Generator vibration
06-23-2007, 05:05
Generator vibration
My generator transfers considerable vibration to the interior. What's
the word on replacing mounts? Where are they available? Are there any
other "tricks"?
Scott Forman
86 PT38
Memphis
06-23-2007, 07:52
Generator vibration
Scott,
Our 88 FC has the 8.0K, 3 cylinder Kubota, located in the rear
driver side bay behind the dual tires. I removed the gennie to
service, re-insulate, adjust valves, t-stat. etc. and cleanup this
area. The motor mounts were flat as a pancake, so I replaced them
with three from Onan, They were labeled , vibration dampeners.
The replacements were more robust with more rubber. If I were to do
this again I would go to NAPA and try to match the part, Onan charges
to paint them green.................
I do not know if this really helped with noise or vibration, But ,
replacing the flat, hard mounts made me feel better.
Bill 88 FC Michigan
What's
any
> other "tricks"?
> Scott Forman
> 86 PT38
> Memphis
06-23-2007, 10:02
Generator vibration
isolation mounts for the lord corporation
Stephen 77fc35
> other "tricks"?
> Scott Forman
> 86 PT38
> Memphis
06-23-2007, 10:18
Generator vibration
I replaced my mounts with small firestone air bags. They work great, but
the best way to install them is with a regulated, check valve air supply to
keep them at the same pressure all the time.
Jim Hutchings
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Stephen Birtles
Sent: Saturday, June 23, 2007 3:02 PM
Subject: [WanderlodgeForum] Re: Generator vibration
Stephen 77fc35
> other "tricks"?
> Scott Forman
> 86 PT38
> Memphis
06-23-2007, 10:21
Generator vibration
> isolation mounts "from" the lord corporation
> Stephen 77fc35
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
What's
there any
> > other "tricks"?
> > Scott Forman
> > 86 PT38
> > Memphis
06-23-2007, 10:35
Generator vibration
Do you have a part number or anything?
> Stephen 77fc35
What's
there any
> > other "tricks"?
> > Scott Forman
> > 86 PT38
> > Memphis
06-23-2007, 13:50
Generator vibration
Not really just figure out how much your generator weighs and size and
type accordingly
Stephen 77fc35
> > Stephen 77fc35
> What's
> there any
> > > other "tricks"?
> > > Scott Forman
> > > 86 PT38
> > > Memphis
10-04-2008, 12:11
Generator vibration
Does anyone have any good tricks for reducing vibration from the
Yanmar/Kohler generator?
Scott Forman
86 PT38
Memphis
10-04-2008, 13:20
Generator vibration
Hello Scott,
This is a project that is nearing the top of my list. I also have the Yanmar
Kohler set up.
in our 83 FC. I recently completed re-insulating my engine compartment and
installing a
new salon floor. I used products from Soundown a company that specialized in
quieting
down expensive yachts. The have a wide range of products for insulation and
vibration damping. http://www.soundown.com/VD.htm
I am very satisfied with the results attained for the engine and floor. I have
discussed the
generator issue with one of the Soundown reps and he suggested stripping
existing
insulation and applying a peal and stick vibration damping sheet and over that a
2" 2
lb/sf ft insulation. I used 2" fiberglass 2 lb/sf with a lead shield for the
engine
compartment but in the generator compartment I will go with 2' 2lb/sf composite
with
decoupler.
On the sub floor in the salon I used a heavy rubber and foam its also 2 lb/sf
with the
foam side down. This is a great base. Over that I used Dupont engineered
flooring
(Hickory). Looks great and its easy to install. Its a click together product (30
year
warranty) and can be changed out without a big hassle. I would have extended
this sub-
floor through the mid coach and kitchen but, I have a nice tile floor and did
not want to
go over it or tear it out. Thats why my generator sound control will have to be
dealt with
exclusively from below.
I realoze the PH has a whole different set up but I think the principles of
damping
vibration will be similar.
Thanks - NH Bill 1983 FC 35 SB
10-04-2008, 13:44
Generator vibration
I have done extensive insulating also, with good results. Vibration
is a different animal though, especially that which is transmitted
through the steering column when driving.
Scott
--- In WanderlodgeForum@yahoogroups.com, "Bill Garamella"
<bgaramella@...> wrote:
> Hello Scott,
the Yanmar Kohler set up.
compartment and installing a
specialized in quieting
insulation and vibration damping. http://www.soundown.com/VD.htm
floor. I have discussed the
stripping existing
and over that a 2" 2
shield for the engine
2lb/sf composite with
> decoupler.
also 2 lb/sf with the
engineered flooring
together product (30 year
extended this sub-
floor and did not want to
will have to be dealt with
principles of damping
