3K trip over 2 weeks, should I do this service or wait
06-06-2007, 11:19
I am about to take our WB on its first long haul trip which will
total about 3K miles in all. I am going to change the engine and transmission oil and assocaited filters. I am carring extra primary and secondary fuel filters with me. The real question is, the prior owner admitted that in the 10 years he owned it that he did basic oil and trans service but never did any coolant service. So that scares me, and all though I have not checked, I can promise it is out of balance. I should note here, that I am not currently having over heating problems. Just want to get my coach caught up on service. Should I dump the coolant, flush the system (I have Permatex Heavy Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, repeat, then add 12 gallons antifreeze, 12 gallons distilled water, and 7 pints Pencool 2000? Or should I test it, get it in balance, take the trip and do the coolant service when I return? I am a little concerned that flushing the system may cause leaks to occur that are not currently known and that would either prevent my trip or cause issues on the road. Looking for some advice from the community. Michael Brundridge 1992 WB40 Georgetown, TX |
06-06-2007, 11:34
Michael,
I look at it this way... Either you can change it now and know what you are starting with or not and chance having to have it changed on the road. I can promise you, it will be cheaper now. Then you and your family can enjoy your trip. Al, Kathy Johnson '96 BMC B100 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > I am about to take our WB on its first long haul trip which will > total about 3K miles in all. > > I am going to change the engine and transmission oil and assocaited > filters. I am carring extra primary and secondary fuel filters with > me. > > The real question is, the prior owner admitted that in the 10 years > he owned it that he did basic oil and trans service but never did any > coolant service. So that scares me, and all though I have not > checked, I can promise it is out of balance. > > I should note here, that I am not currently having over heating > problems. Just want to get my coach caught up on service. > > Should I dump the coolant, flush the system (I have Permatex Heavy > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, repeat, > then add 12 gallons antifreeze, 12 gallons distilled water, and 7 > pints Pencool 2000? > > Or should I test it, get it in balance, take the trip and do the > coolant service when I return? > > I am a little concerned that flushing the system may cause leaks to > occur that are not currently known and that would either prevent my > trip or cause issues on the road. Looking for some advice from the > community. > > Michael Brundridge > 1992 WB40 > Georgetown, TX > |
06-06-2007, 11:44
I'd test it before making any decision. If it tests reasonably well and can be
brought back into balance, I wouldn't be in any big hurry to replace it. A few weeks and a few thousand miles are unlikely to make a significant difference if the coolant is within specs. It will still carry away the heat. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > I am about to take our WB on its first long haul trip which will > total about 3K miles in all. > > I am going to change the engine and transmission oil and assocaited > filters. I am carring extra primary and secondary fuel filters with > me. > > The real question is, the prior owner admitted that in the 10 years > he owned it that he did basic oil and trans service but never did any > coolant service. So that scares me, and all though I have not > checked, I can promise it is out of balance. > > I should note here, that I am not currently having over heating > problems. Just want to get my coach caught up on service. > > Should I dump the coolant, flush the system (I have Permatex Heavy > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, repeat, > then add 12 gallons antifreeze, 12 gallons distilled water, and 7 > pints Pencool 2000? > > Or should I test it, get it in balance, take the trip and do the > coolant service when I return? > > I am a little concerned that flushing the system may cause leaks to > occur that are not currently known and that would either prevent my > trip or cause issues on the road. Looking for some advice from the > community. > > Michael Brundridge > 1992 WB40 > Georgetown, TX > |
06-06-2007, 15:05
The most important item is the balance. If the coolant is clean, then
just make sure it is in balance and go on your trip. That 3000 miles is not going to make much difference. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > I am about to take our WB on its first long haul trip which will > total about 3K miles in all. > > I am going to change the engine and transmission oil and assocaited > filters. I am carring extra primary and secondary fuel filters with > me. > > The real question is, the prior owner admitted that in the 10 years > he owned it that he did basic oil and trans service but never did any > coolant service. So that scares me, and all though I have not > checked, I can promise it is out of balance. > > I should note here, that I am not currently having over heating > problems. Just want to get my coach caught up on service. > > Should I dump the coolant, flush the system (I have Permatex Heavy > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, repeat, > then add 12 gallons antifreeze, 12 gallons distilled water, and 7 > pints Pencool 2000? > > Or should I test it, get it in balance, take the trip and do the > coolant service when I return? > > I am a little concerned that flushing the system may cause leaks to > occur that are not currently known and that would either prevent my > trip or cause issues on the road. Looking for some advice from the > community. > > Michael Brundridge > 1992 WB40 > Georgetown, TX > |
