Battery Choices - Re: Getting Back on the Road this Weekend...
05-31-2007, 01:28
Hello Dan,
Thanks for your battery advice. It seems that others agree with you too.
I was on Trojan's website and also came across the T-125 golf cart
battery. It is the same size as the T-105, but a little more
powerful... But that does not mean it is better... Anybody have
experience with the T-125?
Thanks so much!
Andy
--- In WanderlodgeForum@yahoogroups.com, "ac7880" wrote:
> If your coach still has 4 6 volt golf cart batteries, then I would
> do Trojan T105s. I would replace all 4 at the same time.
> On your gen you should have 2 rocker switches too start it, one by
> driver, one in kitchen. Hold the rocker switch in the down position
> for the preheat for approx 15 to 20 seconds then push on the upward
> position and see if gen fires. If not, repeat.
> Dan previous 83 FC35, now 94 BB BMC 37'
> --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman"
> > Fellow Wanderlodgers:
> > After sitting around for 10 months, I'm finally getting ready to
> drive
> > out my 83 FC-35 and get it back on the road. During that time, I
> did
> > the following;
> > Modified my air intake system.
> > Rebuilt and modified my power steering system.
> > Adjusted the valve lash.
> > Had the radiator cleaned and pressure checked.
> > Replace the racor and fuel filters.
> > Replaced all cooling hoses in front of the front tires.
> > Two things I still have to tackle this weekend...
> > Two of my four 6v starting batteries are showing a weak charge under
> > load - even after charging for many hours. Can somebody recommend
> to
> > me the best brand battery to replace them? A battery with good
> > starting power and good reserve to run lights and assessories?
> > Finally, I'm having trouble starting my Perkins generator. The
> > previous owner used starting fluid to turn it over. I wonder if
> there
> > is a pre-heating device on the geny that isn't working? Might
> anybody
> > know how to replace it? The battery is fine.
> > Any advice you can offer would be great!
> > Looking to break in my coach on a cross country road trip this
> summer.
> > I turn the big 4-0, and can't think of a better way to spend it.
> > I hope to post photos of my air intake and power steering upgrades
> > shortly.
> > Thanks everyone!
> > Andy Coleman
> > 83' FC-35
> > Spring Lake Heights, NJ
05-31-2007, 02:15
Andy,
More is almost always better, But recheck the height of the T125.
It is taller and this height would not fit into our 88 FC, Also the
T125 is a really heavy battery. Take a look at Deka batteries.
http://www.eastpenn-deka.com/
The specs for the 6 volt Deka batteries are about the same as the
popular Trojans. The Deka is mfg. in Pennsylvania , A battery
distributor stated there is about a 15 to $20, savings per battery if
you are located East on the Mississippi because of the Trojan
shipping cost from the West coast.??...
But this may just be a sales pitch............
I purchased 6 Deka batteries, because they were available, had the
post type connectors, and yes they were less cost than the Trojans,
Only six months old , But so far they are good.,
Bill 88 FC with lots of stored energy
> Hello Dan,
you too.
> Thanks so much!
> Andy
would
by
position
upward
to
> > drive
I
> > did
> > > the following;
under
recommend
> > to
if
> > there
> > anybody
> > summer.
it.
upgrades
> > > shortly.
> > > Thanks everyone!
> > > Andy Coleman
> > > 83' FC-35
05-31-2007, 02:46
Boy I thought the T125 was taller then the T105 also and I am sure I
checked the spec's when I thought about making the change for my 1982
fC35. But checked them just now and they are indeed the same
physical size. But after using the Interstate batteries I would not
spend the extra money to get a Trojan battery. In my area Trojans are
almost impossible to find. Interstate batteries are built just as
good and you can find them anywhere in the US in case you need to
replace one in warranty while travelling. I just got 6 new Interstate
6V deep cycles from a wholesaler in Syracuse,NY and paid $58 each for them.
tom warner
vernon center,ny
1985 PT40
At 10:15 AM 5/31/2007, you wrote:
>Andy,
> > Hello Dan,
>you too.
> > Thanks so much!
> > Andy
>would
>by
>position
>upward
>to
> > > drive
>I
> > > did
> > > > the following;
>under
>recommend
> > > to
>if
> > > there
> > > anybody
> > > summer.
>it.
>upgrades
> > > > shortly.
> > > > Thanks everyone!
> > > > Andy Coleman
> > > > 83' FC-35
>Yahoo! Groups Links
05-31-2007, 05:54
Interstate is a marketing company they job the maunfacturing to the
lowest bidder
and I really doubt they are just as good
For trojans go the website use the dealer locater
And yes the the t105 and t125 are the same physical size the
difference is in the internal makeup of the battery
for them.
