Mysterious Items in Bedroom Cabinet!!! 1993 Wanderlodge, WLWB
09-24-2007, 08:14
Howdy, Wanderlodge Forum family.
We have some mysterious items in one of our bedroom closets; a circuit breaker box and a rheostat. Jack has no idea of their purpose. He thought that the rheostat might be part of the hydronic heating system, controlling a blower fan on a heat exchanger under the bedbox. We lifted up the air mattress( what a job that was) so Jack could check the exchanger. No fan there nor any wires that might be for a blower fan. Back to square one. Jack has no idea what that breaker box controls and no, he hasn't turned those breakers off to find out. Please look in the Photo section of this Forum at the album entitled, "Mysterious Items in Bedroom Cabinet". There are photos of the cabinet and those mysterious items. Answers, ideas or SWAGs to our mystery will be welcomed. Thanks, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Currently in Buena Vista, CO where there is snow on the mountain peaks! |
09-24-2007, 08:30
Don't have a clue about the rheostat.
Breakers -- the photo doesn't show the amp rating. If 50 amps each, these could be "mains" for the house 120 vac system. (Try turning them off and see what happens. I'd do this at home or at a non- critical time "just in case.") I have a similar pair of breakers that control my dual inverters... they're located on the back wall of the bedroom down near the floor, but my coach layout is quite different due to having the Series 60 DD engine. So, these may be related to the inverter power. I note that my coach (apparently) is wired with a separate distribution system for inverted power -- it does not pass through the main panel. (I discovered this when I 'killed' the power to the refrigerator through the main panel, then saw the interior light working when the inverters were running.) It seems that the inverted power goes through the pair of breakers that are separate from the main panel. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Sep 24, 2007, at 1:14 PM, Jack and Liz Pearce wrote: > Howdy, Wanderlodge Forum family. > > We have some mysterious items in one of our bedroom closets; a circuit > breaker box and a rheostat. Jack has no idea of their purpose. He > thought that the rheostat might be part of the hydronic heating > system, > controlling a blower fan on a heat exchanger under the bedbox. We > lifted > up the air mattress( what a job that was) so Jack could check the > exchanger. No fan there nor any wires that might be for a blower fan. > Back to square one. > > Jack has no idea what that breaker box controls and no, he hasn't > turned > those breakers off to find out. > > Please look in the Photo section of this Forum at the album entitled, > "Mysterious Items in Bedroom Cabinet". There are photos of the cabinet > and those mysterious items. Answers, ideas or SWAGs to our mystery > will > be welcomed. > > Thanks, > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Currently in Buena Vista, CO where there is snow on the mountain > peaks! > > > > > > > > > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] |
09-24-2007, 08:37
I don't have the foggiest idea about the rheostat or circuit breaker
but I have to tell you that the title of your post got my attention was thinking "kinkie" I guess. And then again you never know it could be!! I myself would experiment a smidge and see what happens. You know the circuit breaker has to turn something on or off and its in the bedroom cabinet. If this is not standard BB stuff then you either trace the wires to there source or you experiment with the switches and see what happens. See, my personality is such that I couldn't wait to find out. I'd be flippin switches and turnin dials 'til I found out what gives. That's me. John Heckman central Pa 1973 FC > > Howdy, Wanderlodge Forum family. > > We have some mysterious items in one of our bedroom closets; a circuit > breaker box and a rheostat. Jack has no idea of their purpose. He > thought that the rheostat might be part of the hydronic heating system, > controlling a blower fan on a heat exchanger under the bedbox. We lifted > up the air mattress( what a job that was) so Jack could check the > exchanger. No fan there nor any wires that might be for a blower fan. > Back to square one. > > Jack has no idea what that breaker box controls and no, he hasn't turned > those breakers off to find out. > > Please look in the Photo section of this Forum at the album entitled, > "Mysterious Items in Bedroom Cabinet". There are photos of the cabinet > and those mysterious items. Answers, ideas or SWAGs to our mystery will > be welcomed. > > Thanks, > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Currently in Buena Vista, CO where there is snow on the mountain peaks! > |
09-24-2007, 09:11
Well, the ole Bird is at it again. My coach has a Hydronic system with two sets