06-07-2007, 02:32
Michael, When you check the balance, you need a homonogous mix of all
the fluids in the bus. there are valves that limit the path of coolant for summer and winter. even the hotwater heater gets passed with engine cooling fluid. I would ;run the bus ;run chassis heat and primus heat then take a test of the fluid. Then if you have one, replace the coolant filter and cut open the old one. I would not use the cleaner as there is no way to check the interior of the heat exchanger tranny cooler (looks like a big pipe under radiator) and the acid will pass through all the non typical appliances not found in apps where that cleaner is used. If you balance a homonogous mix of existing fluids, you will know what you are starting with. On the road you can always replace 5 gal of fluid in the event 1000 miles down the road the test strips show a change in balance. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Al" > > Michael, > I look at it this way... Either you can change it now and know > what you are starting with or not and chance having to have it > changed on the road. I can promise you, it will be cheaper now. > Then you and your family can enjoy your trip. > > Al, Kathy Johnson > '96 BMC B100 > Mandeville, Louisiana > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > I am about to take our WB on its first long haul trip which will > > total about 3K miles in all. > > > > I am going to change the engine and transmission oil and assocaited > > filters. I am carring extra primary and secondary fuel filters > with > > me. > > > > The real question is, the prior owner admitted that in the 10 years > > he owned it that he did basic oil and trans service but never did > any > > coolant service. So that scares me, and all though I have not > > checked, I can promise it is out of balance. > > > > I should note here, that I am not currently having over heating > > problems. Just want to get my coach caught up on service. > > > > Should I dump the coolant, flush the system (I have Permatex Heavy > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, repeat, > > then add 12 gallons antifreeze, 12 gallons distilled water, and 7 > > pints Pencool 2000? > > > > Or should I test it, get it in balance, take the trip and do the > > coolant service when I return? > > > > I am a little concerned that flushing the system may cause leaks to > > occur that are not currently known and that would either prevent my > > trip or cause issues on the road. Looking for some advice from the > > community. > > > > Michael Brundridge > > 1992 WB40 > > Georgetown, TX > > > |
06-07-2007, 02:48
So in a 1992 WB40, the Primus antifreeze is also part of the cooling
system? For some reason I thought they where seperate systems and used a heat exchanger between them. I will go out and fire up the coach now and run all the systems so the fluid gets circulated as I am going to town in a little bit to pickup test strips to test the balance. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Michael, When you check the balance, you need a homonogous mix of all > the fluids in the bus. there are valves that limit the path of > coolant for summer and winter. even the hotwater heater gets passed > with engine cooling fluid. I would ;run the bus ;run chassis heat > and primus heat then take a test of the fluid. Then if you have one, > replace the coolant filter and cut open the old one. I would not use > the cleaner as there is no way to check the interior of the heat > exchanger tranny cooler (looks like a big pipe under radiator) and > the acid will pass through all the non typical appliances not found > in apps where that cleaner is used. > > If you balance a homonogous mix of existing fluids, you will know > what you are starting with. On the road you can always replace 5 gal > of fluid in the event 1000 miles down the road the test strips show a > change in balance. > > GregoryO'Connor > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Al" > > > > Michael, > > I look at it this way... Either you can change it now and know > > what you are starting with or not and chance having to have it > > changed on the road. I can promise you, it will be cheaper now. > > Then you and your family can enjoy your trip. > > > > Al, Kathy Johnson > > '96 BMC B100 > > Mandeville, Louisiana > > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > > > I am about to take our WB on its first long haul trip which will > > > total about 3K miles in all. > > > > > > I am going to change the engine and transmission oil and > assocaited > > > filters. I am carring extra primary and secondary fuel filters > > with > > > me. > > > > > > The real question is, the prior owner admitted that in the 10 > years > > > he owned it that he did basic oil and trans service but never did > > any > > > coolant service. So that scares me, and all though I have not > > > checked, I can promise it is out of balance. > > > > > > I should note here, that I am not currently having over heating > > > problems. Just want to get my coach caught up on service. > > > > > > Should I dump the coolant, flush the system (I have Permatex > Heavy > > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, > repeat, > > > then add 12 gallons antifreeze, 12 gallons distilled water, and 7 > > > pints Pencool 2000? > > > > > > Or should I test it, get it in balance, take the trip and do the > > > coolant service when I return? > > > > > > I am a little concerned that flushing the system may cause leaks > to > > > occur that are not currently known and that would either prevent > my > > > trip or cause issues on the road. Looking for some advice from > the > > > community. > > > > > > Michael Brundridge > > > 1992 WB40 > > > Georgetown, TX > > > > > > |
