Mountain Driving with 1995 42', 42,000 lb. Blue Bird
06-26-2007, 08:09
Post: #41
No hurry Ron,
It will take two to three years working part time at this hobby,
then a few issues will surface , Start a priority list.
Our Bird always get us home safe.
Bill 88 FC michigan
--- In WanderlodgeForum@yahoogroups.com, Ron Thompson
> Lets see now, windows sticking and not unlatching or latching
properly, # umpteenth priority project. Whew this fun RV'ing is
about to kill me...LOL
> Ron Thompson
> Waller, Texas
> 1995 42' BB
> Pete Masterson
wrote: No... it's not normal.
Probably a function of the coach sitting a
> long time. On my coach, the windows up front open very easily --
too
> easily, in fact. The weather stripping has flattened and I need
to
> renew it to stop some rattling while underway.
> The bedroom window, however is somewhat of a pain. It's quite
sticky.
> My latch doesn't quite latch. So, my plan is to thoroughly clean
> tracks and apply some graphite. (WD-40 is a solvent. It leaves a
> slight residue that attracts dirt, so it's not a good choice for
a
> window.) I'll also add some washers under the latch part in the
> window frame so the locking part will connect (if the cleaning
> graphite doesn't do the trick).
> Pete Masterson
> aeonix1@...
> '95 Blue Bird Wanderlodge WBDA 42'
> El Sobrante, CA
> On Jun 26, 2007, at 5:01 AM, Ron Thompson wrote:
> > <snip> I tried the windows in the bedroom and you would have
to
> > have a pry bar to get them open. I don't think they have ever
been
> > open so they are stiff as hell. Going to have to lube them to
get
> > them moving again. A little WD-40 will do wonders. I notice
too
> > that the window latches are very difficult to release. One of
> > windows I had to go get a screw driver to get the latch to
> > release. All of the windows are stiff like that. Is that a
usual
> > thing on these Blue Birds?
06-26-2007, 09:09
Post: #42
Heh, Heh Heh, got one going already.
Regards,
Ron Thompson
Waller, Tx.
1995 42' BB
pattypape wrote:
No hurry Ron,
Bill 88 FC michigan
> Ron Thompson
> Waller, Texas
> 1995 42' BB
> Pete Masterson
too
to
sticky.
a
> Pete Masterson
> aeonix1@...
> El Sobrante, CA
to
been
get
too
usual
06-26-2007, 09:45
Post: #43
Ron one of the things Greg said really rings true.........'don't worry about
the impatient four wheelers' ....stay on a steady course, let them buzz
around you and if they don't like your speed tough. You'll find the four
wheelers don't like being behind you either and will do some pretty crazy
things to avoid it. You are expected to do whatever is reasonable to avoid
contact but at some cases your signal lights become a warning and not a
request. Drive with your eyes way way way down the road. Further than you
normally do in a car.
> Regards,
> Ron Thompson
> Waller, Tx.
> 1995 42' BB
> pattypape > wrote:
> No hurry Ron,
> Bill 88 FC michigan
> Ron Thompson
> > Ron Thompson
> > Waller, Texas
> > 1995 42' BB
> > Pete Masterson
> too
> to
> sticky.
> the
> a
> and
> > Pete Masterson
> > aeonix1@...
> > El Sobrante, CA
> to
> been
> get
> too
> the
> usual
Rob, Sue & Merlin Robinson
94 WLWB
06-26-2007, 10:56
Post: #44
Rob,
Heck, I already do that in my Pick'em UP Truck. Heh heh.
Thanks for the hint.
Ron Thompson
Waller, Tx.
1995 42' BB
Rob Robinson wrote: Ron
> Regards,
> Ron Thompson
> Waller, Tx.
> 1995 42' BB
> pattypape > wrote:
> No hurry Ron,
> Bill 88 FC michigan
> Ron Thompson
> > Ron Thompson
> > Waller, Texas
> > 1995 42' BB
> > Pete Masterson
> too
> to
> sticky.
> the
> a
> and
> > Pete Masterson
> > aeonix1@...
> > El Sobrante, CA
> to
> been
> get
> too
> the
> usual
94 WLWB
06-26-2007, 12:08
Post: #45
Leroy,
I used B'Blaster's "TDL" (The Dry Lube) on the window slides and it works very
good. It dries so isn't messy. Bought it at Lowe's.
Sent: Tuesday, June 26, 2007 6:02 AM
Subject: Re: [WanderlodgeForum] Re: Mountain Driving with 1995 42', 42,000 lb.
Blue Bird
Stephen:
Will try the wax idea.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville,FL
Sent: Tuesday, June 26, 2007 7:54 AM
Subject: [WanderlodgeForum] Re: Mountain Driving with 1995 42', 42,000 lb.
