Help! Perkins Generator Problem in Atlanta
06-14-2007, 09:41
Fellow Wanderlodgers,
My 83 FC-35 is on its first roadtrip as I write this. Left NJ on
Tuesday and made it to Atlanta with few mechanical problems.
Until last night. I was at a concert when the 3" dynamo pulley on my
Perkins 12.5 generator ceased up. I smelled the smoke, turned it off,
and watched the belt burn in half on the pulley.
Spent hours running around Atlanta today looking for a new pulley and
bearing. No luck. Nobody seems capable of finding the part number
from 1983. Or a similar pulley that might work.
Heading down to West Palm Beach, FL tonight. Its going to be very hot!
Might anybody know the part number for the small 3" pulley on the
Perkins that you adjust the tension with? If I had that number, I
might have much more success.
You should see how fried the old bearings were!
Any help is appreciated!
Andy
83 FC-35
Spring Lake Heights, NJ
06-14-2007, 10:14
Andy,
Copying my message on this forum as well, since you posted on both:
I'm all new here so I don't know exactly what pulley you're talking
about, but my guess is this is a simple idler pulley. Have you taken
the old one off and brought it to an auto parts store? It's doubtful
they will be able to look the part number up by vehicle or device, but
idler pulleys are idler pulleys and if you take it in there, they will
almost certainly have a replacement part available. It's a very common
part used on most engines.
Even if they don't have one available, you can press the old bearing
out and pop a new one in fairly easily and they will certainly stock
new bearings. A hammer, block of wood and a tool to remove the little
embedded "c" clamps might be enough to get the job done. (I used a
small vice to hold the pulley and hammered the bearing out when I
replaced them on my DeLorean). Or take it to any auto repair shop and
they should be able to swap the bearing out for you in a few minutes.
So, try taking the actual pulley with you, and use the term "idler
pulley", you should have much more success.
Good luck!
-Ryan
> Andy
> 83 FC-35
06-14-2007, 10:22
Kind of hard to believe a place the size of Atlanta doesn't have a
good bearing supply and repair house that could replace that bearing!
I know this was discussed in the past on the forum, but a I did a
quick search for you but I couldn't find the posts. I'll look in my
offline backup files when I get home. Seems like the bearing was
available at NAPA?
In any event, you might want to take a look in the Links section at
the Perkins Diesel Repair Manual link for some part numbers of the
dynamo on page B.13 for the part numbers on the dynamo which might
provide some clues to a parts counter guy. Section Q.5 covers the
operation, but I did not see any part numbers in there.
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Andy Coleman"
> Andy
> 83 FC-35
06-14-2007, 10:35
Andy,
I pressed out the old bearing and pressed a new one in. Here is the
bearing number for NSK brand: 6203ZZC3. Buy a spare.
I also have handy a Dayco belt number: 17415
David Hollis 84FRC35 Springfield,IL
my
off,
hot!
> Andy
> 83 FC-35
06-14-2007, 10:59
If you can read the bearing number I purchased mine at NAPA, knocked it out and
took a socket and put it back in. The pully itself should be ok. Then the belt
length and I would guess is a V type. Save the burned belt for reference.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Thursday, June 14, 2007 4:41 PM
Subject: [WanderlodgeForum] Help! Perkins Generator Problem in Atlanta
Andy
83 FC-35
06-14-2007, 14:35
Andy,
If you don't have any luck with NAPA, you may try a marine repair facility as
the Perkins is a popular marine engine and they might be able to get parts for
you...
HTH
Sea Ya
Larry
NYC
84 35FCSB
Sent: Thursday, June 14, 2007 6:22:59 PM
Subject: [WanderlodgeForum] Re: Help! Perkins Generator Problem in Atlanta
available at NAPA?
--- In WanderlodgeForum@ yahoogroups. com, "Andy Coleman"
> Andy
> 83 FC-35
#ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;}
#ygrp-mlmsg table {font-size:inherit;font:100%;}
#ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean,
sans-serif;}
#ygrp-mlmsg pre, code {font:115% monospace;}
#ygrp-mlmsg * {line-height:1.22em;}
#ygrp-text{
font-family:Georgia;
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
padding-top:10px;font-family:Verdana;font-size:77%;margin:0;}
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;}
#ygrp-actbar .left{
float:left;white-space:nowrap;}
.bld{font-weight:bold;}
#ygrp-grft{
font-family:Verdana;font-size:77%;padding:15px 0;}
#ygrp-ft{
font-family:verdana;font-size:77%;border-top:1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom:10px;}
#ygrp-vital{
background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;}
#ygrp-vital #vithd{
font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\
ercase;}
#ygrp-vital ul{
padding:0;margin:2px 0;}
#ygrp-vital ul li{
list-style-type:none;clear:both;border:1px solid #e0ecee;
#ygrp-vital ul li .ct{
font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\
ght:.5em;}
#ygrp-vital ul li .cat{
font-weight:bold;}
#ygrp-vital a {
text-decoration:none;}
#ygrp-vital a:hover{
text-decoration:underline;}
#ygrp-sponsor #hd{
color:#999;font-size:77%;}
#ygrp-sponsor #ov{
padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;}
#ygrp-sponsor #ov ul{
padding:0 0 0 8px;margin:0;}
#ygrp-sponsor #ov li{
list-style-type:square;padding:6px 0;font-size:77%;}
#ygrp-sponsor #ov li a{
text-decoration:none;font-size:130%;}
#ygrp-sponsor #nc {
background-color:#eee;margin-bottom:20px;padding:0 8px;}
#ygrp-sponsor .ad{
padding:8px 0;}
#ygrp-sponsor .ad #hd1{
font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\
#ygrp-sponsor .ad a{
#ygrp-sponsor .ad a:hover{
#ygrp-sponsor .ad p{
margin:0;}
o {font-size:0;}
.MsoNormal {
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
blockquote{margin:0 0 0 4px;}
.replbq {margin:4;}
____
Park yourself in front of a world of choices in alternative vehicles. Visit the
Yahoo! Auto Green Center.
http://autos.yahoo.com/green_center/
06-14-2007, 14:54
try this place all they do is bearings
Bearings limited
ATLANTA
5570 Tulane Drive
Atlanta, GA. 30336-2326
Phone: (888) 4-BEARINGS
(800) 247-9920
(404) 696-7065
Fax: (404) 696-7154
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, Larry wrote:
> Andy,
facility as the Perkins is a popular marine engine and they might be
able to get parts for you...
> HTH
> Sea Ya
> Larry
> NYC
> 84 35FCSB
> From: mbulriss <mbulriss@...>
Atlanta
doesn't have a
> available at NAPA?
> Mike Bulriss
> San Antonio, TX
hot!
> > Andy
> > 83 FC-35
sans-serif;}
clean, sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family:Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-vital{
> #ygrp-vital #vithd{
ercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
ght:.5em;}
> font-weight:bold;}
> #ygrp-vital a {
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc {
> #ygrp-sponsor .ad{
> padding:8px 0;}
> margin:0;}
> o {font-size:0;}
> .MsoNormal {
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120%;}
> .replbq {margin:4;}
____
vehicles. Visit the Yahoo! Auto Green Center.
06-16-2007, 00:41
I work in WPB, come see us if you can't get it sorted out or if you
need any additional service.
http://www.excelfleetservice.com/default.asp
http://deadsmall.com/1GH
Eric
> Andy
> 83 FC-35
> Yahoo! Groups Links
A child of five would understand this.
Send someone to fetch a child of five.
-Groucho Marx
