Aux Batt solenoid on PT
05-26-2007, 06:53
Where is the auxillary battery solenoid on a PT?
Scott Forman 86 PT38 |
05-26-2007, 07:48
Scott,
On my 86 PT40 mine is in the compartment with the chargers. But knowing BB and your coach being a 38 footer it may be different. Howard Truitt Camilla, Ga. 86 PT40 > > From: "Scott Forman" <sforman@...> > Date: 2007/05/26 Sat PM 02:53:55 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > Where is the auxillary battery solenoid on a PT? > > Scott Forman > 86 PT38 > > > |
05-26-2007, 11:49
Well, if that's it, then mine doesn't work. Where can I get one of
these? Scott --- In WanderlodgeForum@yahoogroups.com, > > Scott, > On my 86 PT40 mine is in the compartment with the chargers. But knowing BB and your coach being a 38 footer it may be different. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > From: "Scott Forman" <sforman@...> > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > > > Where is the auxillary battery solenoid on a PT? > > > > Scott Forman > > 86 PT38 > > > > > > > |
05-26-2007, 11:59
Contact Stephen Birtles. He sells them.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Scott Forman wrote: > Well, if that's it, then mine doesn't work. Where can I get one of > these? > > Scott > > --- In WanderlodgeForum@yahoogroups.com > > > > > Scott, > > On my 86 PT40 mine is in the compartment with the chargers. But > knowing BB and your coach being a 38 footer it may be different. > > Howard Truitt > > Camilla, Ga. > > 86 PT40 > > > > > > From: "Scott Forman" <sforman@...> > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > To: WanderlodgeForum@yahoogroups.com > > > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > > > > > Where is the auxillary battery solenoid on a PT? > > > > > > Scott Forman > > > 86 PT38 > > > > > > > > > > > > > |
05-26-2007, 12:17
OK...a little help...
There are solenoids all over the place. There's one on the front wall of the batter charger compartment. There are two others on the metal panel that folds down to give access to the charger compartment. And there are three of them behind the step well, although it looks like two of them are for the leveling pump. None of these make the audible "click" when I hit the Aux Batt switch. The drawings in my Blue Box aren't as comprehensive as they were in my FC, so I am having trouble figuring all this out. Help! Scott Forman 86 PT38 --- In WanderlodgeForum@yahoogroups.com, > > Scott, > On my 86 PT40 mine is in the compartment with the chargers. But knowing BB and your coach being a 38 footer it may be different. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > From: "Scott Forman" <sforman@...> > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > > > Where is the auxillary battery solenoid on a PT? > > > > Scott Forman > > 86 PT38 > > > > > > > |
05-26-2007, 12:35
Scott:
Locate the solenoid that the gen set battery charge diode is connected to. It should be on the right of the compartment behind an angle bracket. That is the solenoid that by passes the diode and connects the batteries together. Safe travels, Ralph and Charolette Fullenwider 84FC35 Duncan, Oklahoma At 12:17 AM 5/27/2007 +0000, you wrote: >OK...a little help... > >There are solenoids all over the place. There's one on the front >wall of the batter charger compartment. There are two others on the >metal panel that folds down to give access to the charger >compartment. And there are three of them behind the step well, >although it looks like two of them are for the leveling pump. None >of these make the audible "click" when I hit the Aux Batt switch. > >The drawings in my Blue Box aren't as comprehensive as they were in >my FC, so I am having trouble figuring all this out. > >Help! > >Scott Forman >86 PT38 > >--- In WanderlodgeForum@yahoogroups.com, > > > > Scott, > > On my 86 PT40 mine is in the compartment with the chargers. But >knowing BB and your coach being a 38 footer it may be different. > > Howard Truitt > > Camilla, Ga. > > 86 PT40 > > > > > > From: "Scott Forman" <sforman@...> > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > > > > > Where is the auxillary battery solenoid on a PT? > > > > > > Scott Forman > > > 86 PT38 > > > > > > > > > > > > > |
05-26-2007, 13:07
I was looking for the diode, couldn't find it. But I think I know
the one you are speking of. Lots of connections around that thing. Thanks --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Scott: > > Locate the solenoid that the gen set battery charge diode is connected to. > It should be on the right of the compartment behind an angle bracket. That > is the solenoid that by passes the diode and connects the batteries together. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Duncan, Oklahoma > > At 12:17 AM 5/27/2007 +0000, you wrote: > >OK...a little help... > > > >There are solenoids all over the place. There's one on the front > >wall of the batter charger compartment. There are two others on the > >metal panel that folds down to give access to the charger > >compartment. And there are three of them behind the step well, > >although it looks like two of them are for the leveling pump. None > >of these make the audible "click" when I hit the Aux Batt switch. > > > >The drawings in my Blue Box aren't as comprehensive as they were in > >my FC, so I am having trouble figuring all this out. > > > >Help! > > > >Scott Forman > >86 PT38 > > > >--- In WanderlodgeForum@yahoogroups.com, > > > > > > Scott, > > > On my 86 PT40 mine is in the compartment with the chargers. But > >knowing BB and your coach being a 38 footer it may be different. > > > Howard Truitt > > > Camilla, Ga. > > > 86 PT40 > > > > > > > > From: "Scott Forman" <sforman@> > > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > > To: WanderlodgeForum@yahoogroups.com > > > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > > > > > > > Where is the auxillary battery solenoid on a PT? > > > > > > > > Scott Forman > > > > 86 PT38 > > > > > > > > > > > > > > > > > > > > |
05-26-2007, 15:01
Scott,
On my coach it is in the front drivers side compartment. With the Gen. radiator, fan, control box, etc.. Mine is not working either. I've got it narrowed down to the wire from the switch to the solenoid, has a break in it somewhere? Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Where is the auxillary battery solenoid on a PT? > > Scott Forman > 86 PT38 > |
05-26-2007, 18:03
The '86 and '87 are built way different in that compartment.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. thomas_sorrentino wrote: > Scott, > > On my coach it is in the front drivers side compartment. With the > Gen. radiator, fan, control box, etc.. Mine is not working either. > I've got it narrowed down to the wire from the switch to the > solenoid, has a break in it somewhere? > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > --- In WanderlodgeForum@yahoogroups.com > > wrote: > > > > Where is the auxillary battery solenoid on a PT? > > > > Scott Forman > > 86 PT38 > > > > |
05-27-2007, 01:50
Scott,
May I be so bold as to ask what is your problem? Howard Truitt Camilla, Ga. 86 PT40 > > From: "Scott Forman" <sforman@...> > Date: 2007/05/26 Sat PM 08:17:02 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Aux Batt solenoid on PT > > OK...a little help... > > There are solenoids all over the place. There's one on the front > wall of the batter charger compartment. There are two others on the > metal panel that folds down to give access to the charger > compartment. And there are three of them behind the step well, > although it looks like two of them are for the leveling pump. None > of these make the audible "click" when I hit the Aux Batt switch. > > The drawings in my Blue Box aren't as comprehensive as they were in > my FC, so I am having trouble figuring all this out. > > Help! > > Scott Forman > 86 PT38 > > --- In WanderlodgeForum@yahoogroups.com, > > > > Scott, > > On my 86 PT40 mine is in the compartment with the chargers. But > knowing BB and your coach being a 38 footer it may be different. > > Howard Truitt > > Camilla, Ga. > > 86 PT40 > > > > > > From: "Scott Forman" <sforman@...> > > > Date: 2007/05/26 Sat PM 02:53:55 EDT > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT > > > > > > Where is the auxillary battery solenoid on a PT? > > > > > > Scott Forman > > > 86 PT38 > > > > > > > > > > > > > > > |