Blue Bird
Lube tracks with paraffin wax a small amount goes a long way
If you really worried about escaping from the bedroom through the window
a spring loaded center punch will make the window disappear with one shot
it is tempered non-laminated glass and will crumble
One good piece of equipment on any emergency truck or vehicle usually
located in rescue worker's pocket for fast access along with seat belt
cutter
Stephen 77fc35
--- In
"Leroy Eckert"
> My windows in the bedroom are the same way. I have lubed the track
with limited success. I keep a small sledge hammer in the bedroom jic.
> I posted back in April a potential major source for fire. I have
removed the source from my bus. The freeze heaters on my coach burned
a hole in the water pipe under the night stand while in the infield at
Talladega. The event did not trip the circuit breaker. Flooded the bus
also. I am glad the water was in the line and the pump was on! Or???
The reason for the failure was two of the wires were touching when
they failed. That is not allowed per specifications. I still do not
know why they operated at 85 degrees. In any event, they are gone
now. With hydronic heat, there is no real reason to have them.
> It is not easy to do and inspection of these wires as they are
encased in insulation covering the water pipes. However, if two of
these wires are crossed or get together from movement over the years
the result is inevitable.
> Kinda off the original subject but very important.
> Leroy Eckert
> Niceville, FL
> From: Ron Thompson
> To:
> Sent: Tuesday, June 26, 2007 7:01 AM
> Subject: RE: [WanderlodgeForum] Re: Mountain Driving with 1995
> Brad,
> Man am I glad you jogged my memory about that bus fire during the
Houston evac. I remember seeing that thing burn too. What a tradgedy.
> Yes, you are right about a fire on a coach being a serious matter.
I was just thinking about what I would do if I was in the bedroom and
a fire broke out in the galley. There is no door to get out. I tried
the windows in the bedroom and you would have to have a pry bar to get
them open. I don't think they have ever been open so they are stiff as
hell. Going to have to lube them to get them moving again. A little
WD-40 will do wonders. I notice too that the window latches are very
difficult to release. One of the windows I had to go get a screw
driver to get the latch to release. All of the windows are stiff like
that. Is that a usual thing on these Blue Birds?
> Thanks again Brad.
> My best regards,
> Ron Thompson
> Waller, Texas
> 1995 Wide Body 42" BB
> Detroit Diesel Series 60 470 HP
> Kubota, 4 cylinder, 1681 cc.
> Phone 936-931-2802 land line
> cell..713-295-0119 Cingular
> brad barton <bbartonwx@...> wrote:
> Ron,
> One more ramble and I'll quit.
> Marty is right about heat. A dragging brake on a tour bus
evacuating nursing home patients from Hurricane Rita in Houston, blew
out one time on I-45. The driver didn't understand English, so he
continued on after the tire was changed. The brake heated up again
even in stop and go traffic. The wheel became red hot and caught the
rear of the bus on fire. The driver failed to notice until portable
oxygen tanks used by the patients began exploding. The bus turned into
a crematorium for 24 of those patients. I'll never forget watching the
bus burning up live on TV. Also, I left my magnetic retarder on by
mistake in Flagstaff and nearly caught my 84 Bird on fire. I burned
through the air line that operated the driver's seat slide. Imagine
smoke coming from under your coach and you're struggling to get to the
extinguisher with your seat next to the doghouse. Fire on a motorcoach
is almost as serious as fire on board an airplane. Brad Barton 00LXiDFW
> bbartonwx@...
> To: WanderlodgeForum@...: martingregg598@...: Tue, 26 Jun 2007
00:32:18 +0000Subject: [WanderlodgeForum] Re: Mountain Driving with
> Ron, if you have a Allison HT-755 five speed with a retarder, I
have know advice, if you have a 1995-42' you should have a Allison
HD-4060 and a DD series 60 with a 3 position Jacobs engine brake.
Jacobs's brakes close the valves and turn the cylinder into a
compressor creating braking horsepower, each position adds more
cylinders. I haven't driven a 95 in the mountains but I have driven
over a lot of the passes in the Cascades, Montana, Idaho and so on,
but I can't imagine that if your in the right gear at the right RPM
that the engine brake won't hold it back. For me with a less effective
Pac Brake, it is 4th gear at 50 mph at about 2400 rpm's on a 6% or so,
on a steeper grade it's 3 gear at 35-40 mph and I almost never have to
use my air brakes. If I am in 4th and it starts to run away, faster
that I like, I use the brakes to get the coach down to the speed that
I can select the next lower gear. If the Jacobs brake doesn't hold you
back, maybe there is something wrong
> with the Jacobs brake? As for the "Drum type" air brakes, if you
have been on the road for a time and the ambient temp. is hot, and If
you ride the brakes for a long period of time the drum can expand away
from the shoe and you lose your brakes. With some real bad luck you
could heat the wheel up so hot that it heats the tire up and
blowout.Marty95 BMC 37Kennewick Wa
> __________________________________________________________
> Play free games, earn tickets, get cool prizes! Join Live Search
Club.
http://club.live.com/home.aspx?icid=CLUB_wlmailtextlink<http://club.live.com/hom\
e.aspx?icid=CLUB_wlmailtextlink>