of convection fans. One set under the couch and the other under the bath vanity. They both were designed with a sensor about the size of a quarter with a pin in the center strapped to a rubber hose that causes the rheostat to operate when the system is up to temperature. If the sensor fails, the fans do not work. My couch fans work when the system is activated. The bath fans work when the system is up to temp. When the bath sensor fails, I will bypass it and send the power direct to the rheostat since the temperature rises rapidly. Something less to fail in the future. If that rheostat does not dim lights it must be associated with the heating system. On the high voltage panel I would turn off one at a time and start looking, first at the overhead leg gauges. If nothing there, I would start turning things on and see what does not work. Where is the breaker box with the battery heater circuit breakers? Are the incoming leg one and two main breakers in that box? It's hard to believe the main breakers would be seperated from the panel. It's all a SWAG. lol Leroy Eckert 1990WB-40"Smoke N Mirrors' Niceville, FL Royale Conversion ----- Original Message ----- From: Jack and Liz Pearce To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 24, 2007 3:14 PM Subject: [WanderlodgeForum] Mysterious Items in Bedroom Cabinet!!! 1993 Wanderlodge, WLWB Howdy, Wanderlodge Forum family. We have some mysterious items in one of our bedroom closets; a circuit breaker box and a rheostat. Jack has no idea of their purpose. He thought that the rheostat might be part of the hydronic heating system, controlling a blower fan on a heat exchanger under the bedbox. We lifted up the air mattress( what a job that was) so Jack could check the exchanger. No fan there nor any wires that might be for a blower fan. Back to square one. Jack has no idea what that breaker box controls and no, he hasn't turned those breakers off to find out. Please look in the Photo section of this Forum at the album entitled, "Mysterious Items in Bedroom Cabinet". There are photos of the cabinet and those mysterious items. Answers, ideas or SWAGs to our mystery will be welcomed. Thanks, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Currently in Buena Vista, CO where there is snow on the mountain peaks! [Non-text portions of this message have been removed] |
09-24-2007, 09:52
wrote: > > Well, the ole Bird is at it again. My coach has a Hydronic system with two sets of convection fans. One set under the couch and the other under the bath vanity. They both were designed with a sensor about the size of a quarter with a pin in the center strapped to a rubber hose that causes the rheostat to operate when the system is up to temperature. If the sensor fails, the fans do not work. My couch fans work when the system is activated. The bath fans work when the system is up to temp. When the bath sensor fails, I will bypass it and send the power direct to the rheostat since the temperature rises rapidly. Something less to fail in the future. If that rheostat does not dim lights it must be associated with the heating system. > On the high voltage panel I would turn off one at a time and start looking, first at the overhead leg gauges. If nothing there, I would start turning things on and see what does not work. > Where is the breaker box with the battery heater circuit breakers? Are the incoming leg one and two main breakers in that box? It's hard to believe the main breakers would be seperated from the panel. > It's all a SWAG. lol > Leroy Eckert > 1990WB-40"Smoke N Mirrors' > Niceville, FL > Royale Conversion > ----- Original Message ----- Howdy, Leroy. Thanks for the reply. The battery heater circuit breakers are on the MAIN circuit beaker panel which is located in another cabinet in our bedroom. My SWAG is that the mysterious circuit breaker box is for the hydronic heating system(Webasto). I understand that your coach has the Webasto hydronic heat, also. I 'll email you about that as I have some questions about it. Thanks again, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Still in Buena Vista, CO |
09-24-2007, 10:17
Jack, Liz
I think that the rheostat does control a fan for the heating system. I didn't think that there was a fan in the bedroom until I fired up the heating system about two weeks ago. If you look to the right on the water filter under your bed you should see a snap disc just to the right of it. I have a fan hidden just to the right of that snap disc. I can hear it click then the fan turns on. I didn't know what controlled the fan but my guess is your mystery rheostat does. Steve Quandt Iron Mountain, MI 1993 PT-40 -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jack and Liz Pearce Sent: Monday, September 24, 2007 4:52 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Mysterious Items in Bedroom Cabinet!!! 