A/C Freon
05-06-2005, 02:29
A/C Freon
The '93 would originally have had R12.
- Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "Sid Clark" <sidclark99@y...> wrote: > Hi Dan, > Open your engine hatch and look at you AC compressor. If it has the > large charge/service fittings(about 1/2 inch diameter) with red and > blue dust caps, it is a R134A system and you can get a charge kit at > Walmart or any auto parts store and charge it yourself. It holds > around 6 pounds of refrigerant. My 91 had R134A from the factory or > else someone changed the compressor, so your 92 should be the same. > You should also add an oil charge to it. If it is R12 email me and > I'll give you advice on converting it. > Sid Clark in Dallas-91WBSA40 > > > - In WanderlodgeForum@yahoogroups.com, "Dan Saari" > wrote: > > Hi All.......Got home to not so sunny Wisconsin last Sunday and was > > greeted by a light snow shower about 5 miles from home....wonder > who > > was in charge of the welcome home commitee......... > > > > Made a final deal with the tire guy...He came right to the house to > > look at my tires for resale or capping and has agreed to give me > $550 > > for my tires so the set of 1 year old Michelin take offs will cost > me > > just under $3,000 ....He does,nt care for balancing powder , mostly > > on my drives cause of the slit shot pressure equlizers which he > > thinks could dammage them if the powder gets into them.....So we > will > > balance only the steers ( with stick-on weights) and if we detect > and > > imbalance in the drives or tag we will balance them later....... > > > > I had no front air conditioning on my way home (did,nt need it very > > long anyway)..I noticed a couple months ago that the air from the > > overhead front air was not as cold as it had been in the past ,, > but > > on the way it was gone completle, so I can only assume it needs to > be > > recharged...I had a trucker tell me to recharge it myself with the > > new stuff , 134 I think?,, anyway so I stopped at a walmart and the > > guy there said I needed to be sure all the old stuff was out cause > > they dont mix and I may need a new fitting kit,,so I left with > > nothing...When I got back to the parking lot I removed the front > > panel to look for the air conditioning unit, which for some reason > I > > thought I,d seen the compresser tank inside but no luck ,,not > > there...........SO now is when again I need HELP........Where on my > > 1992 is the front air unit located and what does it take to > recharge > > to the new stuff and can I do it myself????..........DAN SAARI > > > > > > 1992 WLWB 40ft. > > Depere Wi./ Summerfield Fl. |
