Safe Combo
05-05-2005, 14:19
Safe Combo
I tried the message archieve but it wouldn't work for me, so I thought I
would try you guys. My safe combo has been changed from the original factory setting as per 2 different locksmiths. They would have drilled it but since I assume it's empty and there are no replacement parts, I didn't see the point in ruining a great safe. I was going to hid a new one somewhere until I found these #'s under the couch seats covering the safe (shhhh, don't tell anyone). 50 452 Not really having used dial safes in the past I don't know the proper order of spins and what direction to start turning. Anyone have any advice? Al S. 1981 31' FC _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3 Sent: Thursday, May 05, 2005 5:37 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Headlight switch Hi Sid, I just replaced mine with one from Blue Bird. Was around $100 or so... like everything else. Brand was "ohmite". Was pretty easy to get to. New one works beautifully. Could not find a match at any auto parts stores, but did not try a "good" NAPA (the one here in Hershey is pretty sad) I can walk you throught the removal and installation if needed. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Sidney Breese" <ssbreese@a...> wrote: > Well, I think my switch has bit the dust. Some time ago I wrote that > the switch did not work in the parking position, but the headlight > came on, but the tail lights didn't. Someone suggested WD40 and that > worked for a while. Doesn't work this time. I have headlights, but > no marker or tailights. Does anyone know the brand or model of the > switch. I went to a couple of parts stores and the said I needed to > bring the old one in and they would match it. Everything is working > fine and I am not thinking of night driving, so I hate to take the > dash apart to get at the switch. Hoping someone has a model number. > thanks. > Sid Breese > 85PT40 > St. Joseph, MO _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. [Non-text portions of this message have been removed] |
05-05-2005, 14:35
Safe Combo
Don't drill the head/door, it is expensive. Drill the side of the
box, remove dinette booth to do so, box can easily be welded later. Two bolts hold it down, from inside the box. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "Al here" > I tried the message archieve but it wouldn't work for me, so I thought I > would try you guys. > > > > My safe combo has been changed from the original factory setting as per 2 > different locksmiths. They would have drilled it but since I assume it's > > empty and there are no replacement parts, I didn't see the point in ruining > a great safe. I was going to hid a new one somewhere until I found these > > #'s under the couch seats covering the safe (shhhh, don't tell anyone). > > > > 50 452 > > > > Not really having used dial safes in the past I don't know the proper order > of spins and what direction to start turning. Anyone have any advice? > > > > Al S. > > 1981 31' FC |
05-05-2005, 14:37
Safe Combo
Al,
The Dial - 4 or more turns to the left past the 1st number then stop on the 1st number...2 turns to the right past the 2nd number then stop on the 2nd number...1 turn to the left past the 3rd number then stop on the 3rd number...turn to right until dial clicks or stops...should open. I'm working from memory. Will check in the morning for notes that I made and can't find at the moment (CRS...again). Good luck. Curt Sprenger â87PT38, Anaheim, Calif. Al here wrote: > I tried the message archieve but it wouldn't work for me, so I thought I > would try you guys. > |
05-05-2005, 15:35
Safe Combo
Thanks Curt. No luck yet but I keep trying the numbers in different
combinations hoping I'll hit the right combo. Al S. -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger Sent: Thursday, May 05, 2005 7:38 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Safe Combo Al, The Dial - 4 or more turns to the left past the 1st number then stop on the 1st number...2 turns to the right past the 2nd number then stop on the 2nd number...1 turn to the left past the 3rd number then stop on the 3rd number...turn to right until dial clicks or stops...should open. I'm working from memory. Will check in the morning for notes that I made and can't find at the moment (CRS...again). Good luck. Curt Sprenger '87PT38, Anaheim, Calif. Al here wrote: > I tried the message archieve but it wouldn't work for me, so I thought I > would try you guys. > Yahoo! Groups Links |
05-05-2005, 22:22
Safe Combo
Hi AL,
