Generator Output Voltage
06-21-2007, 09:50
We were dry camping at the Formula I race at Indianopolis Speedway last
weekend when both the air conditioners quit. Quick investigation revealed that the generator was running but no output. I checked the breakers and the voltage to them was 84 volts on each leg. 120 would have been better. There are 1400 hours on the unit. Does anyone have an idea where to start to repair this fault? Any and all help appreciated. Bob Criss 1990 SP36 143000 miles |
06-21-2007, 10:13
--- In WanderlodgeForum@yahoogroups.com, "crissrace"
wrote: > > We were dry camping at the Formula I race at Indianopolis Speedway last > weekend when both the air conditioners quit. Quick investigation > revealed that the generator was running but no output. I checked the > breakers and the voltage to them was 84 volts on each leg. 120 would > have been better. There are 1400 hours on the unit. Does anyone have > an idea where to start to repair this fault? > Any and all help appreciated. > Bob Criss > 1990 SP36 > 143000 miles > Bob, I had a similar thing happen to my SP generator several years ago. It turned out to be a bad rectifier diode. One phase was bad which gave the low voltage. It was relatively inexpensive (less than $50) and not hard to replace (once you get the generator out of the bird). The info on how to troubleshoot is listed in the Onan manual and I was able to find them on the internet. Good luck. Jim Brookshire 1989 SP-36 |
06-21-2007, 10:13
06-21-2007, 10:48
When was the last time you checked your voltage? That's a pretty
significant voltage drop, but if for some reason your rpms have dropped on your genset, that will drop the voltage too. See if the set screws are tight. How many hertz do you have. It should be real close to 60. If your hertz are low, you should be able to up the rpms a little bit and see if get some more voltage. My Perkins was running around 98-100 volts when i bought it. After having it checked with a mechanics at Parker Controls, he just had to adjust my rpms slightly. ...But you also need to keep your hertz at around 60. If you are getting 80 volts, but 60 hertz right now, then you definitely have another problem. i was at the Formula One race last weekend too. but i wasn't in my bird. it would have been fun to see another bird. a friend of mine works for renault on the red bull team and i got to see the race from the paddock. that was fun, especially as i had never been to the brickyard or even a race before. Alan 87fc35 --- In WanderlodgeForum@yahoogroups.com, "agitator19" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "crissrace" > wrote: > > > > We were dry camping at the Formula I race at Indianopolis Speedway > last > > weekend when both the air conditioners quit. Quick investigation > > revealed that the generator was running but no output. I checked the > > breakers and the voltage to them was 84 volts on each leg. 120 would > > have been better. There are 1400 hours on the unit. Does anyone > have > > an idea where to start to repair this fault? > > Any and all help appreciated. > > Bob Criss > > 1990 SP36 > > 143000 miles > > > Bob, > > I had a similar thing happen to my SP generator several years ago. It > turned out to be a bad rectifier diode. One phase was bad which gave > the low voltage. It was relatively inexpensive (less than $50) and not > hard to replace (once you get the generator out of the bird). The info > on how to troubleshoot is listed in the Onan manual and I was able to > find them on the internet. Good luck. > > Jim Brookshire > 1989 SP-36 > |
