Cat 3208 Service Location
06-19-2007, 09:32
Hi All,
My 1988 35FC with a Cat 3208 has sprung a leak at the rear main seal. It is currently at Carter Catepiller in Fredericksburg, VA and they tell me that they are not equipped to handle this type of heavy duty work. Any suggestions between Richmond and DC would be most appreciative. It is leaking about 5 qts oil in 275 miles, needless to say my car and tow dolly are a mess. Reply via the group or to me directly at patches@... Thanks, Marc Glassmire King George, VA 1988 35FC |
06-19-2007, 10:12
No personal references, but if no one else has any, you can follow
this link to the Cat dealer site - click Servicing a 'truck engine', enter Virginia and hit 'Find'. http://www.cat.com/cda/framed/frameset?m...tId=145024 It will then list all their authorized dealers in the state that supposedly service truck engines. Although since Carter is listed, sounds like they just don't want to work on a "motor home". Better call ahead to verify if the others will. Good luck. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Marc & Tavie Glassmire" > > Hi All, > My 1988 35FC with a Cat 3208 has sprung a leak at the rear main > seal. It is currently at Carter Catepiller in Fredericksburg, VA and > they tell me that they are not equipped to handle this type of heavy > duty work. Any suggestions between Richmond and DC would be most > appreciative. It is leaking about 5 qts oil in 275 miles, needless to > say my car and tow dolly are a mess. Reply via the group or to me > directly at patches@... > Thanks, > Marc Glassmire > King George, VA > 1988 35FC > |
06-19-2007, 14:08
Ask the dealer to give you the caterpillar 800 number, call them and they will
find you a caterpillar dealer or TEPS dealer to work on your engine. re Brake > > From: "mbulriss" <mbulriss@...> > Date: 2007/06/19 Tue PM 06:12:25 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Cat 3208 Service Location > > No personal references, but if no one else has any, you can follow > this link to the Cat dealer site - click Servicing a 'truck engine', > enter Virginia and hit 'Find'. > > http://www.cat.com/cda/framed/frameset?m...tId=145024 > > It will then list all their authorized dealers in the state that > supposedly service truck engines. Although since Carter is listed, > sounds like they just don't want to work on a "motor home". Better > call ahead to verify if the others will. > > Good luck. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "Marc & Tavie Glassmire" > > > > > Hi All, > > My 1988 35FC with a Cat 3208 has sprung a leak at the rear main > > seal. It is currently at Carter Catepiller in Fredericksburg, VA and > > they tell me that they are not equipped to handle this type of heavy > > duty work. Any suggestions between Richmond and DC would be most > > appreciative. It is leaking about 5 qts oil in 275 miles, needless to > > say my car and tow dolly are a mess. Reply via the group or to me > > directly at patches@... > > Thanks, > > Marc Glassmire > > King George, VA > > 1988 35FC > > > > > > |
06-20-2007, 00:35
Check the breather tube and canister, there is a screen mesh and the
down tube almost touches the ground when dumped, Could be plugged with gunk.. Inside doghouse driver side valve cover. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Marc & Tavie Glassmire" > > Hi All, > My 1988 35FC with a Cat 3208 has sprung a leak at the rear main > seal. It is currently at Carter Catepiller in Fredericksburg, VA and > they tell me that they are not equipped to handle this type of heavy > duty work. Any suggestions between Richmond and DC would be most > appreciative. It is leaking about 5 qts oil in 275 miles, needless to > say my car and tow dolly are a mess. Reply via the group or to me > directly at patches@... > Thanks, > Marc Glassmire > King George, VA > 1988 35FC > |
