Generator Coolant
06-15-2007, 07:19
Generator Coolant
Robert- you may change out your thermostat and leave the radiator cap off-
till you see circulation.
83PT40
Livingston, Mt
06-15-2007, 09:33
Generator Coolant
Good deal- sometimes my old brain has a clear moment.
83PT40
Livingston, Mt
06-15-2007, 11:01
Generator Coolant
I changed coolant in my 8.0 Onan generator and now there seems to be
air traped in the system. Motor is getting hot but radiator is cold,
like the thermostst in not opening.
I'm not sure how to bleed the air out of the system, can anyone help me
out on this one?
__________________
Robert Britton
87FC
Hollister, California
06-15-2007, 12:58
Generator Coolant
Hey Robert,
I tried to squeeze the in and out hoses of the radiator, It lays
horizontal , and alternating the squeezing in and out (milking)
seemed to help.
Also pinch or block the return bypass to the reservoir. This should
force a little more coolant pressure thru the rad. The fan is on
highest speed and the radiator seems to run really cool.
But you should feel warm at the top and much cooler at the outlet of
the radiator .
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Robert Britton"
be
cold,
help me
> out on this one?
> __________________
> Robert Britton
> 87FC
06-15-2007, 13:10
Generator Coolant
Got it working!
Just by running the engine with the radiator cap off did the trick.
Thank you!
__________________
Robert Britton
87FC
cap off-
> Ernie Ekberg
> 83PT40
> Livingston, Mt
http://www.aol.com.
Loading...
