Driver's overhead panel
06-04-2007, 12:21
Does the driver's overhead panel have a common ground or anything like
that? I have several little problems with things up there (safeline buzzer will chirp on a good bump, left/right spotlight selector does nothing, digital clock will re-set to 12:00 on a good bump, gen oil press gauge reads high) and wondered if one thing might be causing all of it. Thanks Scott Forman 86 PT38 |
06-04-2007, 12:41
I am going to guess and say yes simply because I know all of my gauge grounds
are strung together (green wires). I have never traced down the end of it all but the nearest major ground to the overhead panel in my coach is the overhead load center which is behind the cabinet above the drivers head. I have to remove the back of the cabinet to access. Your coach is earlier than mine so that load center may be somewhere else. Perhaps some else knows specifically. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 04, 2007 7:21 PM Subject: [WanderlodgeForum] Driver's overhead panel Does the driver's overhead panel have a common ground or anything like that? I have several little problems with things up there (safeline buzzer will chirp on a good bump, left/right spotlight selector does nothing, digital clock will re-set to 12:00 on a good bump, gen oil press gauge reads high) and wondered if one thing might be causing all of it. Thanks Scott Forman 86 PT38 [Non-text portions of this message have been removed] |