06-07-2007, 06:04
The Primus is not a part of the engine cooling system, at least it isn't on
mine. There should be two small white plastic bottles at the rear of the bus up high that are the reservoirs. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: mbrund To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 07, 2007 9:48 AM Subject: [WanderlodgeForum] Re: 3K trip over 2 weeks, should I do this service or wait So in a 1992 WB40, the Primus antifreeze is also part of the cooling system? For some reason I thought they where seperate systems and used a heat exchanger between them. I will go out and fire up the coach now and run all the systems so the fluid gets circulated as I am going to town in a little bit to pickup test strips to test the balance. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Michael, When you check the balance, you need a homonogous mix of all > the fluids in the bus. there are valves that limit the path of > coolant for summer and winter. even the hotwater heater gets passed > with engine cooling fluid. I would ;run the bus ;run chassis heat > and primus heat then take a test of the fluid. Then if you have one, > replace the coolant filter and cut open the old one. I would not use > the cleaner as there is no way to check the interior of the heat > exchanger tranny cooler (looks like a big pipe under radiator) and > the acid will pass through all the non typical appliances not found > in apps where that cleaner is used. > > If you balance a homonogous mix of existing fluids, you will know > what you are starting with. On the road you can always replace 5 gal > of fluid in the event 1000 miles down the road the test strips show a > change in balance. > > GregoryO'Connor > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Al" > > > > Michael, > > I look at it this way... Either you can change it now and know > > what you are starting with or not and chance having to have it > > changed on the road. I can promise you, it will be cheaper now. > > Then you and your family can enjoy your trip. > > > > Al, Kathy Johnson > > '96 BMC B100 > > Mandeville, Louisiana > > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > > > I am about to take our WB on its first long haul trip which will > > > total about 3K miles in all. > > > > > > I am going to change the engine and transmission oil and > assocaited > > > filters. I am carring extra primary and secondary fuel filters > > with > > > me. > > > > > > The real question is, the prior owner admitted that in the 10 > years > > > he owned it that he did basic oil and trans service but never did > > any > > > coolant service. So that scares me, and all though I have not > > > checked, I can promise it is out of balance. > > > > > > I should note here, that I am not currently having over heating > > > problems. Just want to get my coach caught up on service. > > > > > > Should I dump the coolant, flush the system (I have Permatex > Heavy > > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, > repeat, > > > then add 12 gallons antifreeze, 12 gallons distilled water, and 7 > > > pints Pencool 2000? > > > > > > Or should I test it, get it in balance, take the trip and do the > > > coolant service when I return? > > > > > > I am a little concerned that flushing the system may cause leaks > to > > > occur that are not currently known and that would either prevent > my > > > trip or cause issues on the road. Looking for some advice from > the > > > community. > > > > > > Michael Brundridge > > > 1992 WB40 > > > Georgetown, TX > > > > > > [Non-text portions of this message have been removed] |
06-07-2007, 08:50
I tested the coolant with a coolant test strip at 90 degree coolant
temp: Alkalinity = 6.6, Glycol = 50%, pH = 7.5, Molybdate = 0 PPM, Nitrite = 800 PPM. From what I can determine, Nalcool/Pencool 2000 does not use Molybdate, just Nitrite in its SCA package. So it looks like I need to add a little over 1 pint to bring it into spec. The sample I took has scale in it, so I will need to do a through flush when I return home, but for now I believe I will just add between 1 and 2 pints of Pencool 2000 and go on my trip. I will do the flushing and replacing of coolant when I return. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > The most important item is the balance. If the coolant is clean, then > just make sure it is in balance and go on your trip. That 3000 miles > is not going to make much difference. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > I am about to take our WB on its first long haul trip which will > > total about 3K miles in all. > > > > I am going to change the engine and transmission oil and assocaited > > filters. I am carring extra primary and secondary fuel filters with > > me. > > > > The real question is, the prior owner admitted that in the 10 years > > he owned it that he did basic oil and trans service but never did any > > coolant service. So that scares me, and all though I have not > > checked, I can promise it is out of balance. > > > > I should note here, that I am not currently having over heating > > problems. Just want to get my coach caught up on service. > > > > Should I dump the coolant, flush the system (I have Permatex Heavy > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, repeat, > > then add 12 gallons antifreeze, 12 gallons distilled water, and 7 > > pints Pencool 2000? > > > > Or should I test it, get it in balance, take the trip and do the > > coolant service when I return? > > > > I am a little concerned that flushing the system may cause leaks to > > occur that are not currently known and that would either prevent my > > trip or cause issues on the road. Looking for some advice from the > > community. > > > > Michael Brundridge > > 1992 WB40 > > Georgetown, TX > > > |
06-07-2007, 08:54
Leroy,
Mine is the same as yours with the two small plastic bottles located on the curb side upper engine compartment. In my response to Gregory I said I believed it to be a closed loop system and not part of the coolant system and I see nothing that would make me believe otherwise. Michael Brundridge 1992 WB40 Georgetown, TX --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > The Primus is not a part of the engine cooling system, at least it isn't on mine. There should be two small white plastic bottles at the rear of the bus up high that are the reservoirs. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: mbrund > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, June 07, 2007 9:48 AM > Subject: [WanderlodgeForum] Re: 3K trip over 2 weeks, should I do this service or wait > > > So in a 1992 WB40, the Primus antifreeze is also part of the cooling > system? For some reason I thought they where seperate systems and > used a heat exchanger between them. I will go out and fire up the > coach now and run all the systems so the fluid gets circulated as I > am going to town in a little bit to pickup test strips to test the > balance. > > Michael Brundridge > 1992 WB40 > Georgetown, TX > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Michael, When you check the balance, you need a homonogous mix of > all > > the fluids in the bus. there are valves that limit the path of > > coolant for summer and winter. even the hotwater heater gets passed > > with engine cooling fluid. I would ;run the bus ;run chassis heat > > and primus heat then take a test of the fluid. Then if you have > one, > > replace the coolant filter and cut open the old one. I would not > use > > the cleaner as there is no way to check the interior of the heat > > exchanger tranny cooler (looks like a big pipe under radiator) and > > the acid will pass through all the non typical appliances not > found > > in apps where that cleaner is used. > > > > If you balance a homonogous mix of existing fluids, you will know > > what you are starting with. On the road you can always replace 5 > gal > > of fluid in the event 1000 miles down the road the test strips show > a > > change in balance. > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Al" > > > > > > Michael, > > > I look at it this way... Either you can change it now and > know > > > what you are starting with or not and chance having to have it > > > changed on the road. I can promise you, it will be cheaper now. > > > Then you and your family can enjoy your trip. > > > > > > Al, Kathy Johnson > > > '96 BMC B100 > > > Mandeville, Louisiana > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > > > > > I am about to take our WB on its first long haul trip which > will > > > > total about 3K miles in all. > > > > > > > > I am going to change the engine and transmission oil and > > assocaited > > > > filters. I am carring extra primary and secondary fuel filters > > > with > > > > me. > > > > > > > > The real question is, the prior owner admitted that in the 10 > > years > > > > he owned it that he did basic oil and trans service but never > did > > > any > > > > coolant service. So that scares me, and all though I have not > > > > checked, I can promise it is out of balance. > > > > > > > > I should note here, that I am not currently having over heating > > > > problems. Just want to get my coach caught up on service. > > > > > > > > Should I dump the coolant, flush the system (I have Permatex > > Heavy > > > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, > > repeat, > > > > then add 12 gallons antifreeze, 12 gallons distilled water, and > 7 > > > > pints Pencool 2000? > > > > > > > > Or should I test it, get it in balance, take the trip and do > the > > > > coolant service when I return? > > > > > > > > I am a little concerned that flushing the system may cause > leaks > > to > > > > occur that are not currently known and that would either > prevent > > my > > > > trip or cause issues on the road. Looking for some advice from > > the > > > > community. > > > > > > > > Michael Brundridge > > > > 1992 WB40 > > > > Georgetown, TX > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
06-07-2007, 12:05
I think you will find that the systems are separate.