1993 Wanderlodge, WLWB --- In WanderlodgeForum@ yahoogroups.com, "Leroy Eckert" wrote: > > Well, the ole Bird is at it again. My coach has a Hydronic system with two sets of convection fans. One set under the couch and the other under the bath vanity. They both were designed with a sensor about the size of a quarter with a pin in the center strapped to a rubber hose that causes the rheostat to operate when the system is up to temperature. If the sensor fails, the fans do not work. My couch fans work when the system is activated. The bath fans work when the system is up to temp. When the bath sensor fails, I will bypass it and send the power direct to the rheostat since the temperature rises rapidly. Something less to fail in the future. If that rheostat does not dim lights it must be associated with the heating system. > On the high voltage panel I would turn off one at a time and start looking, first at the overhead leg gauges. If nothing there, I would start turning things on and see what does not work. > Where is the breaker box with the battery heater circuit breakers? Are the incoming leg one and two main breakers in that box? It's hard to believe the main breakers would be seperated from the panel. > It's all a SWAG. lol > Leroy Eckert > 1990WB-40"Smoke N Mirrors' > Niceville, FL > Royale Conversion > ----- Original Message ----- Howdy, Leroy. Thanks for the reply. The battery heater circuit breakers are on the MAIN circuit beaker panel which is located in another cabinet in our bedroom. My SWAG is that the mysterious circuit breaker box is for the hydronic heating system(Webasto). I understand that your coach has the Webasto hydronic heat, also. I 'll email you about that as I have some questions about it. Thanks again, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Still in Buena Vista, CO [Non-text portions of this message have been removed] |
09-24-2007, 10:31
I converted mine from Primus. Now a single loop system that works great. If I
can help I will. email at jwasnewski@... Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Jack and Liz Pearce To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 24, 2007 4:52 PM Subject: [WanderlodgeForum] Re: Mysterious Items in Bedroom Cabinet!!! 1993 Wanderlodge, WLWB --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" wrote: > > Well, the ole Bird is at it again. My coach has a Hydronic system with two sets of convection fans. One set under the couch and the other under the bath vanity. They both were designed with a sensor about the size of a quarter with a pin in the center strapped to a rubber hose that causes the rheostat to operate when the system is up to temperature. If the sensor fails, the fans do not work. My couch fans work when the system is activated. The bath fans work when the system is up to temp. When the bath sensor fails, I will bypass it and send the power direct to the rheostat since the temperature rises rapidly. Something less to fail in the future. If that rheostat does not dim lights it must be associated with the heating system. > On the high voltage panel I would turn off one at a time and start looking, first at the overhead leg gauges. If nothing there, I would start turning things on and see what does not work. > Where is the breaker box with the battery heater circuit breakers? Are the incoming leg one and two main breakers in that box? It's hard to believe the main breakers would be seperated from the panel. > It's all a SWAG. lol > Leroy Eckert > 1990WB-40"Smoke N Mirrors' > Niceville, FL > Royale Conversion > ----- Original Message ----- Howdy, Leroy. Thanks for the reply. The battery heater circuit breakers are on the MAIN circuit beaker panel which is located in another cabinet in our bedroom. My SWAG is that the mysterious circuit breaker box is for the hydronic heating system(Webasto). I understand that your coach has the Webasto hydronic heat, also. I 'll email you about that as I have some questions about it. Thanks again, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Still in Buena Vista, CO [Non-text portions of this message have been removed] |
09-24-2007, 11:15
Jack & Liz...You have two power cord's for your coach. One 50amp is
hard wired and you should have another plug in 30amp cord. The small breaker box with the 30amp breakers is for the plug in cord. It goes here first then to the main breaker box. You also should have a antenna control switch in the same area. this work's same as the one up front to control the direction of the tv antenna. Bob..93pt.Il. > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > wrote: > > > > Well, the ole Bird is at it again. My coach has a Hydronic system with > two sets of convection fans. One set under the couch and the other under > the bath vanity. They both were designed with a sensor about the size of > a quarter with a pin in the center strapped to a rubber hose that causes > the rheostat to operate when the