Any A/C Folks
06-04-2007, 13:40
Any A/C Folks
My coach has two a/c thermostats alike, cannot remember the
manufacturer, one on the front and one on the rear. The a/c fan blows constantly as the compressor cycle with these thermostats. They have an auto, off and on and a slide temperature control. The center a/c has a digital thermostat when set to a temperature shuts off completely when the desired temp is reached. It works like the one at home while the other two work like a window a/c. Can I change out the two thermostats to one like the center and get the a/c to stop and restart within the desired temperature range. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL |
06-04-2007, 14:59
Any A/C Folks
My coach has 3 "duo-therm by Dometic" thermostats that control the
ACs. They have a temperature set point (like a home thermostat) and when set to "cool" (right switch) and the left switch is set to "auto" the temperature selector will cause the fan speed to change and the compressor to cycle on/off -- and even cuts the fan off entirely if the temperature is "reached." This has been particularly pleasant with our recent stay in Texas as we were able to set the thermostat to a comfortable temperature, then the compressor would keep the air dry -- and eventually would slow down the fan and finally turn off both compressor and fan when it was sufficiently cool. This works quite nicely as the temperature would eventually cool down below 70 (outside) during the night, and otherwise somebody (me) would have to get up (amidst many complaints) to turn off the AC otherwise. I upgraded 2 of my 3 AC units to Dometic "high-efficency" ACs (10 amps for 13,500 btu instead of 15 amps for the same btu cooling power) and after inquiry to Dometic, I was told that these thermostats would work with the new ACs. Perhaps you can contact Dometic (assuming they're the AC you have) and see if they can suggest a compatible full range thermostat that will work with your AC. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Russell Kansas... after a looong drive from Tyler Texas.... On Jun 4, 2007, at 8:40 PM, jwasnewski wrote: > My coach has two a/c thermostats alike, cannot remember the > manufacturer, one on the front and one on the rear. The a/c fan blows > constantly as the compressor cycle with these thermostats. They > have an > auto, off and on and a slide temperature control. The center a/c has a > digital thermostat when set to a temperature shuts off completely when > the desired temp is reached. It works like the one at home while the > other two work like a window a/c. > Can I change out the two thermostats to one like the center and get > the > a/c to stop and restart within the desired temperature range. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > > Yahoo! Groups Links > > > |
06-05-2007, 03:49
Any A/C Folks
I believe mine are Domestic, will have to climb up top and see. I haven't had a
seconds trouble with any of them, knock on wood. I would just like for the fans to cut off. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 04, 2007 9:59 PM Subject: Re: [WanderlodgeForum] Any A/C Folks My coach has 3 "duo-therm by Dometic" thermostats that control the ACs. They have a temperature set point (like a home thermostat) and when set to "cool" (right switch) and the left switch is set to "auto" the temperature selector will cause the fan speed to change and the compressor to cycle on/off -- and even cuts the fan off entirely if the temperature is "reached." This has been particularly pleasant with our recent stay in Texas as we were able to set the thermostat to a comfortable temperature, then the compressor would keep the air dry -- and eventually would slow down the fan and finally turn off both compressor and fan when it was sufficiently cool. This works quite nicely as the temperature would eventually cool down below 70 (outside) during the night, and otherwise somebody (me) would have to get up (amidst many complaints) to turn off the AC otherwise. I upgraded 2 of my 3 AC units to Dometic "high-efficency" ACs (10 amps for 13,500 btu instead of 15 amps for the same btu cooling power) and after inquiry to Dometic, I was told that these thermostats would work with the new ACs. Perhaps you can contact Dometic (assuming they're the AC you have) and see if they can suggest a compatible full range thermostat that will work with your AC. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Russell Kansas... after a looong drive from Tyler Texas.... On Jun 4, 2007, at 8:40 PM, jwasnewski wrote: > My coach has two a/c thermostats alike, cannot remember the > manufacturer, one on the front and one on the rear. The a/c fan blows > constantly as the compressor cycle with these thermostats. They > have an > auto, off and on and a slide temperature control. The center a/c has a > digital thermostat when set to a temperature shuts off completely when > the desired temp is reached. It works like the one at home while the > other two work like a window a/c. > Can I change out the two thermostats to one like the center and get > the > a/c to stop and restart within the desired temperature range. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
