Painting project
07-16-2007, 15:06
Post: #21
Painting project
Yeah, I understand the trip is priority. So who cares if the bus is under
restoration and only half painted. So it takes 6 months.You can only see one
side at a time. And folks will applaud your tenacity. I think that's ok.
If not, we are hanging with the wrong crowd. Don't stop now, your will have
wasted the prior time.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Royale Conversion
Sent: Monday, July 16, 2007 9:43 PM
Subject: [WanderlodgeForum] Re: Painting project
Leroy,
If I have a choice of taking a trip or working on the Bird, the
trip wins. What I dream of is a restoration campground. One that
caters to folks restoring coaches of any make. It would be great if
such a place existed. Imagine having a group of experienced RV
technicians, mechanics, interior specialists, and other kinds of
services in a concentraited area. Pull in, set up, and get out the
Mastercard.
Gardner
78FC33
> I know what you mean. I spent 5 years of Sundays restoring an
airplane. It is gratifying. However you can go anywhere in your
coach with it half painted and that is perfectly ok. Enjoy it while
you work on it. It took me five years to fly it then I sold it to my
partner. lol
> Leroy Eckert
> 1990 WB-Smoke N Mirrors"
> Niceville, FL
> Royale Conversion
> From: Gardner Yeaw
> Sent: Monday, July 16, 2007 9:08 PM
> Leroy,
> I know you are right about one section at a time. My problem is
> that I still have a job. I can only get to work on the Bird one
day
> per good weather weekend. There just ain't enough time to keep
it
> running well, washed, waxed, etc. and think about painting.
> Gardner
> 78FC33
> > You can do it one section at a time if your plan properly. Use
> seams in the metal taped off properly and over a period of time
not
> one single person will ever know unless you tell them.
> > Leroy Eckert
> > Niceville, FL
> > Royale Conversion
> > From: Gardner Yeaw
> > Sent: Monday, July 16, 2007 7:50 PM
> > Leroy,
> > Thanks. My paint is pealing in places right down to the
> galvanized
> > surface. It would seem that I really should get down to that
> > start fresh when/if I actually do start painting. I may do the
> Front
> > and rear, then think about the sides and roof. In the North
East
> the
> > weather just isn't stable enough for planning a big paint job.
> > Gardner
> > 78FC33
> > wrote:
> > > I know your post was for Don. Scuff it with ScotchBright and
> > follow with PrepSol. And be certain you do not use a can of
> silicone
> > lubricant anywhere nearby. Fisheyes will be the result. Just
do
> not
> > have that stuff in the shop.
> > > Leroy Eckert
> > > 1990 WB-40"Smoke N Mirrors'
> > > Niceville, FL
> > > From: Gardner Yeaw
> > > Sent: Monday, July 16, 2007 6:40 PM
> > > What did you do to prep the galvanized surface to insure the
> > primer
> > > got a good hold?
> > > Gardner
> > > 78fc33
> > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner"
> > > wrote:
> > > > Nason calls for 2 coats with metallic, but I find that it
is
> > color-
> > > specific dependent on the amount of pigment in the paint.
The
> > gold
> > > has to go on very thin or it will run - less solids, so it
> takes
> > 5
> > > coats. The red takes 2, and the blue and silver take 3.
Nason
> > could
> > > probably be considered "econo Imron" and it is not easy to
> tell
> > how
> > > they differ, since Imron has a couple of non-clearcoat
> products
> > > (3500 and 400) as well.
> > > > On 7/16/2007 at 5:43 PM Leroy Eckert wrote:
> > > > >I have not used that product. I would expect that you
could
> > thin
> > > the
> > > > >final coat (I use three coats with Impron)with a little
> more
> > > reducer to
> > > > >create a wet coat to get the paint to lay out if you are
> not
> > > satisfied.
> > > > >Just do not get in a hurry.That is what I did with Imron
on
> > my
> > > airplane.
> > > > >To aid in prep work, the most important part of a paint
> job,
> > I
> > > use a hand
> > > > >held sand blaster I purchased from the paint store.
> Blasting
> > sand
> > > from Ace
> > > > >Hardware can speed up the prep process over rivets and
> tight
> > > spots. You
> > > > >gotta shower when finished. The rain drop spots may be
able
> > to be
> > > removed
> > > > >by wet sanding and buffing with compound.
> > > > >Looks really good. Great job.
> > > > >Leroy Eckert
> > > > >Niceville, FL
> > > [Non-text portions of this message have been removed]
07-16-2007, 15:11
Post: #22
Painting project
Rob,
What is in Elkhart Indiana?
