What type of ATF for HWH?
06-07-2007, 15:07
Can I just use regular old Dexron III in the leveling jacks? My HWH
manual says "type A" or "type B" transmission fluid and I'm not familiar with that - neither are the people at the local auto store. I just need to top it off & it's clearly got some type of ATF in it now. Thank you! -Ryan '86 PT-40 8V92 Tri-Cities, WA |
06-07-2007, 15:27
I use the Dexron III and it seems to work fine.
Robert Britton 87FC Hollister, California --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Can I just use regular old Dexron III in the leveling jacks? My HWH > manual says "type A" or "type B" transmission fluid and I'm not > familiar with that - neither are the people at the local auto store. I > just need to top it off & it's clearly got some type of ATF in it now. > > Thank you! > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > |
06-08-2007, 02:03
Ryan,
HWH is in business give them a call and pose your question. I would think they had a reason for there reccomendation. Then post there reccomendation on the forum. Howard Truitt Camilla, Ga. 86 PT40 > > From: "Ryan Wright" > Date: 2007/06/07 Thu PM 11:07:11 EDT > To: WanderlodgeForum@yahoogroups.com, wanderlodge@yahoogroups.com > Subject: [WanderlodgeForum] What type of ATF for HWH? > > Can I just use regular old Dexron III in the leveling jacks? My HWH > manual says "type A" or "type B" transmission fluid and I'm not > familiar with that - neither are the people at the local auto store. I > just need to top it off & it's clearly got some type of ATF in it now. > > Thank you! > > -Ryan > '86 PT-40 8V92 > Tri-Cities, WA > > |
06-08-2007, 03:16
Thanks all for your responses. Dexron III it is. Seemed to work fine,
jacks can extend fully now (it was a quart low). Funny, though, how heavy this bus is and how soft the soil at my house must be. I told it to level and watched all four jacks punch a 1 to 2 foot deep hole into the ground. Hah! I'm going to have to put some wood under the jacks next time, and/or just concrete the RV parking. :-) -Ryan '86 PT-40 8V92 Tri-Cities, WA On 6/7/07, Curt Sprenger > Ryan, > Dexron III will work. That is what I have used, no problems. Contact > HWH on the web or call them to validate. I believe they will agree with > III. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Ryan Wright wrote: > > > Can I just use regular old Dexron III in the leveling jacks? My HWH > > manual says "type A" or "type B" transmission fluid and I'm not > > familiar with that - neither are the people at the local auto store. I > > just need to top it off & it's clearly got some type of ATF in it now. > > > > Thank you! > > > > -Ryan > > '86 PT-40 8V92 > > Tri-Cities, WA > > > > > > > > > Yahoo! Groups Links > > > > |
06-08-2007, 03:23
Ryan,
At home base I always put wood under the jacks, I park in a parking lot. I think that the less I have to run the jacks down the better! Jim Riordan 88 WBWL XXV Stuart, Fl. Ryan Wright Thanks all for your responses. Dexron III it is. Seemed to work fine, jacks can extend fully now (it was a quart low). Funny, though, how heavy this bus is and how soft the soil at my house must be. I told it to level and watched all four jacks punch a 1 to 2 foot deep hole into the ground. Hah! I'm going to have to put some wood under the jacks next time, and/or just concrete the RV parking. :-) -Ryan '86 PT-40 8V92 Tri-Cities, WA On 6/7/07, Curt Sprenger > Ryan, > Dexron III will work. That is what I have used, no problems. Contact > HWH on the web or call them to validate. I believe they will agree with > III. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Ryan Wright wrote: > > > Can I just use regular old Dexron III in the leveling jacks? My HWH > > manual says "type A" or "type B" transmission fluid and I'm not > > familiar with that - neither are the people at the local auto store. I > > just need to top it off & it's clearly got some type of ATF in it now. > > > > Thank you! > > > > -Ryan > > '86 PT-40 8V92 > > Tri-Cities, WA > > > > > > > > > Yahoo! Groups Links > > > > --------------------------------- Luggage? GPS? Comic books? Check out fitting gifts for grads at Yahoo! Search. [Non-text portions of this message have been removed] |
06-08-2007, 03:29
Ryan: You got the same problem huh. I thought the gravel was packed down real
tight, even when I backed the bus over it, no tire marks, but put the jack down, hmmm hole in driveway LOL. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: Ryan Wright To: wanderlodge@yahoogroups.com; WanderlodgeForum@yahoogroups.com Sent: Friday, June 8, 2007 8:16:14 AM Subject: [WanderlodgeForum] Re: [wanderlodge] What type of ATF for HWH? Thanks all for your responses. Dexron III it is. Seemed to work fine, jacks can extend fully now (it was a quart low). Funny, though, how heavy this bus is and how soft the soil at my house must be. I told it to level and watched all four jacks punch a 1 to 2 foot deep hole into the ground. Hah! I'm going to have to put some wood under the jacks next time, and/or just concrete the RV parking. :-) -Ryan '86 PT-40 8V92 Tri-Cities, WA On 6/7/07, Curt Sprenger > Ryan, > Dexron III will work. That is what I have used, no problems. Contact > HWH on the web or call them to validate. I believe they will agree with > III. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Ryan Wright wrote: > > > Can I just use regular old Dexron III in the leveling jacks? My HWH > > manual says "type A" or "type B" transmission fluid and I'm not > > familiar with that - neither are the people at the local auto store. I > > just need to top it off & it's clearly got some type of ATF in it now. > > > > Thank you! > > > > -Ryan > > '86 PT-40 8V92 > > Tri-Cities, WA > > > > > > > > > Yahoo! Groups Links > > > > Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail at http://mrd.mail.yahoo.com/try_beta?.intl=ca [Non-text portions of this message have been removed] |