system is up to temperature. If the > sensor fails, the fans do not work. My couch fans work when the system > is activated. The bath fans work when the system is up to temp. When the > bath sensor fails, I will bypass it and send the power direct to the > rheostat since the temperature rises rapidly. Something less to fail in > the future. If that rheostat does not dim lights it must be associated > with the heating system. > > On the high voltage panel I would turn off one at a time and start > looking, first at the overhead leg gauges. If nothing there, I would > start turning things on and see what does not work. > > Where is the breaker box with the battery heater circuit breakers? > Are the incoming leg one and two main breakers in that box? It's hard to > believe the main breakers would be seperated from the panel. > > It's all a SWAG. lol > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors' > > Niceville, FL > > Royale Conversion > > ----- Original Message ----- > > Howdy, Leroy. > Thanks for the reply. The battery heater circuit breakers are on the > MAIN circuit beaker panel which is located in another cabinet in our > bedroom. My SWAG is that the mysterious circuit breaker box is for the > hydronic heating system(Webasto). I understand that your coach has the > Webasto hydronic heat, also. I 'll email you about that as I have some > questions about it. > > Thanks again, > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Still in Buena Vista, CO > |
09-24-2007, 13:44
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
wrote: > > I don't have the foggiest idea about the rheostat or circuit breaker > but I have to tell you that the title of your post got my attention > was thinking "kinkie" I guess. And then again you never know it > could be!! LOL!! Thanks for the reply!! Regards, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 |
09-24-2007, 13:51
--- In WanderlodgeForum@yahoogroups.com, "smquandt"
> > Jack, Liz > > > > I think that the rheostat does control a fan for the heating system. I > didn't think that there was a fan in the bedroom until I fired up the > heating system about two weeks ago. If you look to the right on the water > filter under your bed you should see a snap disc just to the right of it. I > have a fan hidden just to the right of that snap disc. I can hear it click > then the fan turns on. I didn't know what controlled the fan but my guess > is your mystery rheostat does. > Steve Quandt > > Iron Mountain, MI > > 1993 PT-40 Howdy, Steve. Thanks for the reply. I'll check that out tomorrow. Not sure that I know what a snap disc is, though. Thanks again, Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 > > > > > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jack and Liz Pearce > Sent: Monday, September 24, 2007 4:52 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Mysterious Items in Bedroom Cabinet!!! 1993 > Wanderlodge, WLWB > > > > > --- In WanderlodgeForum@ > yahoogroups.com, "Leroy Eckert" > wrote: > > > > Well, the ole Bird is at it again. My coach has a Hydronic system with > two sets of convection fans. One set under the couch and the other under > the bath vanity. They both were designed with a sensor about the size of > a quarter with a pin in the center strapped to a rubber hose that causes > the rheostat to operate when the system is up to temperature. If the > sensor fails, the fans do not work. My couch fans work when the system > is activated. The bath fans work when the system is up to temp. When the > bath sensor fails, I will bypass it and send the power direct to the > rheostat since the temperature rises rapidly. Something less to fail in > the future. If that rheostat does not dim lights it must be associated > with the heating system. > > On the high voltage panel I would turn off one at a time and start > looking, first at the overhead leg gauges. If nothing there, I would > start turning things on and see what does not work. > > Where is the breaker box with the battery heater circuit breakers? > Are the incoming leg one and two main breakers in that box? It's hard to > believe the main breakers would be seperated from the panel. > > It's all a SWAG. lol > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors' > > Niceville, FL > > Royale Conversion > > ----- Original Message ----- > > Howdy, Leroy. > Thanks for the reply. The battery heater circuit breakers are on the > MAIN circuit beaker panel which is located in another cabinet in our > bedroom. My SWAG is that the mysterious circuit breaker box is for the > hydronic heating system(Webasto). I understand that your coach has the > Webasto hydronic heat, also. I 'll email you about that as I have some > questions about it. > > Thanks again, > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Still in Buena Vista, CO > > > > > > [Non-text portions of this message have been removed] > |