My Safe needs six numbers in the combination to open. You may be missing a digit. Example is; 25 35 45 Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Al here" > I tried the message archieve but it wouldn't work for me, so I thought I > would try you guys. > > > > My safe combo has been changed from the original factory setting as per 2 > different locksmiths. They would have drilled it but since I assume it's > > empty and there are no replacement parts, I didn't see the point in ruining > a great safe. I was going to hid a new one somewhere until I found these > > #'s under the couch seats covering the safe (shhhh, don't tell anyone). > > > > 50 452 > > > > Not really having used dial safes in the past I don't know the proper order > of spins and what direction to start turning. Anyone have any advice? > > > > Al S. > > 1981 31' FC > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3 > Sent: Thursday, May 05, 2005 5:37 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Headlight switch > > > > Hi Sid, > > I just replaced mine with one from Blue Bird. Was around $100 or > so... like everything else. Brand was "ohmite". Was pretty easy to > get to. New one works beautifully. Could not find a match at any > auto parts stores, but did not try a "good" NAPA (the one here in > Hershey is pretty sad) I can walk you throught the removal and > installation if needed. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Sidney Breese" > <ssbreese@a...> wrote: > > Well, I think my switch has bit the dust. Some time ago I wrote > that > > the switch did not work in the parking position, but the headlight > > came on, but the tail lights didn't. Someone suggested WD40 and > that > > worked for a while. Doesn't work this time. I have headlights, > but > > no marker or tailights. Does anyone know the brand or model of the > > switch. I went to a couple of parts stores and the said I needed > to > > bring the old one in and they would match it. Everything is > working > > fine and I am not thinking of night driving, so I hate to take the > > dash apart to get at the switch. Hoping someone has a model > number. > > thanks. > > Sid Breese > > 85PT40 > > St. Joseph, MO > > > > > > _____ > > Yahoo! Groups Links > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! > <http://docs.yahoo.com/info/terms/> Terms of Service. > > > > [Non-text portions of this message have been removed] |
05-05-2005, 22:32
Safe Combo
I'M NOT AL. CHECK YOUR SEND ADDRESS. HATE TO SEE AL
MISS A MESSAAGE. SINCERELY, HANK HANNIGAN 90SP36 SYDNEY AUSTRALIA FOR NOW --- pattypape > Hi AL, > > My Safe needs six numbers in the combination to > open. > You may be missing a digit. > > Example is; 25 35 45 > > Bill 88 FC > > > --- In WanderlodgeForum@yahoogroups.com, "Al here" > > > I tried the message archieve but it wouldn't work > for me, so I > thought I > > would try you guys. > > > > > > > > My safe combo has been changed from the original > factory setting as > per 2 > > different locksmiths. They would have drilled it > but since I assume > it's > > > > empty and there are no replacement parts, I didn't > see the point in > ruining > > a great safe. I was going to hid a new one > somewhere until I found > these > > > > #'s under the couch seats covering the safe > (shhhh, don't tell > anyone). > > > > > > > > 50 452 > > > > > > > > Not really having used dial safes in the past I > don't know the > proper order > > of spins and what direction to start turning. > Anyone have any > advice? > > > > > > > > Al S. > > > > 1981 31' FC > > > > > > > > _____ > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On > Behalf Of sfedeli3 > > Sent: Thursday, May 05, 2005 5:37 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] Re: Headlight switch > > > > > > > > Hi Sid, > > > > I just replaced mine with one from Blue Bird. > Was around $100 or > > so... like everything else. Brand was "ohmite". > Was pretty easy to > > get to. New one works beautifully. Could not find > a match at any > > auto parts stores, but did not try a "good" NAPA > (the one here in > > Hershey is pretty sad) I can walk you throught the > removal and > > installation if needed. > > > > Shane Fedeli > > 85PT40 > > Hershey, PA > > > > --- In WanderlodgeForum@yahoogroups.com, "Sidney > Breese" > > <ssbreese@a...> wrote: > > > Well, I think my switch has bit the dust. Some > time ago I wrote > > that > > > the switch did not work in the parking position, > but the headlight > > > came on, but the tail lights didn't. Someone > suggested WD40 and > > that > > > worked for a while. Doesn't work this time. I > have headlights, > > but > > > no marker or tailights. Does anyone know the > brand or model of > the > > > switch. I went to a couple of parts stores and > the said I needed > > to > > > bring the old one in and they would match it. > Everything is > > working > > > fine and I am not thinking of night driving, so > I hate to take the > > > dash apart to get at the switch. Hoping someone > has a model > > number. > > > thanks. > > > Sid Breese > > > 85PT40 > > > St. Joseph, MO > > > > > > > > > > > > _____ > > > > Yahoo! Groups Links > > > > * To visit your group on the web, go to: > > http://groups.yahoo.com/group/WanderlodgeForum/ > > > > * To unsubscribe from this group, send an email > to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > * Your use of Yahoo! Groups is subject to the > Yahoo! > > <http://docs.yahoo.com/info/terms/> Terms of > Service. > > > > > > > > [Non-text portions of this message have been > removed] > > > __________________________________ Do you Yahoo!? Read only the mail you want - Yahoo! Mail SpamGuard. http://promotions.yahoo.com/new_mail |
05-06-2005, 01:08
Safe Combo
At 07:35 PM 5/5/2005, you wrote:
>Don't drill the head/door, it is expensive. Drill the side of the >box, remove dinette booth to do so, box can easily be welded later. >Two bolts hold it down, from inside the box. > >- Jeff Miller Jeff, I located where the bolts were, drilled a small hole in the side of the wood frame and used an air chisel to cut through the bolts. Took about ten minutes and I didn't have to do any welding..... Took the box up to the local key man and he had it open pretty quick... Blair in Oregon [Non-text portions of this message have been removed] |
