Powertech Generator --engine not running right.
06-05-2007, 08:23
Pete- do you have a separate Racor filter for your generator. Maybe its a
fuel starvation problem?
83PT40
Livingston, Mt
06-05-2007, 12:19
Yesterday and again today, the Powertech 15kw generator started
acting up. The problem seems to be the Kubota diesel engine. The
exhaust is black and sooty and the engine isn't putting out full
power (noted that the voltage had dropped down to 100 vac from the
usual 120 vac)
I changed the air filter last summer -- solving a sooty exhaust
problem (without any loss of power) at that time, but this seems more
serious. A couple of weeks ago, I started the generator, I thought
perhaps, prematurely without allowing the glow plugs to run long
enough as the engine was clearly stumbling and not running on all
cylinders.
Looking at the engine, it appears that on injector has been replaced
(from the look of the paint, etc.) so the engine may have had
problems in the past.
I'll call Powertech tomorrow, but I'd appreciate any thoughts anyone
may care to offer.
aeonix1@...
On the road at Denver Colorado
06-05-2007, 12:32
Black exhaust is overfueling. This could equal underairing. I'd check the air
filter again to
see if it is clean. The other factor to consider is the elevation. Denver air
is thin enough
that unless the engine has an altitude compensator of some kind, you may be
running rich
simply due to the elevation.
Diesels Only on West Alameda is a good shop if it turns out you need mechanical
service.
Kerry
82 FC 35
Denver
> usual 120 vac)
> cylinders.
> may care to offer.
> Pete Masterson
> aeonix1@...
06-05-2007, 13:37
No Racor for the genny. I replaced the fuel filter (a spin on one)
last summer when I changed the air filter. I have a spare with me ...
I can put it on...
But with all the soot and smoke, it seems like there's plenty of fuel
-- it's just not burning right.
aeonix1@...
> its a
> Ernie Ekberg
> 83PT40
> Livingston, Mt
06-05-2007, 13:41
I considered the altitude. I had a bit of black smoke when I was
through here last year when I bought the coach ... but this is a
_lot_ more black smoke. I was getting some while in Texas -- some
3000 ft lower elevation.
I'll swap the air filter (I have a spare on board) and see if that
helps.
aeonix1@...
Sitting in the Camping World parking lot in Denver waiting for an AC
service in the morning...
> check the air filter again to
> elevation. Denver air is thin enough
> you may be running rich
> need mechanical service.
> Kerry
> 82 FC 35
> Denver
>> usual 120 vac)
>> cylinders.
>> may care to offer.
>> Pete Masterson
>> aeonix1@...
06-05-2007, 14:35
That parking lot is pretty clean. You might try running it for a minute with
the filter
removed and see if you get enough air flow to solve the problem.
Kerry
82 FC 35
Denver
> helps.
> Pete Masterson
> aeonix1@...
> > Kerry
> > 82 FC 35
> > Denver
> >> usual 120 vac)
> >> cylinders.
> >> may care to offer.
> >> Pete Masterson
> >> aeonix1@
06-05-2007, 14:48
Kerry,
Thanks ... I just put on a new filter, and the genny is back to
normal. Voltage is up to 127 on my multimeter -- the exhaust is
slightly black -- and _that_ I attribute to the altitude. I must have
encountered more dust along the way than I thought.
aeonix1@...
Sitting in a Camping World parking lot for the night in Denver Colorado.
> minute with the filter
> Kerry
> 82 FC 35
> Denver
>> helps.
>> Pete Masterson
>> aeonix1@...
>>> Kerry
>>> 82 FC 35
>>> Denver
>>>> usual 120 vac)
>>>> more
>>>> cylinders.
>>>> replaced
>>>> anyone
>>>> may care to offer.
>>>> Pete Masterson
>>>> aeonix1@
> Yahoo! Groups Links
06-05-2007, 15:03
Glad it's fixed. It's a little late to be telling you this now, but the town of
Golden has a nice
RV park along Clear Creek just west of you. It's not listed in any guidebook
that I've seen
but it's in town, right on the creek at the Whitewater Park adjacent to a very
nice recreation
center/park with a bike path that runs right along the creek. Just a short walk
to Coors
and it's tour.
Kerry
82 Fc 35
Denver
> Kerry,
> Pete Masterson
06-05-2007, 15:19
Pete, the electric fan that cools the radiator creates major dust.
Good filters choak up fast. when you run a diesel rich for a period
of time, it is always a good idea to change the oil.
GregoryO'Connor
94ptRomolandCa
> Kerry,
have
> Pete Masterson
> aeonix1@...
Colorado.
a
> > Kerry
> > 82 FC 35
> > Denver
that
> >> helps.
> >> Pete Masterson
> >> aeonix1@
an AC
I'd
> >>> Kerry
> >>> 82 FC 35
> >>> Denver
The
full
> >>>> usual 120 vac)
seems
> >>>> more
thought
long
all
> >>>> cylinders.
> >>>> replaced
> >>>> anyone
> >>>> may care to offer.
> >>>> Pete Masterson
> >>>> aeonix1@
> > Yahoo! Groups Links
06-06-2007, 00:49
A frenchman with a flamingo posted that the crank case breather on
the powertecs vent too close to the airfilter and the paper element
gets a oily residu which gums up with dust quickly. I plan to take
Randys advice, heed the warning of Petes discovery and vent the
crankcase tube out of the airtight compartment.
GregoryO'Connor
94ptRomolandCa
> GregoryO'Connor
> 94ptRomolandCa
> > Kerry,
> have
> > Pete Masterson
> > aeonix1@
> Colorado.
> a
> > > Kerry
> > > 82 FC 35
> > > Denver
was
is a
some
> that
> > >> helps.
> > >> Pete Masterson
> > >> aeonix1@
> an AC
> I'd
kind,
you
> > >>> Kerry
> > >>> 82 FC 35
> > >>> Denver
started
> The
> full
from
> the
> > >>>> usual 120 vac)
exhaust
> seems
> > >>>> more
> thought
> long
on
> all
> > >>>> cylinders.
> > >>>> replaced
thoughts
> > >>>> anyone
> > >>>> may care to offer.
> > >>>> Pete Masterson
> > >>>> aeonix1@
> > > Yahoo! Groups Links