> tom warner
> vernon center,ny
> 1985 PT40
> >Andy,
> > wrote:
> > > Hello Dan,
> >you too.
> > > Thanks so much!
> > > Andy
> >would
> >by
> >position
> >upward
> >to
> > > > drive
> >I
> > > > did
> > > > > the following;
> >under
> >recommend
> > > > to
> >if
> > > > there
> > > > anybody
> > > > summer.
> >it.
> >upgrades
> > > > > shortly.
> > > > > Thanks everyone!
> > > > > Andy Coleman
> > > > > 83' FC-35
> >Yahoo! Groups Links
05-31-2007, 06:12
Tom in november you posted that you just bought 6 interstates and now
you post you just bought 6 interstates how many batteries does your
coach use or do you have an electrical problem?? VBG
here is a list of who makes interstate battery nothing more than a
marketing firm with a nascar team number 18
interstate Batteries are privately branded batteries the various
flavours and brands are produced by the following companies
Interstate Battery System of America, Inc., (US) +1-972-991-1444,
1-888-772-3600 or http://www.interstatebatteries.com/
50-Month, (Green Top) [SLI] by Johnson Controls
AGM Series [spiral wound] by Optima
Ameriton by Johnson Controls
BBG Series [VRLA] by C&D Technologies
Big Joe [Deep Cycle] by U.S. Battery
BPS Series [SLA] by Power-Sonic
Bulldog [Motive Deep Cycle] by Bulldog Battery
CATV Series [VRLA] by C&D Technologies
Cycle-Tron [SLI] by Yuasa
Cranking [SLI] by Johnson Controls
DCS, (Deep Cycle Series) by C&D Technologies
Extreme Performance [SLI Sprial Cell] by Optima
GC Series [Deep Cycle] by C&D Technologies
Mega-Tron, (Gray Top) [SLI] by Johnson Controls
Plus, (Black Top) [SLI] by Johnson Controls
Motorcycle [SLI] Yuasa
MVP, (Mobility Valu-Plus) Series [Deep Cycle] by C&D Technologies
PC Series by [SLA]Power-Sonic
PowerVolt [SLI] by Johnson Controls
SG Series [Gel Cell Deep Cycle] by East Penn
SC, (SpiralCell) Series by Optima
SDCS Series [Deep Cycle] by C&D Technologies
TCOM Series [SLA] by Power-Sonic
TEL Series [Standby Deep Cycle] by C&D Technologies
U Series [Motive Deep Cycle] by U.S. Battery
UPS Series [Standby Deep Cycle] by C&D Technologies
V Series [SLI] by Enertec Grupo IMSA
Workaholic [SLI] by Johnson Controls
The manufacturer's code number will be on the battery and is only sure
way of identifying the manufacturer. Ask the dealer who made the
battery. In the United States, Material Safety Data Sheets (MSDS), can
provide a useful source of information on the manufacturer of the
battery. Manufacturers, joint ventures or distributors will sometimes
have lines within a trademark or brand, for example, Bronze, Silver,
Gold, Platinum, Titanium, Premium, Heavy Duty, Commercial, Standard,
Plus, Turbo, Calcium, Classic, Maintenance Free, etc., for
differentiating quality, features or warranty periods. They will also
contract with other manufacturers to build special purpose batteries
and batteries to complete their product lines that are not
economically feasible to build themselves. A good manufacturers cross
reference list for Sealed Lead-Acid (SLA) batteries can be found on
Battery Solutions Web site.
Stephen 77fc35 with batteries 7 years old just like the everready
bunny still going strong
> lowest bidder
> for them.
> > tom warner
> > vernon center,ny
> > 1985 PT40
> > >Andy,
> > > wrote:
> > > > Hello Dan,
> > >you too.
> > > > Thanks so much!
> > > > Andy
> > >would
> > >by
> > >position
> > >upward
> > >to
> > > > > drive
time,
> > >I
> > > > > did
> > > > > > the following;
> > >under
> > >recommend
> > > > > to
good
The
> > >if
> > > > > there
> > > > > anybody
> > > > > summer.
> > >it.
> > >upgrades
> > > > > > shortly.
> > > > > > Thanks everyone!
> > > > > > Andy Coleman
> > > > > > 83' FC-35
> > >Yahoo! Groups Links
05-31-2007, 10:32
OK Stephen, since you know so much about batteries, I need to put in
new house batteries. Eight 12V Group 31. Any recommendations? The
guy next door is the Interstate Batteries Distributor, but that isn't
a deciding factor......
1991 WB40 "Texas Minivan"
> > lowest bidder
sure I
1982
not
Trojans are
Interstate
> > for them.
> > > tom warner
> > > vernon center,ny
> > > 1985 PT40
> > > >Andy,
battery if
> > > > wrote:
> > > > > Hello Dan,
> > > >you too.
golf cart
have
> > > > > Thanks so much!
> > > > > Andy
> > > >would
it, one
> > > >by
> > > >position
> > > >upward
ready
> > > >to
> > > > > > drive
> time,
> > > >I
> > > > > > did
> > > > > > > the following;
charge
> > > >under
> > > >recommend
> > > > > > to
> good
assessories?
> The
wonder
> > > >if
> > > > > > there
Might
> > > > > > anybody
trip this
> > > > > > summer.
spend
> > > >it.
> > > >upgrades
> > > > > > > shortly.
> > > > > > > Thanks everyone!
> > > > > > > Andy Coleman
> > > > > > > 83' FC-35
> > > >Yahoo! Groups Links
05-31-2007, 10:40
Stephen as you well know there are many many other companies that
sell similar products with different trade names but all manufactured
by the same company. I see nothing wrong with that. Interstate deep
cycle batteries are still fine batteries very well made and actually
slightly heavier for the same battery U2200 versus T105 and more
capacity at 232AH versus 225AH for the T105. I paid $58 each for the
Interstate batteries and could not get a T105 even if I ordered them
for less then $100. What do you sell and ship them to NY for? As I
noted earlier Interstate batteries are predominent here in New York
and can be easily obtained almost anywhere, a very important factor
to me as I travel. There is no such thing as a trouble free anything
and if I get in the middle of no where and need a replacement I want
to get it whether its a tire or a battery. Thats why I buy Interstate
batteries and Michelin RV tires.
I actually looked for Trojans when I needed the first ones for the
1982 FC35 but could not find them anywhere close by (nearest place
that stocked them was Buffalo, New York). And then I bought two sets
of four Interstates for the 1982 FC35, one set for the coach and
another for the high reach machine we have. I still have the same
set of 6 Interstates in the 1985 PT 40 and still have the 6 Optima
batteries also. Hmmm arent I allowed to do that.
I simply noted before that in my opinion Interstate batteries are
comparable in every way to Trojans and can be bought a lot cheaper
here. If others have another experience then they can chose for
themselves based on their personal needs.
tom warner
vernon center,NY
1985 PT40
> > lowest bidder
> > for them.
> > > tom warner
> > > vernon center,ny
> > > 1985 PT40
> > > >Andy,
> > > > wrote:
> > > > > Hello Dan,
> > > >you too.
> > > > > Thanks so much!
> > > > > Andy
> > > >would
> > > >by
> > > >position
> > > >upward
> > > >to
> > > > > > drive
>time,
> > > >I
> > > > > > did
> > > > > > > the following;
> > > >under
> > > >recommend
> > > > > > to
>good
> The
> > > >if
> > > > > > there
> > > > > > anybody
> > > > > > summer.
> > > >it.
> > > >upgrades
> > > > > > > shortly.
> > > > > > > Thanks everyone!
> > > > > > > Andy Coleman
> > > > > > > 83' FC-35
> > > >Yahoo! Groups Links
>Yahoo! Groups Links
05-31-2007, 10:57
---WOW!!!!....I love this Forum! Plenty of comments..LOL
Hank Hannigan
90SP36
manufactured
deep
actually
them
I
factor
anything
want
Interstate
sets
Optima
> tom warner
> vernon center,NY
> 1985 PT40
now
sure
can
sometimes
Silver,
Standard,
also
batteries
cross
> > > lowest bidder
sure I
my 1982
would not
Trojans are
just as
need to
Interstate
each
> > > for them.
> > > > tom warner
> > > > vernon center,ny
> > > > 1985 PT40
> > > > >Andy,
T125.
Also the
batteries.
as the
battery
battery if
had the
Trojans,
> > > > > wrote:
> > > > > > Hello Dan,
agree with
> > > > >you too.
golf cart
more
Anybody have
> > > > > > Thanks so much!
> > > > > > Andy
then I
> > > > >would
time.
start it, one
> > > > >by
down
> > > > >position
on the
> > > > >upward
getting ready
> > > > >to
> > > > > > > drive
that
> >time,
> > > > >I
> > > > > > > did
> > > > > > > > the following;
tires.
weak charge
> > > > >under
somebody
> > > > >recommend
> > > > > > > to
with
> >good
assessories?
generator.
> > The
I wonder
> > > > >if
> > > > > > > there
working? Might
> > > > > > > anybody
trip this
> > > > > > > summer.
to spend
> > > > >it.
steering
> > > > >upgrades
> > > > > > > > shortly.
> > > > > > > > Thanks everyone!
> > > > > > > > Andy Coleman
> > > > > > > > 83' FC-35
> > > > >Yahoo! Groups Links
> >Yahoo! Groups Links
05-31-2007, 11:05
---Mike:
I Have Interstate Starting batteries ..been in over four years....no
problems.
LOL
Hank Hannigan
90SP36
isn't
> Mike Bulriss
> San Antonio, TX
now
your
sure
(MSDS), can
sometimes
Silver,
Standard,
also
batteries
cross
on
> > > lowest bidder
> sure I
my
> 1982
would
> not
> Trojans are
just as
need to
> Interstate
each
> > > for them.
> > > > tom warner
> > > > vernon center,ny
> > > > 1985 PT40
> > > > >Andy,
T125.
Also the
batteries.
as the
battery
> battery if
had the
Trojans,
> > > > > wrote:
> > > > > > Hello Dan,
agree with
> > > > >you too.
> golf cart
more
Anybody
> have
> > > > > > Thanks so much!
> > > > > > Andy
then I
> > > > >would
time.
> it, one
> > > > >by
down
> > > > >position
on the
> > > > >upward
getting
> ready
> > > > >to
> > > > > > > drive
that
> > time,
> > > > >I
> > > > > > > did
> > > > > > > > the following;
tires.
weak
> charge
> > > > >under
somebody
> > > > >recommend
> > > > > > > to
with
> > good
> assessories?
generator.
> > The
> wonder
> > > > >if
> > > > > > > there
working?
> Might
> > > > > > > anybody
> trip this
> > > > > > > summer.
to
> spend
> > > > >it.
steering
> > > > >upgrades
> > > > > > > > shortly.
> > > > > > > > Thanks everyone!
> > > > > > > > Andy Coleman
> > > > > > > > 83' FC-35
> > > > >Yahoo! Groups Links
05-31-2007, 13:09
I don't recall saying the batteries were no good I was stating that
interstate was nothing more than a marketing company that sells
batteries a good marketing model
Interstate sells a number of products by different manufacturers not
similar products made by the same manufacturer Which leads one to
believe that the lowest bidder gets the contract. So I would question
the quality at times.
Personally I like Rolls and Surrette Batteries for flooded Cell
Lifeline and Fullriver for AGM
I also like the comments on this forum especially when one member
bushwacks another who is honestly trying to sell their coach for
whatever reason
Another case of opening mouth and changing feet.VBG
Lets get on to fixing coaches
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan"
> Hank Hannigan
> 90SP36
> manufactured
> deep
> actually
> the
> them
> I
> factor
> anything
> want
> Interstate
> the
> sets
> Optima
> > tom warner
> > vernon center,NY
> > 1985 PT40
> now
> sure
> can
> sometimes
> Silver,
> Standard,
> also
> batteries
> cross
> the
> > > > lowest bidder
> sure I
> my 1982
> would not
> Trojans are
> just as
> need to
> Interstate
> each
> > > > for them.
> > > > > tom warner
> > > > > vernon center,ny
> > > > > 1985 PT40
> > > > > >Andy,
> T125.
> Also the
> batteries.
> as the
> battery
> battery if
> had the
> Trojans,
> > > > > > wrote:
> > > > > > > Hello Dan,
> agree with
> > > > > >you too.
> golf cart
> more
> Anybody have
> > > > > > > Thanks so much!
> > > > > > > Andy
> then I
> > > > > >would
> time.
> start it, one
> > > > > >by
> down
> > > > > >position
> on the
> > > > > >upward
> getting ready
> > > > > >to
> > > > > > > > drive
> that
> > >time,
> > > > > >I
> > > > > > > > did
> > > > > > > > > the following;
> tires.
> weak charge
> > > > > >under
> somebody
> > > > > >recommend
> > > > > > > > to
> with
> > >good
> assessories?
> generator.
> > > The
> I wonder
> > > > > >if
> > > > > > > > there
> working? Might
> > > > > > > > anybody
> trip this
> > > > > > > > summer.
> to spend
> > > > > >it.
> steering
> > > > > >upgrades
> > > > > > > > > shortly.
> > > > > > > > > Thanks everyone!
> > > > > > > > > Andy Coleman
> > > > > > > > > 83' FC-35
> > > > > >Yahoo! Groups Links
> > >Yahoo! Groups Links
