Hot Water Tank Dry Switch
06-01-2007, 11:00
I am redoing the water system in the coach. Can anyone tell me how the "Hot
water tank dry switch" works. I cannot find my sensor, and the orange wire which should go to the sensor is grounded, which allows the relay to disengage. If I went with plastic tubing, I would assume that the "T" fitting would have to be right next tothe tank so it can be grounded as well, either that, or ground the fitting. Any help would be appreciated. Thanks Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com [Non-text portions of this message have been removed] |
06-01-2007, 15:26
Bill,
The sensor on my '84FC is just a screw threaded into a plastic insulator in the center of a pipe plug mounted into a "T" on the hot water outlet of the water heater. My wire is also disconnected and grounded. When changing my water heater, I found the pipe plug was full of crap that may have prevented the wire from grounding. David Hollis 84FC35 Springfield,IL --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > I am redoing the water system in the coach. Can anyone tell me how the "Hot water tank dry switch" works. I cannot find my sensor, and the orange wire which should go to the sensor is grounded, which allows the relay to disengage. > If I went with plastic tubing, I would assume that the "T" fitting would have to be right next tothe tank so it can be grounded as well, either that, or ground the fitting. > Any help would be appreciated. > Thanks > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com > > [Non-text portions of this message have been removed] > |