R.E. (Ron) Marabito, Dallas, tX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@...> wrote: > > So in a 1992 WB40, the Primus antifreeze is also part of the cooling > system? For some reason I thought they where seperate systems and > used a heat exchanger between them. I will go out and fire up the > coach now and run all the systems so the fluid gets circulated as I > am going to town in a little bit to pickup test strips to test the > balance. > > Michael Brundridge > 1992 WB40 > Georgetown, TX > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Michael, When you check the balance, you need a homonogous mix of > all > > the fluids in the bus. there are valves that limit the path of > > coolant for summer and winter. even the hotwater heater gets passed > > with engine cooling fluid. I would ;run the bus ;run chassis heat > > and primus heat then take a test of the fluid. Then if you have > one, > > replace the coolant filter and cut open the old one. I would not > use > > the cleaner as there is no way to check the interior of the heat > > exchanger tranny cooler (looks like a big pipe under radiator) and > > the acid will pass through all the non typical appliances not > found > > in apps where that cleaner is used. > > > > If you balance a homonogous mix of existing fluids, you will know > > what you are starting with. On the road you can always replace 5 > gal > > of fluid in the event 1000 miles down the road the test strips show > a > > change in balance. > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Al" > > > > > > Michael, > > > I look at it this way... Either you can change it now and > know > > > what you are starting with or not and chance having to have it > > > changed on the road. I can promise you, it will be cheaper now. > > > Then you and your family can enjoy your trip. > > > > > > Al, Kathy Johnson > > > '96 BMC B100 > > > Mandeville, Louisiana > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mbrund" <mbrund@> wrote: > > > > > > > > I am about to take our WB on its first long haul trip which > will > > > > total about 3K miles in all. > > > > > > > > I am going to change the engine and transmission oil and > > assocaited > > > > filters. I am carring extra primary and secondary fuel filters > > > with > > > > me. > > > > > > > > The real question is, the prior owner admitted that in the 10 > > years > > > > he owned it that he did basic oil and trans service but never > did > > > any > > > > coolant service. So that scares me, and all though I have not > > > > checked, I can promise it is out of balance. > > > > > > > > I should note here, that I am not currently having over heating > > > > problems. Just want to get my coach caught up on service. > > > > > > > > Should I dump the coolant, flush the system (I have Permatex > > Heavy > > > > Duty Radiator Cleaner, bascially Hydrochloric Acid), rinse, > > repeat, > > > > then add 12 gallons antifreeze, 12 gallons distilled water, and > 7 > > > > pints Pencool 2000? > > > > > > > > Or should I test it, get it in balance, take the trip and do > the > > > > coolant service when I return? > > > > > > > > I am a little concerned that flushing the system may cause > leaks > > to > > > > occur that are not currently known and that would either > prevent > > my > > > > trip or cause issues on the road. Looking for some advice from > > the > > > > community. > > > > > > > > Michael Brundridge > > > > 1992 WB40 > > > > Georgetown, TX > > > > > > > > > > |
