Info on Freeze Heaters
05-27-2007, 04:12
Since my freeze heaters burned a hole in a water pipe and caused a
flood I have been trying to determine why it happened. While cutting, pulling and removing most of the wiring, I found a factory part number tag and a specific warning. The warning stated, "do not overlap or touch together, fire hazard, and do not over insulate." The area where my problem occurred had three wires in the same area. Apparantly, over time coach movement allowed the wires to touch together causing the problem. FWIW. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL |
