Ignition switch
05-05-2005, 05:44
Ignition switch
Glenn, being able to start and stop your coach, is indeed, a milestone. Now,
if I only had some extra bucks for fuel ~) Ernie-83PT40 in Texas [Non-text portions of this message have been removed] |
05-05-2005, 09:39
Ignition switch
Just a note to mark a personal milestone. Took the old ignition switch
out, replaced it with a new bolted post one and reassembled the part of the console the previous owner had left. She now starts like a dream. Thanks to Mike Hoenstein for the pointer on the bolted terminals. Not the first repair, but the first correct one. Little details impress me. Glenn Shehorn 83FC35RB Kansas City Mo I think I am too easily amused |
05-05-2005, 09:41
Ignition switch
I'm glad that worked out for you.
Mike Hohnstein ----- Original Message ----- From: glenn_shehorn To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 05, 2005 4:39 PM Subject: [WanderlodgeForum] Ignition switch Just a note to mark a personal milestone. Took the old ignition switch out, replaced it with a new bolted post one and reassembled the part of the console the previous owner had left. She now starts like a dream. Thanks to Mike Hoenstein for the pointer on the bolted terminals. Not the first repair, but the first correct one. Little details impress me. Glenn Shehorn 83FC35RB Kansas City Mo I think I am too easily amused ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
09-24-2006, 01:29
Ignition switch
If you use graphite, put a towel around the switch, as graphite will stain
your floorcovering. I have seen many hinges on doors that on the carpet directly under the hinge, a black stain. Ernie Ekberg 83 PT40 Livingston, Montana [Non-text portions of this message have been removed] |
09-24-2006, 04:14
Ignition switch
Does anyone know the ignition switch make for 2004 M380. I can start
the engine from the rear switch but not the ignition switch. The keys have been a little sticky recently getting in. It seems to turn all the way to start-nothing happens. thanks, Jim O'Neil M380 |
09-24-2006, 05:00
Ignition switch
Jim,
Use compressed air with a spray tube and blow down into key opening. Try a squirt of graphite powder in the key switch. Also check the key for a burr. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: brystal9 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 24, 2006 12:14 PM Subject: [WanderlodgeForum] ignition switch Does anyone know the ignition switch make for 2004 M380. I can start the engine from the rear switch but not the ignition switch. The keys have been a little sticky recently getting in. It seems to turn all the way to start-nothing happens. thanks, Jim O'Neil M380 ------------------------------------------------------------------------------ Internal Virus Database is out-of-date. Checked by AVG Free Edition. Version: 7.1.405 / Virus Database: 268.12.3/445 - Release Date: 9/11/2006 [Non-text portions of this message have been removed] |
09-24-2006, 07:48
Ignition switch
If the key turns all the way to "Start", the pins and sheer
would seem to me be working as a key lock should though. Graphite powder would definitely help the stickyness. Wonder? Is there a theft-proof feature on the front that is not in the rear ignition circuit? Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Jim, > Use compressed air with a spray tube and blow down into key opening. > Try a squirt of graphite powder in the key switch. Also check the key for a burr. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > ----- Original Message ----- > From: brystal9 > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, September 24, 2006 12:14 PM > Subject: [WanderlodgeForum] ignition switch > > > Does anyone know the ignition switch make for 2004 M380. I can start > the engine from the rear switch but not the ignition switch. The keys > have been a little sticky recently getting in. It seems to turn all > the way to start-nothing happens. > > thanks, > Jim O'Neil > M380 > > > > > > > -------------------------------------------------------------------- ---------- > > > Internal Virus Database is out-of-date. > Checked by AVG Free Edition. > Version: 7.1.405 / Virus Database: 268.12.3/445 - Release Date: 9/11/2006 > > > [Non-text portions of this message have been removed] > |
09-24-2006, 08:35
Ignition switch
Jim,
Another thought, on my 86 PT40 you have to flip the toggle switch at the rear to crank from the rear and while set to crank from the rear it will not crank from the front. Happened to me. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: brystal9 To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 24, 2006 12:14 PM Subject: [WanderlodgeForum] ignition switch Does anyone know the ignition switch make for 2004 M380. I can start the engine from the rear switch but not the ignition switch. The keys have been a little sticky recently getting in. It seems to turn all the way to start-nothing happens. thanks, Jim O'Neil M380 ------------------------------------------------------------------------------ Internal Virus Database is out-of-date. Checked by AVG Free Edition. Version: 7.1.405 / Virus Database: 268.12.3/445 - Release Date: 9/11/2006 [Non-text portions of this message have been removed] |
09-24-2006, 23:00
Ignition switch
found out can't start the bus from the front with the engine door open!
thanks to all for your suggestions. Jim O'Neil M380 |
05-12-2009, 06:16
Ignition switch
Just spent the last two days chasing my tail trying to find a replacement
ignition switch for my 97 WB. Seems it is the same switch used for a long time and know it is used at least on the 85FC as well. Truck dealers don't stock this switch. I have gone to Kenworth, Peterbuilt, Ford truck, Freightliner and GMC truck. The place to get the switch is INTERNATIONAL, especially the school bus dealers. It appears that school buses (makes sense) use the same switch and the International part number is: 1652306C91. I replaced mine today. In the for what it's worth dept., I stopped by the BB bus dealer here and they have sent most of their parts back and didn't have the switch nor one that they could find in their parts book. For the archive, the Pollak part is 31-139 and the International part is 1652306C91. Now all I have to figure out is how to change the lock cylinder so the keys to the front ignition is the same as the rear ignition switch now that I have changed the front. Paul 97WB43 Silver Spring, MD |
