Engine Alternator overcharging
07-15-2007, 08:55
I am having a problem with my Leece-Neville alternator overcharging. I
had it rebuilt as preventive maint.,it woked ok for about 800-1000
miles then it started over charging 15-15.5 volts & 80-100amps. I took
it back to the rebuilder and they said the regulator was bad so they
replaced it. They told me to check the voltage to the small + post
under the regulator. I was getting about .75 of a volt less than
battery voltage as measured at the big + post. I could not find where
the volt drop was so I ran a new wire from the ignition operated
solinoid above the throttle pedal. The alternator is still
overcharging. We are supposed to leave on Friday for a 4000 mile trip
so this is a big problem. Did Bluebird use a special regulator since
they have Batt. power to the alternator all of the time? The rebuilder
may have installed the wrong regulator. Thanks Jim Matus 84FC35 Rescue
CA
07-15-2007, 09:36
Jim,
What is the voltage from the alternator frame to the + post on the
alternator?
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of jim matus
Sent: Sunday, July 15, 2007 3:55 PM
Subject: [WanderlodgeForum] Engine Alternator overcharging
CA
07-15-2007, 10:38
Try jumping the alternator's sense wire to the battery positive terminal.
Your sense wire might be disconnected or degraded resulting in high
resistance.
David Brady
'02 LXi, Smokey
NC
> CA
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.476 / Virus Database: 269.10.6/900 - Release Date: 7/14/2007 3:36
PM
07-15-2007, 13:52
I did that and it charged ok but after I hooked it up with the sense
wire it started overcharging and now it overcharges no matter how you
connect it so I guess the regulator blew again. Jim Matus 84FC35
Rescue CA --
terminal.
> resistance.
> David Brady
> '02 LXi, Smokey
> NC
overcharging. I
took
they
where
trip
since
rebuilder
Rescue
> > CA
7/14/2007 3:36 PM
07-15-2007, 17:32
Chuck: The voltage is 12.32 volts same as battery voltage. Jim Matus
84FC35 Rescue CA -
-- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler"
> Jim,
> alternator?
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
overcharging. I
took
they
where
trip
since
rebuilder
Rescue
> CA
07-16-2007, 00:29
Have you checked all grounds on the coach (battery, frame, etc?)
Insecure grounds can do strange things to apparently unrelated
components.
Dan
94 BMC 37'
--- In WanderlodgeForum@yahoogroups.com, "jim matus"
sense
you
> Rescue
CA --
> terminal.
high
> > resistance.
> > David Brady
> > '02 LXi, Smokey
> > NC
> overcharging. I
1000
I
> took
> they
post
> where
mile
> trip
> since
> rebuilder
> Rescue
> > > CA
> 7/14/2007 3:36 PM
07-16-2007, 01:25
Then I confused! Where is the 15+ volts? Sounds like it's dead, not
overcharging.
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
Sent: Monday, July 16, 2007 12:33 AM
Subject: [WanderlodgeForum] Re: Engine Alternator overcharging
84FC35 Rescue CA -
> Jim,
> alternator?
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
yahoogroups.com
yahoogroups.com
overcharging. I
took
they
where
trip
since
rebuilder
Rescue
> CA
07-16-2007, 01:33
Sorry for this Jim, but I gotta ask, was the engine running when
you read the 12.32V?
David Brady
'02 LXi, Smokey
NC
> 84FC35 Rescue CA -
> , "Chuck Wheeler"
> > Jim,
> > alternator?
> > - Chuck Wheeler -
> > 82 FC 31 SB
> > Fort Worth, TX
> > _____
> overcharging. I
> took
> they
> where
> trip
> since
> rebuilder
> Rescue
> > CA
PM
07-16-2007, 17:25
The reading I gave you was with the engine shut off. + post to
alternator frame I thought that is what you wre asking . With the
engine running I was getting 15+ volts on the dash volt meter and the
alternator was getting very warm. Jim Matus 84FC35 Rescue CA -
not
> overcharging.
> - Chuck Wheeler -
> 82 FC 31 SB
> Fort Worth, TX
> _____
Matus
> 84FC35 Rescue CA -
> > Jim,
> > alternator?
> > - Chuck Wheeler -
> > 82 FC 31 SB
> > Fort Worth, TX
> > _____
> > From: WanderlodgeForum@ 40yahoogroups.com>
> yahoogroups.com
> > [mailto:WanderlodgeForum@ 40yahoogroups.com>
> yahoogroups.com
> overcharging. I
1000
> took
> they
post
> where
> trip
> since
> rebuilder
> Rescue
> > CA
07-16-2007, 17:36
No the way the question was asked I thought he was asking about the
voltage thru the frame to ground with the engine off. Running @ 1500+
rpms it is 15+ volts. I called Leece-Neville this morning and they
told me to try Norm's Electric in Sacramento I took it to them and
the first thing they saw was that the previous shop had used a no
name regulator. I suspect they used substandered off-shore parts in
it. I should know tomorrow what all they found.Jim Matus 84FC35
Rescue CA -
-- In WanderlodgeForum@yahoogroups.com, David Brady
> David Brady
> '02 LXi, Smokey
> NC
Matus
> > 84FC35 Rescue CA -
> > , "Chuck Wheeler"
> > wrote:
> > > Jim,
> > > alternator?
> > > - Chuck Wheeler -
> > > 82 FC 31 SB
> > > Fort Worth, TX
> > > _____
> > ] On Behalf Of jim
matus
> > overcharging. I
1000
I
> > took
> > they
post
> > where
> > trip
> > since
> > rebuilder
> > Rescue
> > > CA
7/14/2007 3:36 PM