05-06-2005, 01:51
Safe Combo
Blair, Do you think he could crack the safe without
removing it? How are things? Bill "Blue Goose" 91pt40 norcal ----- Original Message ----- From: Blair To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 06, 2005 6:08 AM Subject: Re: [WanderlodgeForum] Re: Safe Combo At 07:35 PM 5/5/2005, you wrote: >Don't drill the head/door, it is expensive. Drill the side of the >box, remove dinette booth to do so, box can easily be welded later. >Two bolts hold it down, from inside the box. > >- Jeff Miller Jeff, I located where the bolts were, drilled a small hole in the side of the wood frame and used an air chisel to cut through the bolts. Took about ten minutes and I didn't have to do any welding..... Took the box up to the local key man and he had it open pretty quick... Blair in Oregon [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-06-2005, 02:02
Safe Combo
Hi Bill! Nice to see you're still around...how about setting up a meet
some day? Had to take the safe out....the klutz who bolted it in did it in such a way that you could only see the numbers with a mirror..........locksmith said take it out and I'll open it.......previous owner was probably a dyslectic with mirror vision. Blair in Oregon.....raining again, the grass is up to my mid thighs, so thick it's going to be a real B______ to cut. At 06:51 AM 5/6/2005, you wrote: >Blair, Do you think he could crack the safe without >removing it? How are things? >Bill "Blue Goose" 91pt40 norcal > ----- Original Message ----- > From: Blair > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, May 06, 2005 6:08 AM > Subject: Re: [WanderlodgeForum] Re: Safe Combo > > > At 07:35 PM 5/5/2005, you wrote: > >Don't drill the head/door, it is expensive. Drill the side of the > >box, remove dinette booth to do so, box can easily be welded later. > >Two bolts hold it down, from inside the box. > > > >- Jeff Miller > > > Jeff, > I located where the bolts were, drilled a small hole in the side of > the wood frame and used an air chisel to cut through the bolts. Took about > ten minutes and I didn't have to do any welding..... > Took the box up to the local key man and he had it open pretty > quick... > > Blair in Oregon > > [Non-text portions of this message have been removed] > > > >------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > ><http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/\ WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > >[Non-text portions of this message have been removed] > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-06-2005, 02:14
Safe Combo
Hello Al,
Just had my Safe serviced and reset. The Combination is (usualy) Left 4 turns to # ? Right 3 turns to # ? left 2 turns to # ? Right 1 turn to STOP Kurt 83FC35SB in NH --- In WanderlodgeForum@yahoogroups.com, "Al here" > I tried the message archieve but it wouldn't work for me, so I thought I > would try you guys. > > > > My safe combo has been changed from the original factory setting as per 2 > different locksmiths. They would have drilled it but since I assume it's > > empty and there are no replacement parts, I didn't see the point in ruining > a great safe. I was going to hid a new one somewhere until I found these > > #'s under the couch seats covering the safe (shhhh, don't tell anyone). > > > > 50 452 > > > > Not really having used dial safes in the past I don't know the proper order > of spins and what direction to start turning. Anyone have any advice? > > > > Al S. > > 1981 31' FC > > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sfedeli3 > Sent: Thursday, May 05, 2005 5:37 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Headlight switch > > > > Hi Sid, > > I just replaced mine with one from Blue Bird. Was around $100 or > so... like everything else. Brand was "ohmite". Was pretty easy to > get to. New one works beautifully. Could not find a match at any > auto parts stores, but did not try a "good" NAPA (the one here in > Hershey is pretty sad) I can walk you throught the removal and > installation if needed. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Sidney Breese" > <ssbreese@a...> wrote: > > Well, I think my switch has bit the dust. Some time ago I wrote > that > > the switch did not work in the parking position, but the headlight > > came on, but the tail lights didn't. Someone suggested WD40 and > that > > worked for a while. Doesn't work this time. I have headlights, > but > > no marker or tailights. Does anyone know the brand or model of the > > switch. I went to a couple of parts stores and the said I needed > to > > bring the old one in and they would match it. Everything is > working > > fine and I am not thinking of night driving, so I hate to take the > > dash apart to get at the switch. Hoping someone has a model > number. > > thanks. > > Sid Breese > > 85PT40 > > St. Joseph, MO > > > > > > _____ > > Yahoo! Groups Links > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! > <http://docs.yahoo.com/info/terms/> Terms of Service. > > > > [Non-text portions of this message have been removed] |
