Conversion