Gardner
78FC33
- In WanderlodgeForum@yahoogroups.com, "Rob Robinson"
> I think you just described Elkhart Indiana
> On 16/07/07, Gardner Yeaw wrote:
> > Leroy,
if
> > Mastercard.
> > Gardner
> > 78FC33
> > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "Leroy Eckert"
while
to my
> > partner. lol
> > > Leroy Eckert
> > > Niceville, FL
> > > Royale Conversion
> > > From: Gardner Yeaw
> > > To: WanderlodgeForum@yahoogroups.com 40yahoogroups.com>
> > > Leroy,
> > day
> > it
> > > Gardner
> > > 78FC33
> > "Leroy Eckert"
Use
> > not
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > Royale Conversion
> > > > From: Gardner Yeaw
> > > > Leroy,
> > > galvanized
> > and
> > > Front
> > East
> > > the
job.
> > > > Gardner
> > > > 78FC33
> > "Leroy Eckert"
> > > silicone
> > do
> > > not
> > > > > Leroy Eckert
> > > > > Niceville, FL
> > > > > From: Gardner Yeaw
> > > > primer
> > > > > got a good hold?
> > > > > Gardner
> > > > > 78fc33
> > "Don Bradner"
> > is
> > > > color-
> > The
> > > > gold
> > > takes
> > > > 5
> > Nason
> > > > could
> > > tell
> > > > how
> > > products
> > could
> > > > thin
> > > > > the
> > > more
> > > > > reducer to
> > > not
> > > > > satisfied.
> > on
> > > > my
> > > > > airplane.
> > > job,
> > > > I
> > > > > use a hand
> > > Blasting
> > > > sand
> > > > > from Ace
> > > tight
> > > > > spots. You
> > able
> > > > to be
> > > > > removed
> > > > > > >Leroy Eckert
> > > > > > >Niceville, FL
> Rob, Sue & Merlin Robinson
> 94 WLWB
07-16-2007, 15:19
Post: #23
Painting project
Hi Gardner. I was in Elkhart to have Mor Ryde put on an SOB back in 2001. I
never saw so many RV related business located in one place in my life. All
the parts manufacturers, assembly lines, conversion builders and even RV
Junkyards. You could spend a week in just the junkyards alone.
> Rob,
> Gardner
> 78FC33
> - In WanderlodgeForum@yahoogroups.com ,
> "Rob Robinson"
> > > Leroy,
> if
> the
> > > Mastercard.
> > > Gardner
> > > 78FC33
> > > --- In
> > 40yahoogroups.com>,
> > > "Leroy Eckert"
> while
> to my
> > > partner. lol
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > Royale Conversion
> > > > From: Gardner Yeaw
> > 40yahoogroups.com>
> > > > Leroy,
> > > day
> > > it
> > > > Gardner
> > > > 78FC33
> > > > --- In
> > 40yahoogroups.com>,
> > > "Leroy Eckert"
> Use
> > > not
> > > > > Leroy Eckert
> > > > > Niceville, FL
> > > > > Royale Conversion
> > > > > From: Gardner Yeaw
> > > > > To:
> > 40yahoogroups.com>
> > > > > Leroy,
> > > > galvanized
> > > and
> the
> > > > Front
> > > East
> > > > the
> job.
> > > > > Gardner
> > > > > 78FC33
> > > > > --- In
> > 40yahoogroups.com>,
> > > "Leroy Eckert"
> and
> > > > silicone
> > > do
> > > > not
> > > > > > Leroy Eckert
> > > > > > Niceville, FL
> > > > > > From: Gardner Yeaw
> > > > > > To:
> > 40yahoogroups.com>
> the
> > > > > primer
> > > > > > got a good hold?
> > > > > > Gardner
> > > > > > 78fc33
> > > > > > --- In
> > 40yahoogroups.com>,
> > > "Don Bradner"
> > > is
> > > > > color-
> > > The
> > > > > gold
> > > > takes
> > > > > 5
> > > Nason
> > > > > could
> > > > tell
> > > > > how
> > > > products
> > > could
> > > > > thin
> > > > > > the
> > > > more
> > > > > > reducer to
> > > > not
> > > > > > satisfied.
> > > on
> > > > > my
> > > > > > airplane.
> > > > job,
> > > > > I
> > > > > > use a hand
> > > > Blasting
> > > > > sand
> > > > > > from Ace
> > > > tight
> > > > > > spots. You
> > > able
> > > > > to be
> > > > > > removed
> > > > > > > >Leroy Eckert
> > > > > > > >Niceville, FL
> > 94 WLWB
94 WLWB
