Changing out PT battery chargers
05-24-2007, 11:22
How hard is it to upgrade the PT battery chargers? It doesn't "seem"
like it would be hard to pull out the boilers and put in something modern, is there something I am not seeing? Scott Forman 86 PT38 |
05-24-2007, 11:52
Nope,
Sinple to do. Did mine and replaced with a couple from Camping World. Use the 100 amp as primary, and the other as backup. Simple to wire direct to batts. Bob Lawrence 84 PT36 Tacoma, Wa. (with 143 days left before we fulltime otta here!) > How hard is it to upgrade the PT battery chargers? It doesn't "seem" > like it would be hard to pull out the boilers and put in something > modern, is there something I am not seeing? > > Scott Forman > 86 PT38 > |
05-24-2007, 12:53
Easy job Scott. I installed 2 of the IOTA chargers in my PT40. Just
label the existing wires & hook the new ones up the same way. You only want one of the "Smart Chargers" in your new installation. So one on your new chargers will have it, and the other one won't. IOTA has great tech support too if you have specific questions. I bought mine on eBay with the full warranty for $150 each + shipping. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Scott Forman wrote: > How hard is it to upgrade the PT battery chargers? It doesn't "seem" > like it would be hard to pull out the boilers and put in something > modern, is there something I am not seeing? > > Scott Forman > 86 PT38 > > [Non-text portions of this message have been removed] |
05-24-2007, 12:59
What amp rating do I need to use?
--- In WanderlodgeForum@yahoogroups.com, Terry Neal > > Easy job Scott. I installed 2 of the IOTA chargers in my PT40. Just > label the existing wires & hook the new ones up the same way. You only > want one of the "Smart Chargers" in your new installation. So one on > your new chargers will have it, and the other one won't. IOTA has great > tech support too if you have specific questions. I bought mine on eBay > with the full warranty for $150 each + shipping. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > > > Scott Forman wrote: > > > How hard is it to upgrade the PT battery chargers? It doesn't "seem" > > like it would be hard to pull out the boilers and put in something > > modern, is there something I am not seeing? > > > > Scott Forman > > 86 PT38 > > > > > > > > [Non-text portions of this message have been removed] > |
05-24-2007, 13:02
Terry and Scott. I just replaced one of my two IOTA55s and was told the
correct smart charger for a two charger system was the IQ4. This is a single smart box with two telephone wires. You plug one wire into each IOTA. On 24/05/07, Terry Neal > > Easy job Scott. I installed 2 of the IOTA chargers in my PT40. Just > label the existing wires & hook the new ones up the same way. You only > want one of the "Smart Chargers" in your new installation. So one on > your new chargers will have it, and the other one won't. IOTA has great > tech support too if you have specific questions. I bought mine on eBay > with the full warranty for $150 each + shipping. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > Scott Forman wrote: > > > How hard is it to upgrade the PT battery chargers? It doesn't "seem" > > like it would be hard to pull out the boilers and put in something > > modern, is there something I am not seeing? > > > > Scott Forman > > 86 PT38 > > > > > > [Non-text portions of this message have been removed] > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-24-2007, 13:07
Scott my system has two 55amp IOTAs and my battery bank consists of eight
6volt golf carts. Been working well for me for three years. I blew on IOTA because I had a smart charger on each charger instead of using the IQ4 which is designed to control two chargers. On 24/05/07, Scott Forman <sforman@...> wrote: > > What amp rating do I need to use? > > --- In WanderlodgeForum@yahoogroups.com > Terry Neal > > > > Easy job Scott. I installed 2 of the IOTA chargers in my PT40. > Just > > label the existing wires & hook the new ones up the same way. You > only > > want one of the "Smart Chargers" in your new installation. So one > on > > your new chargers will have it, and the other one won't. IOTA has > great > > tech support too if you have specific questions. I bought mine on > eBay > > with the full warranty for $150 each + shipping. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > > > Scott Forman wrote: > > > > > How hard is it to upgrade the PT battery chargers? It > doesn't "seem" > > > like it would be hard to pull out the boilers and put in something > > > modern, is there something I am not seeing? > > > > > > Scott Forman > > > 86 PT38 > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-25-2007, 07:58
I bought the 55 amp models Scott. They work well & keep the batteries
fully charged all the time without overcharging or any measurable water loss. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Scott Forman wrote: > What amp rating do I need to use? > > --- In WanderlodgeForum@yahoogroups.com > > > > > Easy job Scott. I installed 2 of the IOTA chargers in my PT40. > Just > > label the existing wires & hook the new ones up the same way. You > only > > want one of the "Smart Chargers" in your new installation. So one > on > > your new chargers will have it, and the other one won't. IOTA has > great > > tech support too if you have specific questions. I bought mine on > eBay > > with the full warranty for $150 each + shipping. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > > > > > Scott Forman wrote: > > > > > How hard is it to upgrade the PT battery chargers? It > doesn't "seem" > > > like it would be hard to pull out the boilers and put in something > > > modern, is there something I am not seeing? > > > > > > Scott Forman > > > 86 PT38 > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] |
05-25-2007, 08:00
Thanks Rob, I was trying to recall the name that IOTA used on that
control (the IQ4) when I was writing the reply. That is the set up that I have too. One of the IQ4s & two IOTA 55 amp chargers. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Rob Robinson wrote: > Terry and Scott. I just replaced one of my two IOTA55s and was told the > correct smart charger for a two charger system was the IQ4. This is a > single > smart box with two telephone wires. You plug one wire into each IOTA. > > On 24/05/07, Terry Neal > > > > Easy job Scott. I installed 2 of the IOTA chargers in my PT40. Just > > label the existing wires & hook the new ones up the same way. You only > > want one of the "Smart Chargers" in your new installation. So one on > > your new chargers will have it, and the other one won't. IOTA has great > > tech support too if you have specific questions. I bought mine on eBay > > with the full warranty for $150 each + shipping. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Scott Forman wrote: > > > > > How hard is it to upgrade the PT battery chargers? It doesn't "seem" > > > like it would be hard to pull out the boilers and put in something > > > modern, is there something I am not seeing? > > > > > > Scott Forman > > > 86 PT38 > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > -- > Rob, Sue & Merlin Robinson > 94 WLWB > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
